David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Mon Sep 17, 2007 1:53 pm Post subject: Gap Seal |
Then there is this:
http://www.ntsb.gov/NTSB/brief.asp?ev_id=20001212X19633&key=1
DVD
On 9/15/07, ElleryWeld(at)aol.com (ElleryWeld(at)aol.com) <ElleryWeld(at)aol.com (ElleryWeld(at)aol.com)> wrote: | Quote: | REALLY its not a big deal Flying without the gap seal at least in my Firestar it just makes it a convertible top
There is no difference in how it fly's with or without it
Ellery in Maine
ô¿ô - "As pilots we are special, unique, a rare breed, passionate, and generally somewhat odd." ~ Dave Wiley [quote][b]
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
flymichigan(at)comcast.ne Guest
Posted: Mon Sep 17, 2007 3:33 pm Post subject: Gap Seal |
jim
Posted: Mon Sep 17, 2007 3:37 pm Post subject: Gap Seal |
When I got my Firefly it did not have a gap seal. I considered putting
one on but I'm 6-01 and I think it would make it more difficult to get in
and out of the Firefly.
_________________ Jim
N. Idaho |
d-m-hague(at)comcast.net Guest
Posted: Mon Sep 17, 2007 4:21 pm Post subject: Gap Seal |
OK, with all the talk about how important the center section gap seal is on
the later birds, how 'bout the Ultrastar? Mine didn't come with one, the
previous owner said it made little or no difference, after it ripped he
never replaced it, but he only flew the plane a few times.
-Dana
Every election, Mickey Mouse looks better and better as President.
Posted: Mon Sep 17, 2007 4:54 pm Post subject: Gap Seal |
| Quote: | OK, with all the talk about how important the center section gap seal is
on the later birds, how 'bout the Ultrastar?
-Dana
Dana:
My own personal experience came as a shock when I learned, in the air, that
flying an Ultrastar without the gap seal seriously degraded performance of
the aircraft.
Always in a hurry to get stuff done so I could fly, back in the early days,
I decided to do a quick test flight around the patch without the US gap
seal. Soon as I was in the air I realized it was there for more than
aesthetics.
The original nylon gap seal Old Kolb provided were quickly destroyed by UV.
I found that normal roofing valley aluminum made an excellent gap seal.
Welded a couple tabs fore and aft, top and bottom, to attach with tinnerman
nuts. Worked great.
Later on decided I should use "real" aircraft material, so bought an
expensive roll of 2024 aluminum. In a matter of hours the 2024 started
cracking and splitting. The cheap, soft hardware store variety worked much
better.
Some low time Kolb pilots don't know the difference between a good flying
Kolb and one that flies like a dog.
_________________ John Hauck
Titus, Alabama |
Posted: Mon Sep 17, 2007 5:11 pm Post subject: Gap Seal |
At 08:53 PM 9/17/2007, John Hauck wrote:
that flying an Ultrastar without the gap seal seriously degraded
performance of the aircraft.
John, degraded how?
-Dana
In England, the cops say, 'Halt or I'll say halt again!'
Posted: Mon Sep 17, 2007 5:40 pm Post subject: Gap Seal |
| Quote: | John, degraded how?
-Dana
Dana:
Performance of the Ultrastar is seriously degraded. You know, like it takes
a heck of a lot more power to make the airplane fly. There is a tremendous
amount of drag on the airplane. In addition, it loses lift and degrades the
controls. Typically, what happens when the airflow is seriously screwed up
in and around the airplane.
That is my experience with the Ultrastar circa 1984 or 85. Maybe all that
has changed by now.
My 1986 Firestar also suffered from the same characteristics when flown
without the gap seal. Again, that was a long time ago, like 1986 ot 87.
