Strut fairing questions.
Goto page 1, 2  Next
occom
PostPosted: Sat May 05, 2007 10:29 am    Post subject: Strut fairing questions. Reply with quote
I have been in touch with Kitfox and John advises that they have a PVc fairing kit. Has anyone used this and do you have pictures? The original fairings from the damaged struts was a wood-like material that is very hard and cannot be removed. I can't imagine that PVC would be as strong. Any ideas??
Dave Goddard- Mod IV 1050/582
lcfitt(at)sbcglobal.net
PostPosted: Sat May 05, 2007 11:59 am    Post subject: Strut fairing questions. Reply with quote
Dave,
I have the PVC fairings on my airplane. They are tough, I don't worry if
someone is helping move the airplane by grabbing the fairing covered lift
struts.
I think the most common argument against them is that they are relatively
heavy vs. a light weight wood.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 850 hrs.
Guy Buchanan
I did not install mine, but I give them a bulletproof rating. They're
certainly a lot harder than my head!
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Lynn Matteson
PostPosted: Sat May 05, 2007 12:49 pm    Post subject: Strut fairing questions. Reply with quote
"Strong like bull" to quote some lame B-movie that I saw years ago. I
installed the PVC fairings that were produced back in about 1994 or
so, and they are tough. I covered mine with Polyfiber cloth, and
painted with Polytone just like any fabric-covered part. I have some
pictures.
Lynn Matteson
Grass Lake, Michigan
flying w/275+ hrs
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
kitfoxmike
PostPosted: Sat May 05, 2007 2:56 pm    Post subject: Re: Strut fairing questions. Reply with quote
I have them on my plane, I left them alone, no paint, no glue, just snapped them on and away I went. about 400 hrs on them, they look great. When I removed the wood off one side I weighed the wood and then weighed the plastic, pretty much the same.
Joel
PostPosted: Sun May 06, 2007 9:01 am    Post subject: Re: Strut fairing questions. Reply with quote
I have been considering strut fairings for my model 5 and am wondering how to make sure that they are properly aligned with the slip stream. Do you think that they are sturdy enough for use on a float plane where folks on the dock often try to help by grabbing the lift struts?
Joel Mapes
Bremerton, WA
38 hours into phase one, currently on tube gear
Way too much fun.
Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs
Guy Buchanan
PostPosted: Sun May 06, 2007 5:00 pm    Post subject: Strut fairing questions. Reply with quote
slip stream.
Mine are aligned in the plane of the struts. They will be very close
to aligned, or possibly have a few degree angle of attack.
The PVC ones are definitely strong enough.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
smokey_bear_40220(at)yaho
PostPosted: Sun May 06, 2007 6:27 pm    Post subject: Strut fairing questions. Reply with quote
Hi Joel,
Alignment: Michel in Norway, and a friend of his from
France, helped me design super slick fairings for my
Fox. They used X-Plane to do the modeling of the
struts for me. What we found was interesting.
The fairings were stalled durning normal climb and
approach speed/AOA. When below the stall AOA, they
could lift up to 40 lbs. This made them speed up the
plane and lift more than their own weight too. A
double plus. But for steap climbs, they didn't help
so much.
We worked hard to come up with a design that didn't
stall during normal climb so that the extra lift and
reduced drag were still there. That part gets a bit
complex. Of course I had to learn not to overshoot
the landings again, because it worked. And I got over
10 mph more speed from them in cruise.
For the normal strut fairings, I would suggest taking
a picture of your wing against the horizon during
cruise flight. Blow the pic up enough so you can
measure the angle of the spreader rod between the
strut tops and horizon, and the angle of your jury
strut spreader to the horizon. With those 2 angles,
you can align the fairings to the horizon as a zero
incidence for your fairings.
But if your spreader bar and horizontal jury bar are
nose down, put your fairings a bit nose down too. 2
degrees max nose down to the horizon. This is
probably because your cruise AOA is a bit nose down
with the KF wing developing too much lift. A little
nose down on the fairings will keep them from stalling
when more nose up, as in climb, and also might take a
little of that extra lift in cruise away making you
fly a tad more level.
Just my opinion.
Kurt Schrader
S-5 NSI turbo w/CAP 140 prop
Back in Florida
Joel Mapes
Bremerton, WA
Way too much fun.
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
kitfoxmike
PostPosted: Mon May 07, 2007 8:02 am    Post subject: Re: Strut fairing questions. Reply with quote
How to center the struts. Well if you installed them the way I did (just snap them on) you don't have to worry about it, they will move to the slip stream automatically. I did a test this morning and put down angle on the strut fairings. By the time I hit level flight they readjusted themselves to level. Another note if you want to glue them is to put them to the bar that goes between the front and back at the wing connections, at least I have one on my 4.
Michel
PostPosted: Mon May 07, 2007 11:39 am    Post subject: Strut fairing questions. Reply with quote
I am glad it could help, Kurt. Of course, using a simulator to
calculate real life aviation should always be taken with a grain of
salt but apparently it was effective in your case.
Michel Verheughe
Norway
Kitfox3 - Jabiru
Kitfox 3 - Jabiru 2200
arholland
PostPosted: Thu Sep 13, 2007 4:04 am    Post subject: Re: Strut fairing questions. Reply with quote
I am looking for strut fairings for my kitfox as well. Does Kitfox aircraft have them listed on their website somewhere?
