sarg314(at)comcast.net Guest
Posted: Sun Sep 16, 2007 10:08 pm Post subject: high temp cable ties |
It is acceptable/practical to use high temp. nylon cable ties under the
cowling? Will a DAR accept the use of these to secure wires to the
engine mount tubes?
Tom Sargent, RV-6A, electrical system.
kboatright1(at)comcast.ne Guest
Posted: Mon Sep 17, 2007 3:07 am Post subject: high temp cable ties |
I used regular zip ties on my airplane and the DAR had no problem with that.
After 6 years and 500 hours, they have not given any trouble.
Kyle Boatright
Kellym
Posted: Mon Sep 17, 2007 3:09 am Post subject: high temp cable ties |
Regardless of the temps, it is not acceptable to use cable ties on an
engine mount tube. Oil and dirt get under it and start wearing the tube.
You need a pair of Adel clamps.
KM
A&P/IA
engine mount tubes?
KCHD |
sbuc(at)hiwaay.net Guest
Posted: Mon Sep 17, 2007 5:18 am Post subject: high temp cable ties |
Kelly McMullen wrote:
True.
However, the regular ol' nylon zip ties in the engine compartment of my
RV-6, some of which are on mount tubes, were not only passed by the DAR,
but have stood up just fine for eight years and 825 hours and have
caused no damage.
Maybe it is because oil and dirt are not allowed in the engine
compartment of my plane.
Sam Buchanan
kahuna
Posted: Mon Sep 17, 2007 8:59 am Post subject: high temp cable ties |
I had tie wraps of unknown substance cut into my engine mount of my rv-6 in ~800 hours.
It cut through the powder coating and into the steel.
I do not know what the magic formula was for this to happen.
Too tight? Too much movement? Too loose? Sharp edge tie wraps? I dunno. But Ill never use them again and they are forbiden on the heavies.
My heavies mechanic buddy tried to worn me about this when he looked over my fwf before my first flight. I blew him off and said "yeah right. Whatever. That plastic aint gonna cut into that steel."
I was wrong! It did. And I learned my lesson. Listen to the guy that sees this stuff a lot.
[img]cid:1__=08BBF9CADFC8D4498f9e8a93df938(at)us.ibm.com[/img]"Brian Kraut" <brian.kraut(at)engalt.com>
[img]cid:3__=08BBF9CADFC8D4498f9e8a93df938(at)us.ibm.com[/img]
To
<rv-list(at)matronics.com> [img]cid:3__=08BBF9CADFC8D4498f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
RE: high temp cable ties [img]cid:3__=08BBF9CADFC8D4498f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF9CADFC8D4498f9e8a93df938(at)us.ibm.com[/img]
--> RV-List message posted by: "Brian Kraut" <brian.kraut(at)engalt.com>
Me too. I would stay away from using them to hold your exhaust up though.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com
105 Bytes |
6814 Time(s) |
1.23 KB |
6817 Time(s) |
45 Bytes |
6816 Time(s) |
wskimike(at)mchsi.com Guest
Posted: Mon Sep 17, 2007 12:08 pm Post subject: high temp cable ties |
You can use tie wraps if you use them properly. You are suppose to use one to go around both the structure and the cable and don't tighten it but then use another tie wrap wraped around the first tie wrap in between the cable and structure to tighten the first tie wrap. If installed properly, it won't cut into anything.
105 Bytes |
6814 Time(s) |
45 Bytes |
6813 Time(s) |
n616tb(at)btsapps.com Guest
Posted: Mon Sep 17, 2007 1:37 pm Post subject: high temp cable ties |
Or alternatively you put one around the structure loose to start with and the second around your cable and then through the first tie wrap. Then tighten them.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of wskimike
Sent: Monday, September 17, 2007 3:08 PM
To: rv-list(at)matronics.com
Subject: Re: high temp cable ties
105 Bytes |
6812 Time(s) |
73 Bytes |
6813 Time(s) |
73 Bytes |
6811 Time(s) |
AV8ORJWC
Posted: Mon Sep 17, 2007 3:26 pm Post subject: high temp cable ties |
Kyle - Each builder gets to make these choices personally. It could be
wrong for builders to assign responsibility or assume the DARs role was
to do their final "binding" inspection on your project build. That is
one of the reasons the EAA offers "No Charge" progress inspections to
members to provide an added additional sets of eyes to the build
(Initial, Recurrent, Final) through the EAA Tech Counselor Program.
The DAR role (to my understanding) is primarily the review of
documentation and submission for the all important FAA documents. For
many, they can confirm the DARs walk around was only cursory in scope.
