High compression, high CHTs
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
jrstone(at)insightbb.com
PostPosted: Sun Sep 23, 2007 3:47 am    Post subject: High compression, high CHTs Reply with quote
First let me announce the fact that N918JK is flying, as of about a week ago.
Second, I need some advice to clear up high CHTs.
I am running ElectroAir's ignition on lower plugs and a Slick Mag on the upper plugs. I have 10-1 pistons in new Lycoming jugs. On the first few short flights my CHTs climbed right through redline on 5 or 6 cylinders in less than 5 minutes. My EIS timing was factory set to 23 deg to account for the high compression and I set the mag at 25 deg per the engine placard. I reduced the EIS to 20 degrees and saw some relief but two of the CHTs (6 and 2) still climbing into the low to mid 400s. Today I plan on retarding the Mag to 20 degrees because during cruise I felt a vibration and turned the Mag off and the vibration went away so I feel like the two ignitions were not working together. CHT #4 is my coolest with a difference from the hottest (#6) 80-100 deg.
Question: What timing have you high compression guys been using to get reasonable CHTs?
Other than ensuring no leaks in the baffles what else can I do?
BTW, a friend installed the louvers on the bottom of his F-1 cowl and it had no effect so I'm not going there until last.
Thanks for you time,
Jim Stone
Louisville KY
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
fairlea(at)amtelecom.net
PostPosted: Sun Sep 23, 2007 4:11 am    Post subject: High compression, high CHTs Reply with quote
Jim
I have had ok service from the elctro air systems but others have noted erratic ignition timing . Contact Jim Winings, in Indianapolis regarding his electro air situation, as it sounds similar to what you are experiencing.
Tom Martin
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Jim Stone
Sent: September 23, 2007 7:47 AM
To: rocket-list(at)matronics.com
Subject: High compression, high CHTs
Jim Stone
Louisville KY
Release Date: 20/09/2007 12:07 PM
20/09/2007 12:07 PM
n395v
PostPosted: Sun Sep 23, 2007 5:48 am    Post subject: Re: High compression, high CHTs Reply with quote
Congratulations on getting in the air.
I have a stock IO540 and fought CHTs forever, tweaked baffling mesed with timing. Got to where all was ok in cruise but always on climbout I quickly blew through 400Deg F everytime.
Finally put louvers in and have had no problems since.
I think your friend with the louvers probably has an additional issue.
Milt
Wolfgang
PostPosted: Sun Sep 23, 2007 7:23 am    Post subject: High compression, high CHTs Reply with quote
Hi Jim,
congratulations!!
Calibrate your CHT probes. (Check on the ground what a calibrated high quality temp. tester (Fluke) will show you).
If you are using bayonet type probes they might be reading higher and are considered fairly inaccurate (screw in type are more accurate)
What EM are you using?
If your ignition would be the only problem area you’d see high CHTs on all Cylinders.
What is your T/O fuel flow?
Check your baffle gaps! I am referring to Kent Pacers book “Speed with Economy” (P. 59) :
… The cylinder barrel baffle gap was best at 7/8” to 1.0 inch. The cylinder head baffle gap was much more critical to controlling temperatures,
but gave best results at dimensions of 21/4”.
When I was using 10:1s the engine was timed at 20deg. and I had no problems, however I used a Dual LSE Plasma III setup.
Also check that the top part of your cowling intakes allows a smooth airflow transition towards your engine baffling. If this area is rough or curves up at steep angles your
cooling airflow will be very disturbed.
Hope this helped.
Wolfgang
Sent: Sunday, September 23, 2007 5:47 AM
Jim Stone
Louisville KY
  - The Rocket-List Email Forum ---> http://www.matronics.com/Navigator?Rocket-List
CalBru(at)aol.com
PostPosted: Sun Sep 23, 2007 8:31 am    Post subject: High compression, high CHTs Reply with quote
I'd like details re: the louvers. I fly 116 very gingerly in the summer, have a ball with it in the winter. It has cold air induction, tuned exhaust and a plenum, but still seem to run hot.