Titus, Alabama |
Richard Pike
Posted: Mon Sep 17, 2007 6:20 pm Post subject: Gap Seal |
I'll second what John H says. Number of years ago watched a Firestar take
off and was about 50' up when the gap seal came loose. The pilot was good,
but he almost lost it getting it down alongside the runway. Scared him
badly, said it wanted to quit flying on him.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
ElleryWeld(at)aol.com Guest
Posted: Mon Sep 17, 2007 7:00 pm Post subject: Gap Seal |
The pilot's failure to maintain airspeed, which resulted in a stall
I think this would be the only reason PILOT error forgetting to fly the plane after he had lost the gap seal
I know this first hand as I had one fly off while doing stalls one day I cant believe it didnt get in the prop but the plane flew as good without it as it did with it
and I have flown it many times without it and I havent wrecked it yet because I never forget to fly the plane
Ellery in Maine
"Mainiac"
**************************************< [quote][b]
jindoguy(at)gmail.com Guest
Posted: Mon Sep 17, 2007 7:14 pm Post subject: Gap Seal |
Dana, John et al, The explanation for the degraded performance of a wing without a gap seal is simple. With a gap seal, you have two wing tip vortices, without, you have four. On top of that the two inner vortices interfere with each other by spinning in opposite directions.
The two wings flying side by side have half the aspect ratio of the full wing so a much larger percentage of each wing is involved in spanwise flow. The net result is not just more than twice the induced drag, but a significant reduction in lift, too.
Rick
On 9/17/07, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:[quote] --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Posted: Mon Sep 17, 2007 7:15 pm Post subject: Re: Gap Seal |
John H says: "Some low time Kolb pilots don't know the difference between a good flying
Kolb and one that flies like a dog. "
...... I know how mine flies, but I do not have anything to compare it to; I may be flying a "dog".
I am a low time Kolb pilot and I only have my Kolb to judge flight characteristics from.
I built a Gap Seal from lexan. The top is nearly a complete seal except for the area around the the engine mount. There is no TOP side coverage on a section about the size of the engine mounting plate platform.
I have a BRS on a shelf under the seal and I fabricated a door that will allow the chute to pass through if ever needed. It is held in place with a aluminum hinge and Velcro. I have been experimenting with the amount of Velcro needed to keep it closed during flight, but not enough to slow the chute deployment. It has partially opened in a corner during flight, I am looking at alternate ways to hold it in place.
The bottom is OPEN. The leading edge is formed aluminum and that extends about 12" back, but then it is open all the way to the rear.
My question is about the open bottom. I saw it quite a challenge to build the bottom section around the BRS, and it got harder the further back I went. I figured the the top was the most important and I could skip the bottom.
Does an open bottom gap seal = a "dog" Kolb?
The pictures are some I made when I was fitting up everything. The BRS pack is missing plus I had not finished the Velcro around the trap door.
What do you think Kolb fliers?
55.33 KB |
1672 Time(s) |
48.42 KB |
1562 Time(s) |
_________________ Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot |
Posted: Mon Sep 17, 2007 7:39 pm Post subject: Gap Seal |
Hi Ellery:
Never flew a FSII without the gap seal. Can only speak for the original FS and US, which in my opinion flew much better than any FSII I have flown over the years.
I was very fortunate, last june, while at Homer Kolb's, to get to fly the 1985 Oshkosh Grand Champion Firestar powered with a dual carb 503. Mine had a 40 hp 447, which Homer would not sell me with the kit. Kit came with a 35 hp 377. Homer's FS was a rocket ship, very light and powerful.
| Quote: | the plane flew as good without it as it did with it
Ellery in Maine
| [quote][b]
Titus, Alabama |
pj.ladd(at)btinternet.com Guest
Posted: Tue Sep 18, 2007 4:15 am Post subject: Gap Seal |
Hi,
re gap seals.
On my Challenger after a few times taking the gap seal off to oil the
control joints and check connections on DI and putting it on again I gave up
and never bothered to use it again. Never seemed to make a detectable
difference but then maybe I just ham handed.
The gap between the wingroots was about 10 inches.