I would love to hear of DARS that accept liability for a final
inspection.
As an A&P working for a regional air carrier, SFAR 88 is real and a
definitive FAA effort to assign an explanation and corrective action to
TWA Flight #800. That is to say "other than those conspiracy theorists
who claim the US Navy brought it down". It remains the most costly,
time consuming FAA accident investigation in US Aviation history.
Compliance is a bitch.
I would propose to builders considering "zip ties" that there are indeed
areas where other attachments are recommended (and more valid) on TCDS
Aircraft and possibility a great starting point for Owner Build and
Maintained Aircraft as well. When ties do give trouble, the prudent
builder has thought it out and chosen wisely.
Glad your specific DAR did more than many and that you are flying
happily after so many hours. I cannot speak for DARs. As a Tech
Advisor, I try to point out other alternatives, enlighten builders on
potential avenues, encourage broad questions and further investigation,
and try to promote safety in the build. Tom's question was "is it
acceptable/practical?" Not much is easier than a zip. The builder
decides. He is the manufacturer and the standard to maintain. I try to
enlighten on the potential consequences. Adel's are most often seen on
Air Carrier fleets due to insurance reasons. They come in various
flavors (color and composition) due to environmental concerns that are
"known".
John Cox
EAA TC #5242
A&P/IA
Kellym
Posted: Wed Sep 19, 2007 3:29 pm Post subject: high temp cable ties |
John Cox put it very well. As the manufacturer, you can do what you want.
A DAR not finding fault with something does NOT mean it is a good practice
or even safe. I can tell you that as an IA, every Tywrap found attached
around the engine mount on a TC aircraft will be written up as a
discrepancy. Your plane, your experiment, you can do as you choose, at
your own risk.
True.
caused no damage.
Sam Buchanan
KCHD |
Kellym
Posted: Wed Sep 19, 2007 3:43 pm Post subject: high temp cable ties |
WRONG! Tie wraps will cut steel engine mount tubing regardless of what
you have under them. It is just a matter of time. If you don't have a
cushion under the tiewrap to prevent it from chafing, it will chafe. But,
if you want to have to occasionally replace or reweld your engine mount,
be my guest. Just remember that the type certificated industry had about
40 years head start on the experimental category in figuring out how to
screw up a perfectly good airplane. You just have the freedom to relearn
others mistakes.
| Quote: | You can use tie wraps if you use them properly. You are suppose to use one
KCHD |
klwerner(at)comcast.net Guest
Posted: Wed Sep 19, 2007 4:18 pm Post subject: high temp cable ties |
Anyone ever heard of *Koroseal* (as sold by AC-Spruce and others) http://www.aircraftspruce.com/catalog/elpages/lacing.php
That is the product I would use in the engine compartment instead of tie-wraps, based on input from much smarter people then myself.
Just because we Experimenters can do whatever they want does not necessarily make it a necessarily great move...
walter(at)tondu.com Guest
Posted: Wed Sep 19, 2007 5:29 pm Post subject: high temp cable ties |
I wrap engine mount tubing with 3 to 4 wraps of self-sticking silicone
tape and put the tie wrap on that. Some of the tape should also be wrapped
around any part being held with the tie wrap as well.
No way that will cut through in my lifetime.
http://www.aircraftspruce.com/catalog/appages/uniwrap.php
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
AV8ORJWC
Posted: Wed Sep 19, 2007 5:42 pm Post subject: high temp cable ties |
I was dressed down "offline" by another poster who was apparently also
an EAA TC (which I did not know from the post). The value for all of
you reading is that everyone has opinions so make your choices wisely.
My presentation which was lost on many, yet remains as follows.
Just because someone has flown X years and Y hours without the problem
rearing its ugly head, use some common sense when selecting techniques
which are not officially supported. Choose wisely. The TWA 800 fiasco
is throwing copious money and time at correcting conditions which "do
lead to failure in electrical systems and fuel distribution system - due
to aging aircraft". It is called "Forensic Pathology". As we are part of
the OBAM community, those of us left flying after others have become
insurance statistics pay for the mistakes of those who chose unwisely.
Zip ties are cheap, quick and we can tend to be lazy. Do it once, do it
right stay safe. Seek a second or third set of eyes to inspect your
work when available. Don't get your technical advice from hangar
flying. DARs serve a valuable service. If you think they are buying
off your pet project as safe, get it in writing with their signature and
DAR designation number or don't make such a representation. You may
just be reading more into the process that the FAA has granted with
their authority to review your documents during that process.
