czech floats
usher
PostPosted: Tue Sep 18, 2007 3:41 am    Post subject: czech floats Reply with quote
I have a model 111, 582, on Full Lotus floats. Plane empty on wheels weighs 496 lbs, I weigh 150. Not really happy with Full Lotus and have to have amphibs. Looking to buy Czech amphibs. Anybody with this combination? and if so, how is water performance with two people. Thanks.
Don
akflyer
PostPosted: Tue Sep 18, 2007 2:20 pm    Post subject: Re: czech floats Reply with quote
is there a particular reason that you dont like the full-lotus floats? Are you by any chance using the skystar rigging? I was not real happy with the full lotus on the KF using the original skystar rigging till I changed the step position and the angle of incidence on the wing.. now it is a fun machine that will go some amazing places.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Tue Sep 18, 2007 6:52 pm    Post subject: czech floats Reply with quote
What were your new figures on the step and the incidence??
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
greg(at)case-assembly.com
PostPosted: Fri Sep 21, 2007 6:27 am    Post subject: czech floats Reply with quote
I did not see any responses to the question on the Czech Floats.
While we are on the Float topic (and by the way great video!) lets chat about these Czech floats if anyone has an opinion.
gc
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don & Dianne Usher
Sent: Tuesday, September 18, 2007 7:40 AM
Subject: czech floats
Don
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
No virus found in this incoming message. size=2>Version: 7.5.487 /
9/20/2007 12:07 PM
kcozik(at)cablespeed.com
PostPosted: Fri Sep 21, 2007 8:21 am    Post subject: czech floats Reply with quote
I really have no information to add to the float debate since I have such
limited knowledge of the diffrent brands and styles of floats. My experience
consists of about 10 hours in a supercub on EDO 2000's and have not landed mine
in the water yet (maybe this weekend). I'll keep the list posted as to the
performance of the Czech floats.
Kevin Cozik
Series 6
914 turbo
On Fri Sep 21 10:26 , 'Gregory Cronin' <greg(at)case-assembly.com> sent:
Floats.
opinion.
gc
Dianne Usher
To:
kitfox-list(at)matronics.com
Subject: czech
floats
Thanks.
Don
size >Version: 7.5.487 /
9/20/2007 12:07 PM
dave
PostPosted: Fri Sep 21, 2007 8:51 am    Post subject: Re: czech floats Reply with quote
some Kitfox Videos here
http://www.youtube.com/profile?user=kitfoxflyer
floats , skis and water.
gotta be a few thousand Kitfoxes flying and only 22 vidoes from me plus a few others on you tube.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
PostPosted: Mon Sep 24, 2007 7:48 am    Post subject: czech floats Reply with quote
Is anyone here flying the Czech floats currently?
If so please let us all know what you think.
Thanks!
gc
1:53 PM
john(at)leptron.com
PostPosted: Mon Sep 24, 2007 8:14 am    Post subject: czech floats Reply with quote
Me too,
I sold my aerocet amphibs to Dan Denny a few years ago and really want to
replace them next year. The Czech floats seem fairly strong, though not for
rough beaching.
John Oakley
Fox 4 long and short
Cap - 912ul
PostPosted: Mon Sep 24, 2007 10:52 am    Post subject: czech floats Reply with quote
Yes, I'm flying the 1650s with my first water landings yesterday. I landed about
9am yesterday morning in no wind and glassy conditions. They felt great touching
down and there was not much tendency to pitch forward considering the smooth water
condition. As I can off the step, the nose came up like normal and then settle in
fairly flat......maybe a little too flat as some water made its way over the front
of the float. Idle taxing I could see water building up in front of the float which
I blamed on the large front cavity where the nosewheel sits. Just for kicks I
wanted to see how long it would take to get on step before I turned around to depart
but it could not climb up on step no matter what I tried. Now I'm concerned about
how the floats are sitting in the water (nearly flat). To make a long story short,
I ended up adding about 10 lbs to the rear compartment of each float to get off the
water. First try it was up on step almost instantly but the wind and water
conditions had also changed to 10 mph. Multiple takeoffs and landings with great
results. Fast off the water and very smooth on!
I'll try again in the next few days but I'm hoping I won't have to keep the extra
weight in the floats and that the reason the water came over the top was more of an
amphib problem than a rigging problem.
Any thoughts?
