LarryRosen
Posted: Sat Sep 15, 2007 6:54 pm Post subject: Antenna placement and adequate ground plane or ground wire |
Have you considered mounting them under the cabin top, inside the
Accuracy Avionics overhead console? I know there are two layers of
fiberglass and a core, but that shouldn't interfere with the signals.
(in my non expert opinion). Any thoughts?
Larry Rosen
Deems Davis wrote:
With all this talk about antennas, I've got a question for the group.
I need to mount a XM weather antenna and an additional GPS antenna. I
already have the primary GPS mounted on the top of the tail cone aft
of the cabin top intersection. I am not keen on placing them on the
cabin top, primarily for aesthetics, so I'm planning on mounting them
side by side on a shelf on the firewall. This will make installation
and the cabling easier. The antennas don't require a ground plane as
best as I can tell. Mounting them in this location will make for a
shorter cable run and an easier installation. Anybody gone this route?
Feedback? I think I recall that Checkoway mounted one or more antennas
in this manner.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