Don't even wind me up on the subject of allowing purchasers of
professional build Kitplanes (who did not build it to 51% rules) to
acquire a repairman's ticket and then maintain them in the same
insurance pool that I pay.
Nuff said. How bout them Red Sox?
John Cox
n343fd(at)yahoo.com Guest
Posted: Wed Sep 19, 2007 7:39 pm Post subject: high temp cable ties |
I have been watching the cable tie debate with interest. Lots of things to think about on both sides. My little bird is extremely well built (by someone other than me so I can say that) it has cable ties and 590 + hours. Checking my little bird out I have noticed that the cable ties hav e abraded some paint. I have looked at a 6 just a couple hangers away with well over 2000 hours, adle clamps and no abraded paint. I will be replacing the cable ties with adle (however you spell it) clamps over time. It just seems better to not have abraded paint. Anyone trying to decide is welcome to come over and take a look if that will help you make a decision. Don't know what is wright or wrong or acceptable in this case I just know what I have observed and the clamps appear at least to me to be a better choice.
Mike Divan
Adopted - N64GH (RV6)
RV7 Builder - SLOW
EAA - 577486
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
acepilot(at)bloomer.net Guest
Posted: Thu Sep 20, 2007 2:37 am Post subject: high temp cable ties |
Here's a link to AC 43-13-1B covering wiring bundles, etc. I do not
imagine it is required to be followed on experimentals, but it certainly
is a good guide...
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2011.pdf
Hope this helps!
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Mike Divan wrote:
| Quote: | I have been watching the cable tie debate with interest. Lots of
Mike Divan
RV7 Builder - SLOW
EAA - 577486
tcervin(at)valkyrie.net Guest
Posted: Thu Sep 20, 2007 4:45 am Post subject: high temp cable ties |
NO! How about those Indians!!!!!!!!
Tom in Ohio RV6-A
[quote]>
John Cox
Kellym
Posted: Thu Sep 20, 2007 5:35 am Post subject: high temp cable ties |
What some folks have been missing in this discussion is that your engine
mount is rather important, and is designed for that single purpose. It is
not designed to be the hangar or mount for a bunch of other stuff.
Minimize what you attach to the mount by any means, and use the best
techniques you can if you feel you have to attach something to the mount.
Nuff said.
[quote] I have been watching the cable tie debate with interest. Lots of things to
be a better choice.
Mike Divan
RV7 Builder - SLOW
EAA - 577486
KCHD |
Posted: Thu Sep 20, 2007 11:46 am Post subject: high temp cable ties |
Since my original post has been quoted on several of the replies in this
thread, I want to clear up a couple of things:
1) I agreed with the the person to whom I replied that adel clamps are
the preferred way to secure item to the engine mount tubes. I have
several adel clamps in my engine installation.
2) I disagree with the assertion that the use of cable ties will always
doom your engine mount to certain damage. Mine and the experience of
many other builders would invalidate this position.
Our engine compartments are monitored much more closely than many
certificated planes and we have ample opportunity to catch problems
before they become problems. If you have used cable ties to attach
wiring to the mount, then replacing them with adel clamps would
certainly be in keeping with certificated practice. But if the ties
remain in place, just keep an eye on them and replace them if/when you
see anything that bothers you.
Common sense rules.
Sam Buchanan
bicyclop(at)pacbell.net Guest
Posted: Thu Sep 20, 2007 1:38 pm Post subject: high temp cable ties |
On the other hand, I have seen damage on our 6a caused by cable ties.
Most places, it just wore through the paint. Other places, it did some
some damage to the metal. We still have some cable ties, but now they
have tape or rubber hose between them and the engine mount. I highly
recommend protecting the engine mount from cable ties and any other
possible cause of chafing. Even if the metal isn't damaged, it is
unprotected from corrosion unless you chase it down, prime and paint it.
Pax,
Ed Holyoke
Sam Buchanan wrote:
this thread, I want to clear up a couple of things:
always doom your engine mount to certain damage. Mine and the
experience of many other builders would invalidate this position.
Common sense rules.
Sam Buchanan
Posted: Thu Sep 20, 2007 2:00 pm Post subject: high temp cable ties |
Good grief......now my post to clear up how I was originally misquoted
has been misquoted.........
Guess I will just have to go hang myself with some oil-soaked, abraded
nylon cable ties.....
Sam Buchanan
Ed wrote:
Pax,
Ed Holyoke
> Common sense rules.
> Sam Buchanan