Cal
116
118 hours
See what's t="_blank">Make AOL Your Homepage.
Hr2pilot(at)aol.com
PostPosted: Sun Sep 23, 2007 8:38 am    Post subject: High compression, high CHTs Reply with quote
What do you all consider high temps?
john
See what's new a_blank">Make AOL Your Homepage.
n395v
PostPosted: Sun Sep 23, 2007 2:34 pm    Post subject: Re: High compression, high CHTs Reply with quote
To me anything over 380 is too high.
[quote="What do you all consider high temps?
john
 Filesize:  27.15 KB
 Viewed:  820 Time(s)
 Filesize:  41.51 KB
 Viewed:  852 Time(s)
 Filesize:  28.09 KB
 Viewed:  854 Time(s)
 Filesize:  28.1 KB
 Viewed:  801 Time(s)
Milt
smokyray(at)yahoo.com
PostPosted: Mon Sep 24, 2007 3:36 am    Post subject: High compression, high CHTs Reply with quote
Jim,
I have the exact same setup in my HR2, a LyCon IO-540 with 10:1's and a EI ignition. I have low CHT's comparatively, 330F in cruise on the lowest, 350F on the highest. Since you are still breaking it in, I would give a chance for the rings to seat, something highly evident inflight. You get a noticeable CHT and oil temp drop. You need to run it hard, I mean HARD the first 5 hours. I typically do a full power climb to 10,000+ feet on a new engine several times. The timing issue sounds like the Mag, but one easy way to check is to isolate them inflight which it sounds like you have. The EI timing is pretty straightforward and works good, lasts a long time. I would check the timing on both, clean the plugs and try it again...
Rob Ray
Tom Martin <fairlea(at)amtelecom.net> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]--> Jim
Tom Martin
Jim Stone
Louisville KY
[quote] [b]
russ(at)wernerworld.com
PostPosted: Mon Sep 24, 2007 5:44 am    Post subject: High compression, high CHTs Reply with quote
Jim,
I run my mag at 25 degrees. What kind of temp did you see? Lycoming redline is 500F. Hope you dind't get that high.
Russ
PostPosted: Mon Sep 24, 2007 6:06 pm    Post subject: High compression, high CHTs Reply with quote
Thanks Rob,
What timing do have your mag and EI set at?
Jim
PostPosted: Mon Sep 24, 2007 6:18 pm    Post subject: High compression, high CHTs Reply with quote
Hey Russ,
The second flight they were climbing to redline and I had to land at my emergency field. They have responded to retarding the timing to 20 deg. I also discovered the mag was not timed where I had set it, it was way early, probably a rookie mistake. I think I may have seen the drop that comes with initial breakin just today, temps were better (less than 410). The engine does not seem to be as smooth as I would like but I have little experience behind a souped up 540. I will keep moving the timing around until I find the setting that is best for my engine.
Jim Stone
Louisville
Jones15183(at)aol.com
PostPosted: Mon Sep 24, 2007 7:10 pm    Post subject: High compression, high CHTs Reply with quote
Jim. are you aware that your EIS has an automatic advance of +7 degrees. So whatever you set the initial setting on , at 2500 RPM degrees the timing is supposed to read 25 degrees BTDC. Or whatever your manufacturer calls for your engine. At 23/23 you might be reading a timing of approx. 32 degrees BTDC. At alt. your highest timing might be 38 degrees BTDC. There are a lot of questions that could be answered about your Eis if I knew all the parameters. Do You have the CSTW or the rear timing mount system. It makes a lots of defference in adjusting your timing system. billy waters
See what's new at AOL.com and Make AOL Your Homepage.
rocketbob(at)gmail.com
PostPosted: Mon Sep 24, 2007 7:54 pm    Post subject: High compression, high CHTs Reply with quote
Jim, congrats on your first flight. Its too bad you have to spend this time debugging and not enjoying something you spent years building.
1. What type of pickup (crank trigger/mag hole trigger)?
2. Which plugs are you running on the bottoms?
3. Have you connected a voltmeter to the the Electroair to determine how much advance there is?
4. Why are your mags not timed exactly to the EI?
Bob Japundza
RV-6 flying F1 under const.
