Pilot operating handbook for an UltraStar
KolbFlyerJim(at)aol.com
PostPosted: Sun Sep 16, 2007 6:40 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Hi all Jim here
Dose anyone have a pilot operating handbook For an UltraStar ????
THANKS Jim
See what's new atblank">Make AOL Your Homepage.
worrybear(at)verizon.net
PostPosted: Sun Sep 16, 2007 9:39 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Jim, The builders manual had a section on flying the Ultrastar, but there was no operating handbook that I am aware of. Are you N numbering your Ultrastar?
Dan Walter
Palmyra, PA.
Ultrastar, 177 hours, engine still not fixed.
Do not Archive
[quote] [b]
PostPosted: Sun Sep 16, 2007 10:53 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Thanks Dan
I have the build manual dosnt give vne best rate of climb,Best angle of climb,or any other info i need. Yes I have N numbered my UltraStar. from the looks of it I Have the only N numbered UltraStar in the country.
Thanks Jim VanGarsse
See whatarget="_blank">Make AOL Your Homepage.
PostPosted: Sun Sep 16, 2007 10:56 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Sorry I was WRONG about the only n numbered UltraStar
Jim
See what's new at AOL.com and .
PostPosted: Sun Sep 16, 2007 11:04 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Jim V:
Back in 1984, when I built my Ultrastar, there was not a lot of info on the aircraft. However, it was plenty to build and fly the airplane. There were no V speeds in the builders manual. Homer said to take the Ultrastar at least 1,000 feet above the ground and check the stall speed. Then you were ready to make your first landing, carrying about 5 or 10 mph over stall.
PostPosted: Sun Sep 16, 2007 11:34 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Thanks John
Jim Here. I have put over 200 hrs on my UltraStar in 2 seasons i just need the info for a manual for the UltraStar for an airworthyness cert,
Thanks Jim
planecrazzzy
PostPosted: Sun Sep 16, 2007 12:02 pm    Post subject: Re: Pilot operating handbook for an UltraStar Reply with quote
If you look in AC NO: 90-89A
Amateur-built aircraft and Ultralight Flight Testing Handbook
It tells you how to figure all your "V" speeds ( except Vne )
Somebody had an address where you could look it up on line...
Gotta Fly...
Mike & "Jaz" in MN
My FSII V speeds
 Filesize:  1.76 MB
 Viewed:  242 Time(s)
PostPosted: Sun Sep 16, 2007 12:41 pm    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Jim:
In that case, the numbers are really insignificant except to fill in the blanks.
I'd come up with the best I could.
[quote] Jim Here. I have put over 200 hrs on my UltraStar in 2 seasons i just need the info for a manual for the UltraStar for an airworthyness cert,
Thanks Jim
PostPosted: Sun Sep 16, 2007 4:55 pm    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Thanks Mike & Jaz
See what's new="_blank">Make AOL Your Homepage.
d-m-hague(at)comcast.net
PostPosted: Mon Sep 17, 2007 10:15 pm    Post subject: Pilot operating handbook for an UltraStar Reply with quote
At 02:50 PM 9/16/2007, KolbFlyerJim(at)aol.com wrote:
Thanks Dan
Why are you N-numbering an Ultrastar?
-Dana
A common mistake that people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete fools.
PostPosted: Tue Sep 18, 2007 12:25 am    Post subject: Pilot operating handbook for an UltraStar Reply with quote
Hi Dana
IM N numbering because I have more than 5 gallons of fuel and over weight
Thanks Jim
