d-m-hague(at)comcast.net Guest
Posted: Thu Sep 20, 2007 6:46 pm Post subject: gap seal |
At 10:39 AM 9/20/2007, boyd wrote:
Dana
Or you could make it permanent, bolt it on and forget it.
Boyd
I would, but I expect to be folding the wings on a regular basis.
-Dana
"I'm a lawyer." "Honest?" "No, the usual kind."
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Sat Sep 22, 2007 5:40 am Post subject: Re: Gap Seal |
Group,
We "HAD" an Ultra Star pilot argue the same point 2 years ago in Tullahoma Tn. at a large event. he thought it was not needed, crashed in front of hundreds of spectators Dying in a very gruesome way as when his BRS handle hooked on the tree he impacted, the rocket went off with the cable around his neck, or where his neck used to be!! Do as you will but, its not worth saving a couple of minutes of setup time and playing test pilot. I apologize if this sounds harsh but, the sight of that will never leave my mind.
Fly Safe,
Wade
Posted: Sat Sep 22, 2007 6:52 pm Post subject: Gap Seal |
At 09:40 AM 9/22/2007, Wade Lawicki wrote:
Group,
in front of hundreds of spectators...
Well, I went ahead and made one for mine last night, why take
chances? .040" clear vinyl held on with 2" heavy duty velcro; it actually
came out quite nice. I haven't actually flown with it yet (other than one
short crow hop; it was too windy) but it seems to be holding on just fine.
-Dana
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Sun Sep 23, 2007 5:21 am Post subject: Re: Gap Seal |
New Kolb Mark II owner here. Can you guys take a look at the picture I've attached and tell me if you've seen a gap seal like the one I have? It is some kind of cloth (I don't know what). It is velcroed onto the wings. Is that safe?
Cristal
51.87 KB |
1335 Time(s) |
herbgh
Posted: Sun Sep 23, 2007 5:34 am Post subject: Gap Seal |
Cristal
The Kolb Firefly uses the same or similar gap seal.. Canvas or heavy
cloth with velcro... The velcro that is attached to the wing roots comes
unglued in short order...on mine anyway... Herb
On Sun, 23 Sep 2007 06:21:34 -0700 "cristalclear13"
<cristalclearwaters(at)juno.com> writes:
beauford173(at)verizon.ne Guest
Posted: Sun Sep 23, 2007 6:28 am Post subject: Gap Seal |
Brother (Brothette?) Cristal:
Per your question... I don't believe safety is necessarily the issue with
the nylon seal. However, I had unsatisfactory results with the Kolb
factory-provided rip-stop nylon gap seal which came in the Firefly kit... It
never actually came off, but despite my re-velcroing efforts on the aft end,
the trailing edges gradually feathered out and shredded in the slipstream
until it eventually became an unsightly mess after about 50 hours. The last
time I flew with it installed, I learned a bonus lesson about nylon and
various hot Rotax Brothers components, particularly, the exhaust... The tiny
nylon fuzz instantly melts and bakes onto every hot surface with which it
comes into contact... and the low-pressure turbulent areas behind the BRS
cannister did a superb job of sucking that little cloud of nylon thread
particles back forward enough to give a really nice spattering effect on
parts well forward of the shredding areas further aft....
Once baked on there, it took a delightful scotchbrite and sandpaper weekend
before I finally got all of that crap off the engine.
I would use asphalt roofing shingles for a gap seal before I would put
another one of those nylon thingys
on my airplane... It now has an aluminum seal, heavy velcro at the front,
bungees at the rear... 90 or so hours on the thing... no problems.... yet...
Worth what ye paid fer it...
Beauford
FF-076 / N173BW
Brandon, FL
that safe?
Cristal
http://forums.matronics.com/viewtopic.php?p=135867#135867
http://forums.matronics.com//files/kolb_mark_ii_seats_148.jpg
Posted: Sun Sep 23, 2007 7:38 am Post subject: Gap Seal |
| Quote: | another one of those nylon thingys
on my airplane...
Beauford
Bill:
Got to admit, that nylon is light in weight.
