LarryRosen
Posted: Mon Sep 24, 2007 5:18 am Post subject: Rivethead-Aero Door Guide - help |
I am one of the fortunate ones that have received my door guides from
rivethead-aero. While trying to install them they are to wide (the
distance between the door frame to the door) and prevent the door from
closing properly. In my case it is for 3 of the 4 guides. Has anyone
else had this problem and what is the solution?
Larry Rosen
#356
still working on the doors
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
rene(at)felker.com Guest
Posted: Mon Sep 24, 2007 5:37 am Post subject: Rivethead-Aero Door Guide - help |
I had the same problem. I cut down the nylon guides on the door. I was
able to cut enough off so that they did not contact. I have not put the
doors back on since I got the fuselage back from the paint shop....hope they
still fit.
Rene' Felker
N423CF
40322
801-721-6080
zackrv8
Posted: Mon Sep 24, 2007 5:37 am Post subject: Re: Rivethead-Aero Door Guide - help |
Larry,
The door guides were made that way to accommodate every application. Every door to fuselage distance is not the same on every RV10. So, you have to trim the backside of the guides to make it fit. I guess you could trim some off the delrin on the door if you wanted to, but I didn't do that.
Zack
_________________ RV8 #80125
RV10 # 40512 |
LarryRosen
Posted: Mon Sep 24, 2007 6:20 am Post subject: Rivethead-Aero Door Guide - help |
"trim the backside" Thats what I thought but, how? If I had a mill
it would be easy, but then I could have made the part . I
could use a grinder or sanding disk, but that seems a crude way to fit
such a beautiful piece of machine work. Suggestions.
Larry
zackrv8 wrote:
Larry,
Zack
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=136080#136080
#40356
N205EN (reserved)
<http> |
Deems Davis
Posted: Mon Sep 24, 2007 7:01 am Post subject: Rivethead-Aero Door Guide - help |
This is definately NOT an elegant way to do it, but since I didn't have
a milling machine. I used a flat 1/2" router bit, chucked in a drill
press. Put the part in a drill press vise and 'milled' off very small
amounts at a time. cleaned it up with the vixen file.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Larry Rosen wrote:
planesmith(at)hotmail.com Guest
Posted: Mon Sep 24, 2007 7:11 am Post subject: Rivethead-Aero Door Guide - help |
If you are a member of an EAA chapter, does anyone in the chapter have a milling machine? They may be a resource for you.
Vern Smith
> Date: Mon, 24 Sep 2007 10:18:26 -0400
| Quote: | From: LarryRosen(at)comcast.net
Subject: Re: Re: Rivethead-Aero Door Guide - help
--> RV10-List message posted by: Larry Rosen <LarryRosen(at)comcast.net>
Larry
Make your little one a shining star! Shine on! [quote][b]