One person in the email chain said they just snapped them on, not covering, no paint, nothing. Where did you get the snap on fairings?
Allen Holland
Munford, TN
occom
PostPosted: Thu Sep 13, 2007 4:53 am    Post subject: Strut fairing questions. Reply with quote
I'm sure John M will answer this with the definitve answer but I think they
now or shortly will have a similar to original wood fairing kit that will
require glueing and covering as the originals did. I will want them sooner
or later. The really great thing about this from my perpspective is that
they can be cut to shorter lengths and shipped. Try that with a one piece
plastic fairing
john(at)leptron.com
PostPosted: Thu Sep 13, 2007 5:21 am    Post subject: Strut fairing questions. Reply with quote
Dave,
I will need to get out my paperwork, but many of us did some speed checks
when we were playing with fairings. The wood kit supplied by kitfox was an
improvement of about 4.5 mph. When we went to the snap on fairings that
kitfox, started supplying our improvement over stock round tube was 8 to 9
miles better. It actually made the whole plane feel different. I used to fly
the plane full throttle down to the surface and it would slow down and land
in a hurry, now I have to think about how to slow it down.
John Oakley
dave.wahlquist(at)ics.uwe
PostPosted: Thu Sep 13, 2007 5:51 am    Post subject: Strut fairing questions. Reply with quote
Does anyone have experience with removing the wood and fabric fairings?
How well are they glued on?
I assume you don't want to do any scraping or grinding on the struts.
Maybe if you are going to the snap on ones you just need to clean up
well enough to allow the new ones to slip on and not bind or scrape?
Dave Wahlquist
Model 3 582
Marshall,WI
dave
PostPosted: Thu Sep 13, 2007 6:10 am    Post subject: Re: Strut fairing questions. Reply with quote
John, what is the difference in chord of the fairings that helped gain that extra speed ?
What speeds do you get wide open straight and level ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Tom Jones
PostPosted: Thu Sep 13, 2007 6:26 am    Post subject: Re: Strut fairing questions. Reply with quote
I have not removed fairing from the struts but have removed lots of other parts glued on. The wood fairing are attached with 3M epoxy. It will soften with heat from a heat gun. You can use a plastic or wood scraper to remove the residual epoxy from the struts.
Tom Jones
Classic IV
Ellensburg, WA
jdmcbean(at)kitfoxaircraf
PostPosted: Thu Sep 13, 2007 11:38 am    Post subject: Strut fairing questions. Reply with quote
Regarding lift strut fairings...
Some of you will remember the original wood style fairings.. The install was
fairly simple and very easy to work with even after the aircraft is flying.
The PVC Fairings were introduced and while they offered a more true airfoil
shape they also added significant weight. They are also very time consuming
to install nicely as they have a 2 ridges on each side of them that should
be sanded down. The aluminum cuff on the end also created some challenges.
That being said we have chosen to look back and re-introduce the wood...
although a little different. We have chosen Balsa as the medium to use for
several reasons.. believe it or not strength is one, ease of install and
sanding, and the other is weight. The 2 lift struts weighed in at almost
14 lbs difference from the PVC to the Balsa and the Balsa is stronger.
Speed differences between the 2 is negligible. The new Balsa fairings
maintain the correct proportions to the diameter of the tube. We have seen
and had reported from 8 to 14 mph difference with either style.
The Strut fairings will also include the horizontal lift strut pieces as
well for the single horizontal support tubes.
We have not introduced these officially yet as we need to develop the
installation instructions for them.. However, they are ordered and should be
in stock hopefully by months end.
Installation is pretty straight forward. Bond, shape, seal, cover &
paint... Smile
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
 Filesize:  391.57 KB
 Viewed:  740 Time(s)
pwmac(at)sisna.com
PostPosted: Thu Sep 13, 2007 8:59 pm    Post subject: Strut fairing questions. Reply with quote
John,
How close in the balsa compared to the old pine/fir ones used previously?
It looks like it might have a slightly longer chord?
Thanks, Paul
At 01:35 PM 9/13/2007, you wrote:
[quote]Regarding lift strut fairings...
paint... Smile
Fly Safe !!
John & Debra McBean
208.337.5111
hflynn46531(at)YAHOO.COM
PostPosted: Fri Sep 14, 2007 3:26 am    Post subject: Strut fairing questions. Reply with quote
In 1995 when I built my S5 I didn't use the pvc fairings. Instead I ordered balsa wood from Aircraft Spruce and used that. It was vary easy to work with and shape and vary strong and light weight. I covered them with fabric and painted them. They turned out so nice that people thought they were metal ones. They look the same today as they did when I fiinshed them.
jdmcbean <jdmcbean(at)kitfoxaircraft.com> wrote: [quote]Regarding lift strut fairings...
paint... Smile
Fly Safe !!
John & Debra McBean
208.337.5111
PostPosted: Fri Sep 14, 2007 8:48 am    Post subject: Strut fairing questions. Reply with quote
Paul,
They are a longer chord... There is an aerodynamic rule of thumb for
streamline shapes and we have tried to stay close to that.
Fly Safe !!
John & Debra McBean
208.337.5111
Goto page 1, 2  Next
Page 1 of 2