Pat
Posted: Tue Sep 18, 2007 6:14 am Post subject: Gap Seal |
I Fly an Original Firestar but I have flown the Firefly and the Mk3Xtra I think they all fly real similar to one another
the original Firestar and Firefly you have to put left Rudder input with quick excelleration and the Mk3 Xtra You have to put a whole boot full of Right Rudder on take off because of Prop rotation
Ellery in Maine
possums(at)bellsouth.net Guest
Posted: Tue Sep 18, 2007 11:06 am Post subject: Gap Seal |
At 11:15 PM 9/17/2007, you wrote:
The bottom on mine is open and just slides into the tracks on the end of
the wings, held by two screws on the front. Flys fine.
It's not as wide as a Mark III gap seal would be, so I don't know about those.
45.28 KB |
1597 Time(s) |
77.68 KB |
1490 Time(s) |
49.5 KB |
1463 Time(s) |
19 KB |
1479 Time(s) |
Posted: Tue Sep 18, 2007 7:39 pm Post subject: Gap Seal |
At 11:12 PM 9/17/2007, Richard Girard wrote:
| Quote: | ...With a gap seal, you have two wing tip vortices, without, you have
I don't think you'd have twice the induced drag, the vortices going in
opposite direction would tend to cancel each other out, somewhat... but I
can see that it still could be signfiicant. More significant, perhaps, may
be the disturbance of the airflow over the tail and/or through the prop
(the latter may be more significant on the low boom Kolbs than on my US
with its prop completely under the wing).
What's odd is the number of people who say it makes no difference at all?
Anyway, I figure it's worth putting it on... once I get familiar with the
plane I might try it without it to see the difference.
My thought is to use .040" clear vinyl sheet, velcroed to the wings and
wrapping all the way around, and secured with cords where it breaks for the
cage structure. Quick and easy, and since it wraps all the way around and
attaches to itself, no chance of it coming off and going through the
prop. Comments?
-Dana
"Calvin, we will not have an anatomically correct snowman!"
lcottrell
Posted: Tue Sep 18, 2007 7:51 pm Post subject: Gap Seal |
| Quote: | What's odd is the number of people who say it makes no difference at all?
I find it odd that people say that it makes no difference as well. I have
flown Mark III with gap seal ( mine) and another when I was getting my
Ultralight pilots lic with no gap seal and the one with no seal flew like a
dog. It was a bear to land, stall was about 60 or more with flaps. I
attempted to try to convince the guy to put one on. He would not. I believe
it is scrap parts now.
Larry C
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Wed Sep 19, 2007 6:25 am Post subject: Gap Seal |
In a message dated 9/18/2007 11:52:17 P.M. Eastern Daylight Time, lcottrell(at)fmtcblue.com writes:
Larry C
I just crow hopped my firestar KX after 2 1/2 years of nonflying and had to rediscover how to swim again..... and I did not have the gap seal on yet. Took 55mph to get off the ground (but I had gained a little weight too, squirrelled to the right...probably p factor....with full left rudder ....but it went right anyway and gradually veered left....just before I hit the tree in front of me....soooooo I didn't hit the tree afterall. It finally became controllable and I took off, going very fast...Hall was pegged at 55.....backed off on throttle, more n more n more and it finally started to come down.....it was floating for sure.... and I landed several times as the speed was still high.........sooooo busy didn't care to look at Hall.
Lotsa squirrels to that flight..............rest assured, my next attempt will be WITH gapseal.
George Randolph
Firestar driver in the Villages, florida.... testing at Richard Swiderski's house
See what's new at AOL.com and Make AOL Your Homepage.
_________________ George Randolph
Firestar driver, The Villages, fl |
GeoR38
Posted: Wed Sep 19, 2007 1:54 pm Post subject: Gap Seal |
Larry C
I just crow hopped my "by George" Firestar KX without a gap seal and it was learning how to swim all over again. I really didn't think the gap seal could make that much difference ....and I have not flown the puppy for 2 years,
by0ung(at)brigham.net Guest
Posted: Thu Sep 20, 2007 6:39 am Post subject: gap seal |
Dana
Or you could make it permanent, bolt it on and forget it.
Boyd
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>
prop. Comments?
-Dana
