		| Author | Message |
		| ira.saligman(at)verizon.n Guest
				|  Posted: Tue Feb 21, 2006 2:48 am    Post subject: Starting the -52 in cold weatherStarting the -52 in cold we |   |
Two things we  do in the starting regiment:
 1) allow two minutes  to pass from when you finish priming the cylinders before starting.  This  allows the fuel to vaporize in the cylinders.
 2) immediately prior  to starting, prime the main pipe (primer to the left) the pump the throttle full  fwd and aft twice prior to setting it at the 1/3 point.
 Holding the starter  on after you hear firing, does help and does not damage the starter as it  would an electric starter.
 We use a rule  for priming, 1 pump for every 10 degrees C below 100.
 Ira Saligman
 isaligman(at)saligman.com (isaligman(at)saligman.com)
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 4:08 am    Post subject: Re: Starting the -52 in cold weatherStarting the -52 in cold |   |
				| Russian manual recommends 2-3 minutes in summer between priming & starting, rising to 3-4 minutes in winter due to lower fuel vapourisation rate.
 They also warn about over-priming as this "washes" oil off the cylinder walls & presents a hydraulic lock risk too ... it only needs an eggcup of liquid.
 If you've a manifold drain, leave it open during priming & you will be surprised as to how much fuel can pour out even with 6 or 7 cylinder primes.
 Rob R.
		| Back to top |  |