On 9/23/07, Jim Stone <jrstone(at)insightbb.com (jrstone(at)insightbb.com)> wrote:[quote] First let me announce the fact that N918JK is flying, as of about a week ago.
Jim Stone
Louisville KY
[quote][b] http://www.matronics.com/Navigator?Rocket-List http://forums.matronics.com [quote][b]
PostPosted: Tue Sep 25, 2007 3:59 am    Post subject: High compression, high CHTs Reply with quote
Billy,
No I am not aware of an automatic advance of +7 degrees.
I have had daily phone conversations with Mike (the new owner) of ElectroAir. He has been most helpful and very patient with troubleshooting and adjusting the EIS. He set the timing at 23 BTDC due to the 10-1 pistons. My pistons are forged racing pistons from a very nice engine overhaul shop in Ontario CA, sorry I forgot the name. The pistons tops are ceramic coated and have a MolyB coating on the sides, and they are in factory new Lyc jugs. This may explain the high temps.
The ElectroAir system uses a toothed ring on the crank behind the flywheel and a magnetic sensor to read the gap. This signal goes to a controller aft of the firewall, which then controls the coils located forward of the firewall. A MAP or manifold air pressure sensor is teed into the cockpit MAP gage line to provide an input to the controller at all power setting to optimize the ignition curve.
Please tell me what you recommend the timing be set at. My engine is a O-540 E4B5 with a Bendix fuel servo RSA5 and Airflow Performance spider valve.
Don Rivera said the engine appears out of time after reviewing some takeoff parameters like MAP, RPM, FF,CHT and EGTs and fuel pressure, which btw were all within limits.
Thanks for the help,
Jim Stone
Louisville KY
PostPosted: Tue Sep 25, 2007 4:12 am    Post subject: High compression, high CHTs Reply with quote
Hey Bob,
Thanks, and you are right, it has been a real pain. All my attention has been on the temps and trying to get the engine running super smooth. It took 5 flights before I was able to do a stall to verify the stall speed for landing, I got to do 4 landings without knowing this speed. It was no big deal, I just flew the airplane.
In answer to your questions,
1. Crank
2.REM 37BY, top and bottom per ElectroAir
3.Yes, ElectroAir said it is correct, although after small adjustment I did not verify again.
4. The mag is now timed to match the EIS but is not required to be (I'm told by ElectroAir)
Thanks for your interest and help,
Jim Stone
Louisville KY
PostPosted: Tue Sep 25, 2007 5:06 am    Post subject: High compression, high CHTs Reply with quote
Jim, what's the advance voltmeter showing at cruise power. It should be right at 25 degrees in cruise, unless manifold pressure drops which it shouldn't unless you are at 8-9K and above. Also, the old Electroairs were timed at 0 deg. BTDC, not sure if the new purple ones are still that way.
Bob Japundza
On 9/25/07, Jim Stone < jrstone(at)insightbb.com (jrstone(at)insightbb.com)> wrote:[quote] Hey Bob,
1. Crank
Jim Stone
Louisville KY
PostPosted: Tue Sep 25, 2007 9:57 am    Post subject: High compression, high CHTs Reply with quote
My mag is 25 btdc, the EI is an old one installed at TDC with a crank sensor. It has a selector switch in the cockpit to activate/deactivate the advance. I am running airboat Denso spark plugs with Accel plug wires. I ran the exact same setup in my RV4. Normal cruise advance at 20" MP is 34-36. I would give EI a call and see if they can help. One way to eliminate the problem would be to replace both the mag and the EI separately and make test runs. Good Luck...
RR
Jim Stone <jrstone(at)insightbb.com> wrote:
[quote] Thanks Rob,
Jim
PostPosted: Tue Sep 25, 2007 7:39 pm    Post subject: High compression, high CHTs Reply with quote
Jim, there are so many questions that cannot be answered by email. My phone no. is 254 853-2426.
If you want to call me that's ok. I will be home after 7 pm Wed. night. billy
See whatarget="_blank">Make AOL Your Homepage.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
