kim.forest(at)surewest.ne Guest
Posted: Fri Sep 14, 2007 1:39 pm Post subject: Elevator Center Channel |
Dear Fellow 601XL Builders:
Anyone working on the elevator use caution. Maybe it will be obvious to you, but I missed it. Before drilling your rivet line in the bottom of the elevator (into the Elevator Center Channel/6T3-2), make sure you compensate for this part being 20mm closer to the front edge of the elevator. I miss drilled two holes that ended up 10mm aft and into the curve of 6T3-2. Luckily, I was able to order a new part without having to do anything major.... just another speed bump, I guess. ARRRGGHHH!
Forest K., Rocklin, CA
Rudder/Horizontal Stab complete
Working on elevator/Wing Kit in garage...
N601FK (reserved)