Kevin Cozik
S6 Czech 1650s
914 turbo
Lansing Michigan
On Mon Sep 24 11:46 , 'Gregory Cronin' <greg(at)case-assembly.com> sent:
Thanks!
gc
1:53 PM
av8rps(at)tznet.com
PostPosted: Tue Sep 25, 2007 3:27 pm    Post subject: czech floats Reply with quote
Greg,
I have 25 years of float flying experience, with a total of 2200 hrs in
seaplanes. 1300 hours of that seaplane time has been in various light sport
type aircraft. I have a bit more than 30 hours in an amphibious Czech float
equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty weight
on wheels around 670 lbs, and right close to 900 on floats. The floats are
the 4 wheel option 1150/1200a amphibs.
The floats work, but lack forward floatation, as well as total floatation
for the Rans (note how low the spreader bars are to the water in the
attached picture. Also, the rear seat passenger weight is actually is
helping keep the front of the floats up. Otherwise the bows would be
plowing water over the top when idling). The landing gear has no
suspension, and while the main gear does have a down lock, the nosegears are
held down purely by hydraulic pressure, consequently causing concerns about
gear collapse in the case of hydraulic failure, The hydraulic cyls also tend
to leak when sitting with the weight of the airplane on them. The other
problem with the floats is that they are approx 15 1/2 ft in length, and
that causes you not to be able to rotate well without dragging the heels
(which will consequently also keep you from leaving the water). This a a
common problem with many older float designs as well. While a long float
offers a nice ride and lots of good tracking and stability, they limit your
ability to take off short because you can't rotate into a steep attitude.
For those reasons I personally would always choose a short float over a long
one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my
Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being
able to rotate due to the float being so long for the airplane. The Czech
floats on this Rans also only have 2 watertight compartments / pump outs.
That would never pass muster for a certified float, as it puts the airplane
at risk of capsizing if ever one compartment were to leak and fill with
water. The good news there is that the later Czech floats are known for not
leaking much water. But if you ever hit an underwater obstruction and poke
a hole in your float, you have little or no reserve buoyancy with 50% of one
float only left watertight.
Another thing I don't like about the Czech floats is they are
hydrodynamically very draggy. Example, last time I flew this Rans I was
doing a downwind takeoff in a 10 mph wind and no matter what I did I
couldn't get enough forward water speed to lift off. I tried everything,
but finally stopped and turned into the wind and took off no problem. That
whole issue is caused by too much reveted skin area causing excess water
drag and limiting the ability to accelerate on the step. And being that I
fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind
takeoffs are never a problem, even though I have 20 hp less than the Rans,
and less wing area. The Aerocets having a smooth fluted bottom have let me
acclerate easily for a takeoff at gross weight in a 25+ mph downwind before
(ps - don't try this at home - I've been flying floats for a lot of years...
Go into the wind like our flight instructors tell us to). I also don't like
the fact that there are no storage areas in the czech floats.
Ok, so what do I like about the Czech floats? Ground handling is good, and
brakes work pretty good or an amphib. Water rudders are sufficiently sized,
and the floats will get you off the water relatively quick as they use a
pretty flat bottom. Of course, since nothing is ever free, rough water is
not the Czech floats forte.
I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It
weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot of
issues, with underfloatation being the biggest problem, and a weak landing
gear second. But other than that it is hands down the best handling float
you will ever fly (I can do a 600-800 foot circular one float takeoff!
Yeah, they handle that good...)
Because I don't think we have a decent choice out there currently for an
amphib float for our planes, I designed my own with all the features I
wanted, and felt we need. I am in final design stages and will be going
into production soon (has been a MUCH bigger job than I ever expected. Oh
well, all good things take time they say...). I expect to have floats
available 1st qtr of 2008. Pricing is targeted to compete with the Czech
floats. And it will be an attractive float with a real landing gear and nice
storage (read as "Not anything weird"). I will let the group know here as
I progress with production. The Kitfox is one of my favorite airplanes, so
I hope to set up a Kitfox as one of the first airplanes on my new floats.
Paul Seehafer
ps - did those Avid amphibs not work out for your?
 Filesize:  626.8 KB
 Viewed:  792 Time(s)
john(at)leptron.com
PostPosted: Tue Sep 25, 2007 8:26 pm    Post subject: czech floats Reply with quote
Paul,
That is the greatest report on floats I have seen. I am thinking you need to
quit your job and write for a magazine. Smile Honestly that is what many of us
want to hear, One persons experience and feelings. I now believe you are
capable of making a great set of floats. I along with many others are
waiting for more info on your system. I learned from you about how many
compartments there need to be, also the storage area's is a must, I had
forgotten the aerocet had them. I actually put my kids in the floats with
their heads sticking out and dressed like elfs, me as santa.( they will
never forgive me)
Any picture of the floats you want to share.