On the other hand, asphalt shingles are a good idea. Especially the ones
you all use in Florida. GAF has some rated for 110 mph, well above the vne
for a FF. As a matter of fact, they also have some 80 mph shingles, but
there is always the chance one may slip over the vne of the FF and exceed 80
mph.
DO NOT ARCHIVE
_________________ John Hauck
Titus, Alabama |
cristalclear13
Posted: Sun Sep 23, 2007 6:05 pm Post subject: Re: Gap Seal |
Thanks for sharing your input and experiences. Just curious if there are factors that contribute to the deterioration of the Velcro such as...are they hangered right after flying vs. left out in the weather...do you fold the wings every time you're done flying, thus needing to continually remove and replace the cloth gap seal...do you live in extreme climates?
Beauford, I've never heard the term "Brothette", but if that's what you'd call a "Mrs.", then yep, that's me.
Aviatress Cristal
Posted: Sun Sep 23, 2007 6:19 pm Post subject: Gap Seal |
At 10:05 PM 9/23/2007, cristalclear13 wrote:
Different types of velcro are rated for different lifespans (number of
stick/unstick cycles). In general, the stronger the bond, the shorter the
life.
For mine, I found a strong bond velcro that still is good for plenty of
cycles... and has an adhesive back specifically made for flexible vinyl,
which is what I used... and sticks just great to the Stits wing covering,
which also is vinyl based.
-Dana
HShack(at)aol.com Guest
Posted: Sun Sep 23, 2007 6:32 pm Post subject: Gap Seal |
In a message dated 9/23/2007 10:07:34 PM Eastern Daylight Time, cristalclearwaters(at)juno.com writes:
| Quote: | | Just curious if there are factors that contribute to the deterioration of the Velcro such as... |
The sun deteriorates the glue on Velcro fairly fast. Most people get rid of the cloth gap seal pretty quick.
My plane is a FS II.
Mine is made of .060 Lexan with an aluminum leading edge & some lateral aluminum angles & is held on with screws into the wing leading edge, industrial Velcro along the edges, & bunjii's. It only covers the top of the wing as I like a lot of clearance for my big head.
The best mod. I have made to my FSII is to replace the short windshield with one that starts out the same as the shorty at the bottom [where it bolts on], but extends all the way up to the wing. Also, because of bad knees, I trimmed the right side of the windshield so that only one screw holds that side, gives me about 8" more room to get my foot in. Yes, my windshield shape is assymetrical, the plane doesn't care.The new Lexan was increased in thickness to .090". I don't fold.
I no longer feel the wind is pushing my head back & it makes winter flying more bearable. By the way, I live in SC.
Howard Shackleford
FS II
SC
Make AOL Your Homepage.
Posted: Sun Sep 23, 2007 7:21 pm Post subject: Gap Seal |
Madam Aviatress Cristal...
Per your questions; My machine lives in an enclosed trailer and is folded
after each flight.
My take on the deterioration of the nylon cloth was that it was not so much
the velcro, or any sort of UV induced ageing, as it was the fluttering of
the trailing edge of the center portion of the cover... I think it
mechanically beat itself to death. As I mentioned, I reinforced the velcro
on the sides toward the rear with heavier stuff... and I took particular
care to stretch it as tightly as possible after noticing that it was
shredding a little over toward the center... From the time I first noticed
the beginning of the problem until it turned into a fuzzy nylon party favor
was not more than five flight hours. That last hour did almost all of the
serious damage.
As for living in an extreme climate... I have been married over 42
years....
Good Luck, and enjoy your Mark II.
Beauford
p.s. Aluminum and lexan are our friends....
flying... Do you live in an extreme climate?
Aviatress Cristal
http://forums.matronics.com/viewtopic.php?p=136008#136008
by0ung(at)brigham.net Guest
Posted: Sun Sep 23, 2007 9:09 pm Post subject: gap seal |
Dana
Boyd
-Dana
Dana
With the way I built my gap seal, I can fold the wings without removing
it.
Boyd.
herbgh
Posted: Mon Sep 24, 2007 2:20 am Post subject: Gap Seal |
Cristal
I had 15 hours on my velcro..always hangered...always folded.. It came
loose on the top of the wing toward the engine.Both sides..
