hdoud(at)satx.rr.com Guest
Posted: Sat Sep 15, 2007 1:59 pm Post subject: Bunches of stuff |
Many thanks to all of you Kitfoxers who responded either to me directly or to the list concerning my question as to why we Kitfoxers put the firewall blanket on the engine side, instead of on the cabin side as do GA aircraft manufacturers. A large number of builders who responded, have eiher done away with the blanket or have installed it on the cabin side of the firewall, which makes sense to this old fart.
Now to another subject. I guess everyone who messes with car and airplane engines have heard of Marvel Mystery Oil. I'v used it off and on for 50 years.
I bought an ATV sometime back and through short trip useage and many starts, the spark plug was carboning up and fouling. Most of my use with Marvel, was in the engine oil, for break-ins and hard useage. On the container Marvel is also suggested for the fuel, for upper end lube and cleaning of the cylinders.
I tried it on the ATV and for a coupla weeks, using the recommended amount in the fuel and it worked super. The plug cleaned up, starts were easier and it idled better........But, I started getting a gasoline puddle under my ATV, coming out of the carb overflow.
Bunches of work, but I pulled the carb, looked at the float needle and it had turned gummy and was leaking. So I installed a new needle and put the works back together. A week or so later, I started getting a large fuel puddle under the ATV again.
Earlier, it had worked so well, before getting fuel leakage under the ATV, I also had put in in my gas for the 582 on my Kitfox. Worked great there too, keeping clean plugs and smooth idling.
I hadn't had the plane out in a coupla weeks and when I saw the gas puddle under the ATV, I hobbled out to the folded wing, mini hanger, checked the carbs for leaking and sure enough, there was a large gas puddle on the floor under the engine. I was mixing the plane gas with the premix oil and adding the suggested amount of Marvel Mystery Oil.
I pulled both carbs and checked the rubber tips on the float needles and they were deteriorating.
Not being a real fast thinker, I guess, I cussed to myself, about the poor quality of tips on the needle valves and how things just weren't up to the standards of earlier years.
I replaced the Bing needles, and made no changes in the Marvel oil as it was sure working good in cleaning up the combustion chanmbers.
A week or so later, I had another gas puddle under the plane and the ATV was still leaking gas. Finally the gray mater lit up and I drained the fuel tanks on both the plane and the ATV and again, replaced the float needles on the 2 engines. After I'd used up all the bad words that I learned from all the bad people I knew, I hadda start making up a whole lot of new ones, that I'd like to pass on.... But I can't spell 'em.
Any way, I changed the 582 over to oil injection and am using the Marvel in the oil injection system and quit putting Marvel in the ATV. It's been several months now and no more fuel leakage from either engine.
It seems that the Marvel is a good product, if it not used where it can come in contact with the rubber tips they are now using on the float needles. (they all used to be brass tips) Marvel sure keeps things cleaned up and seems to work great in the 4 cycle oil engines, But beware of mixing with gasoline in the fuel tanks.
My ATV still fouls plugs, so I buy them buy the dozen. If anyon's interested in some old fouled plugs to play with, I have some real cheap.
Herbert Doud
Kitfox IV/582
New Braunfels, Tx
dave
Posted: Sat Sep 15, 2007 2:06 pm Post subject: Re: Bunches of stuff |
How many hours do you get out of your 582 plugs by using Marvel oil ?
how do you know your 582 is clean inside ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
jcorner(at)shaw.ca Guest
Posted: Sun Sep 16, 2007 6:35 am Post subject: Bunches of stuff |
Herbert.... I am thinking of adding Marvel to my 582 operation, are you using straight Marvel in the injection system or are you adding it to your regular injection oil? If so in what percentage?
Jim
Kitfox 2, 582,
1100+ hrs
Calgary AB
On 15-Sep-07, at 3:59 PM, Herbert Doud wrote:
dave
Posted: Sun Sep 16, 2007 6:45 am Post subject: Re: Bunches of stuff |
Can i ask why would you want to add it ?
I run easy past 300 hours using Bombardier XPS mineral oil and have no reason to need it so far ?
andynfultz(at)bellsouth.n Guest
Posted: Sun Sep 16, 2007 4:28 pm Post subject: Bunches of stuff |
If the Mystery Oil is causing damage to the needle tips, I can't help but wonder what it's doing to the inside of your fuel lines and or oil injection lines?
Andy F.
[quote] --
Float Flyr
Posted: Mon Sep 17, 2007 4:43 am Post subject: Bunches of stuff |
From what I've read MMO is mostly Stoddard solvent (Varisol) and lard. I have no idea what the lard does for the recipe but I know I don't want Varisol soaking the seals in the base of my engine. I might consider using the stuff for the last ten hours or so before an engine tear down for new seals just to clean things up a bit for inspection. sorry guys but I'm with the crowd that is NOT in favour of additives to gas or oil for planes.
If you are getting too much carbon in your engine and your oil ratios are correct then you are using the wrong brand of oil. Bombardier, the manufacturer's, oil, Pennzoil air-cooled and "El Cheapo" WallyWorld oil all seem to work well according to the reports from this and other lists.
[img]cid:825512212(at)17092007-2356[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
487 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