Again, thanks
John Oakley
Fox 4 speedster long and short
912 ul
mikelaundy(at)yahoo.co.uk
PostPosted: Tue Sep 25, 2007 10:13 pm    Post subject: czech floats Reply with quote
Paul,
That was a very interesting piece you wrote about floats. All the more so as I am planning to fit my KF3 with Aerocet amphibs this winter. If you have any tips about using the Aerocets I would sure appreciate it.
Mike Laundy
KF3 582
john oakley <john(at)leptron.com> wrote:
[quote]--> Kitfox-List message posted by: "john oakley"
Paul,
never forgive me)
Again, thanks
John Oakley
912 ul
PostPosted: Wed Sep 26, 2007 5:35 am    Post subject: czech floats Reply with quote
Your always the right guy to share your knowledge when it comes to floats.
Thanks for the information.
I did a lot of work on the avid floats. Repainted them and powder
coated/anodized all the components. But never did fit them to the plane
because I thought they may not be enough float. I have plans to modify them
by adding another scallop to each side of the float but have not got to that
point.
I would be interested in any drawings you would be willing to share of your
new design.
Always good to hear from you.
greg
dave
PostPosted: Wed Sep 26, 2007 6:29 am    Post subject: Re: czech floats Reply with quote
I will be interested in Paul's floats as well when he gets them ready.
I have Aerocet 1100s on 582 and they work well, like Paul says one of the best handling floats on the water but a bit under floated. I could see them be near not very good on a Subaru install. 582 ok but when dual with heavy load it takes more to get up on step and a 582 is likely about 150 lbs less than a Sub on the nose ... and the nose is where they seem under-floated the most.
That being said they are very aerodynamic and your speed loss will be far less than some real draggy floats like Full lotus.
I think the Aerocet 1100 was set at 1100 displacement per float Before the Amphibs were installed and hence loss some capability.
Landing gear is ok but if you operate off non smooth runways like i do with thousands of takeoffs and landings your gear in time will fail . Seaplane ramps can take there toll as well.
I have about 20 + videos up with float ones too www.cfisher.com and look for link .
av8rps(at)tznet.com
PostPosted: Fri Sep 28, 2007 5:17 am    Post subject: czech floats Reply with quote
Hey gang,
I want to briefly reply to all of your comments about floats, but am on a
time crunch getting ready for a week plus float plane trip to northwest
ontario in a Beech 18 with two of my buddies. But when I return, I would be
happy to respond to any of the float questions Noel, Michael, and Joe have
asked me to explain further. So remind me in about a week and a half.
Briefly;
John; Thanks for the compliment about what I wrote. Fwiw I do write
articles for magazines - check out EAA's August 2006 Sport Pilot for an
article I wrote on LSA seaplanes and converting one to floats.
Noel; Yes, there are a lot of times a downwind takeoff and landing are
needed or at least preferred. I can explain further later.
Michael; I'd be happy to give you some good tips on the aerocet float
install on your airplane. I think I've learned a lot about what to do and
not do with these floats. Would love to see you be able to successfully
operate yours. Plus, I can put you in contact with others who have info to
share on the aerocet 1100 as well. We've developed a good communications
amongst a small group of us aerocet 1100 float flyers, and sharing info
between us has proven extremely valuable.
Greg and everybody else; I will be happy to explain more about my new
floats to you when I return. To make a long story short, they will be a
float specifically designed for airplanes like we (me included) like to fly.
So having flown Avids and Kitfoxes (as well as other G.A. aircraft) since
the mid 80's on floats, I know what we need, and what we don't need. And as
I said before, as far as I'm concerned we currently have no good choices out
there (sorry, just my opinion..). But my float will change that. It has
been in development for over a year now, but I'm not just eyeball
engineering things here. I sought out true experts to help me. Running
EAA's AirVenture Seaplane Base, and being around the seaplane crowd for a
quarter century has provided me with many contacts that have an incredible
amount of float operating and building experience, and they were willing to
share their knowledge because we're friends. Combining that expert help
along with my seaplane flying background, and my frustration over not having
a good float choice, I'm convinced will provide guys like us with a
marvelous amphib float. Oh yeah, and I promised myself I'd do all I can to
make it reasonably priced. I remember not too long ago when I had to scrimp
and save to buy my first set of inexpensive floats. So I want to make sure
my float is a real value, and is as affordable as I can make it without
sacrificing quality. Hopefully this will help you all to understand better
where I'm coming from, and why I'm passionate about producing a great float
for our airplanes. (see the pic attached if you want an approximate idea
what my new floats will look like. Will be very similar to that... but
better!)
Talk to you all in about a week and a half!
Paul Seehafer
Kitfox IV 912ul amphib
Central Wisconsin
 Filesize:  240.04 KB
 Viewed:  681 Time(s)