Currently working on a .016 2024 t3 sheet of Aluminum to replace the
cloth gap seal.. I do not plan to use lexan as it is much too heavy..Herb
On Sun, 23 Sep 2007 19:05:47 -0700 "cristalclear13"
Aviatress Cristal
Posted: Mon Sep 24, 2007 3:00 am Post subject: gap seal |
At 01:07 AM 9/24/2007, boyd wrote:
it.
That sure sounds convenient... but I don't think it's possible on an Ultrastar.
-Dana
Posted: Mon Sep 24, 2007 4:15 am Post subject: Gap Seal |
At 07:05 PM 9/23/07 -0700, you wrote:
Cristal,
History of my center wing gap seal.
I painted the original white gap seal to match the color of the FireFly.
The thread on the original Kolb supplied trailing edge started to fail from
flapping after three hours of fight. I re-sewed the seam and inserted a
small diameter aluminum tube inside the seam to stiffen the trailing edge.
This stopped the fluttering and I had no further problems with the trailing
edge.
After 41 hours, about one year, I replaced the gap seal. I purchased light
red Dacron cloth that closely matched the color of the FireFly. I cut the
thread on the original gap seal so that I could use it as a pattern. I
re-used the original Velcro. It has been in place for the last 190 hours and
seven years. To save weight, I did not paint or seal the cloth. I keep the
back edge from fluttering by using a small piece of Velcro in the center to
attach it to the engine support tube. I did install a tube in the foremost
seam to prevent it from buzzing.
I rarely fold. The FireFly is hangared in and enclosed building out of
direct sun light. All but two years of this time the FireFly was hangared
in the Mississippi River bottoms where it was hot and humid in the summer.
I have not had any trouble with the adhesive backing on the wings. At this
time, the color shows some fading, but otherwise the gap seal in in good
shape.
I hope this helps you out.
Jack B. Hart FF004
Winchester, IN
Richard Pike
Posted: Mon Sep 24, 2007 4:49 am Post subject: Gap Seal |
Cristal, years ago I had a Maxair Hummer that often needed to have the wings
folded, and I had a very successful gap seal made from Naugahyde that was
semi stretchy. It would give a little when you stretched it, it had Velcro
sewed around the perimeter to attach to the various structure points. The
stretchiness allowed it to fit tightly. Based on my experience, if I were
going to use any sort of fabric instead of aluminum, I would choose
Naugahyde instead of cloth, and also sew a reinforcement into the rear edge
ala Jack Hart's method.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
herbgh
Posted: Mon Sep 24, 2007 6:48 am Post subject: Gap Seal |
Piping in
My experience tells me that just the last foot or so of velcro ,
glued to the wings, toward the engine, on the top side, is all that needs
fixing..
I figure that the gap seal is flapping a bit in flight to hasten to
the problem... Herb
On Mon, 24 Sep 2007 08:47:02 -0400 "Richard Pike" <richard(at)bcchapel.org>
writes:
the wings
that was
Velcro
points. The
were
rear edge
Richard Pike
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Tue Sep 25, 2007 12:02 pm Post subject: Re: Gap Seal |
Without the gap seal you are going to have some kind of degraded performance....we can all agree, even if is is not that noticeable.
You will also have more turbulence over your tail due to the extra vortices effecting controlability.
I think we can all agree that Gap Seal WILL improve things.
The consequences of NOT using a gap seal can be minor or even Hazardous to your health.
My Ultrastar has a fiberglass Gap seal, but Im sure aluminum or fabric are just as good or better.
I'd say use the Gap seal and have a better flying safer aircraft.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
WillUribe(at)aol.com Guest
Posted: Tue Sep 25, 2007 2:41 pm Post subject: Gap Seal |
Here are pictures of some of the repair I have to make.
33.46 KB |
1260 Time(s) |
30.33 KB |
1275 Time(s) |
30.78 KB |
1150 Time(s) |
Posted: Tue Sep 25, 2007 3:47 pm Post subject: gap seal |
I have never seen an ultrastar.... but unless it folds differently than
the mkIIIc it should be possible.
Boyd
it.
Ultrastar.
-Dana
