sarg314(at)comcast.net Guest
Posted: Sun Sep 09, 2007 2:34 pm Post subject: VM1000 manifold pressure and CHT sensors |
I have a VM1000 that has sat in a box for 6 years. VisionMicro (=JPI)
tells me they have an inventory of VM1000 spare parts but are not going
to maintain it any more. When those parts are gone, they're gone forever.
I finally got the VM1000 installed and powered up. It was flaky until I
reseated the 4 socketted DIP components in the main control box. I
attribute that to sitting unused for so long (and maybe cheap sockets).
Seems to come up reliably now, but shows 2 problems. The CHT3 is
consistently 15 - 20 deg. low and the manifold pressure is about 2.5
inches low. It reads 27.3 when the barometric pressure is 30.00. The
M.P. sensor is a bellows type and can get stuck, so the tech at Vision
Micro recommended I just run the engine a bit. Well, I'm a few months
away from being able to do that and their inventory of spare parts is
only getting smaller, so rather than wait, I hooked up a hose to it and
actually blew into it gently. I was able to make it change +- 1 inch,
so I don't think I did it any violence. But it still returns to 27.3 in.
when I leave it be.
There must be lots of people out there with experience with these
things. Should I spend the $250 to buy a new MP sensor now, or wait
until the engine is actually running and hope that all the vibration and
pressure swings will get the thing working, OR that Vision Micro will
still have sensors on the shelf?
Since the CHT is a thermocouple, it is as likely that the failure is the
amplifier circuit it is connected to as it is a bad thermocouple. I
don't know anything about the innards of these things. What is the
typical failure mode for a VM1000 temp. sensor? Is it the sensor itself
or the circuitry reading it? All the other thermo probes seem OK.
Tom Sargent, RV-6A, electrical system
Vanremog(at)aol.com Guest
Posted: Sun Sep 09, 2007 2:51 pm Post subject: VM1000 manifold pressure and CHT sensors |
In a message dated 9/9/2007 3:36:20 P.M. Pacific Daylight Time, sarg314(at)comcast.net writes:
| Quote: | Since the CHT is a thermocouple, it is as likely that the failure is the
or the circuitry reading it? |
Easy to swap the TC out with one of the others and see if the problem moves with it.
Regarding the MP sender, it seems a stretch to me that benign storage could cause it to drift in this fashion to that degree. I would try to find someone else out there in RV builder land with another identical sender that you could swap out to see if this is the culprit. Either that or go thru all of the printed troubleshooting tips that VM gives out to try and pinpoint the problem (low voltage to the sender, wrong output, high resistance at the connections, bum wire).
N1GV (RV-6A, Flying 865hrs, O-360-A1A, C/S, Silicon Valley)
Make AOL Your Homepage.
Posted: Sun Sep 09, 2007 3:12 pm Post subject: VM1000 manifold pressure and CHT sensors |
Thanks, I guess I'll have to swap CHT sensors. I don't like handling
those things - I keep expecting that stiff T.C. wire to fatigue and break.
I was looking for a "trouble shooting" section in the manual, but mine
doesn't have one. I didn't get anything else with the unit and their
web page has no downloads. How did you get yours?
Vanremog(at)aol.com wrote:
| Quote: | Either that or go thru all of the printed troubleshooting tips that VM
*N1GV (RV-6A, Flying 865hrs, O-360-A1A, C/S, Silicon Valley)*
n5lp(at)warpdriveonline.c Guest
Posted: Sun Sep 09, 2007 3:13 pm Post subject: VM1000 manifold pressure and CHT sensors |
On Sep 9, 2007, at 4:33 PM, sarg314 wrote:
(=JPI) tells me they have an inventory of VM1000 spare parts but
are not going to maintain it any more. When those parts are gone,
until I reseated the 4 socketted DIP components in the main control
box. I attribute that to sitting unused for so long (and maybe
cheap sockets). Seems to come up reliably now, but shows 2
problems. The CHT3 is consistently 15 - 20 deg. low and the
manifold pressure is about 2.5 inches low. It reads 27.3 when the
What do you mean by when the pressure is 30.00, the altimeter
setting? What is your altitude? If your elevation is around 2,700
feet the MP is probably correct.
Larry Pardue
Carlsbad, NM
khorton01(at)rogers.com Guest
Posted: Sun Sep 09, 2007 3:35 pm Post subject: VM1000 manifold pressure and CHT sensors |
On 9 Sep 2007, at 18:33, sarg314 wrote:
... the manifold pressure is about 2.5 inches low. It reads 27.3
when the barometric pressure is 30.00. The M.P. sensor is a
bellows type and can get stuck, so the tech at Vision Micro
is only getting smaller, so rather than wait, I hooked up a hose to
it and actually blew into it gently. I was able to make it change
+- 1 inch, so I don't think I did it any violence. But it still
returns to 27.3 in. when I leave it be.
What is the source of the barometric pressure you are using to
compare the MP indication against? Is it really the true barometric
pressure, or is it possible that it is sea level corrected barometric
pressure? What is the elevation of your shop, roughly speaking?
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Sun Sep 09, 2007 3:46 pm Post subject: VM1000 manifold pressure and CHT sensors |
Larry:
I am at 2200 ft. altitude. The 30.00 is what I'd uses as the
altimeter setting. I didn't think 2200 ft would account for 2.7 in. of
pressure difference, but I admit I was just guessing.
Larry Pardue wrote:
| Quote: | What do you mean by when the pressure is 30.00, the altimeter
Larry Pardue
Carlsbad, NM
n616tb(at)btsapps.com Guest
Posted: Sun Sep 09, 2007 3:50 pm Post subject: VM1000 manifold pressure and CHT sensors |
Tom,
Is this already all installed in your airplane? I have an original VM1000
and if it wasn't installed I would drop it like a rock. It would be a hard
decision because of what I spent for the system, but I would change mine out
even now if the sensors were compatible with something else.
I had a bad DPU resulting in no oil pressure reading. I have been flying
with a mechanical oil pressure gauge installed under the dash for 10 months.
I finally got it taken care of but it took a lot including a flight to VM.
I would be very surprised if they had any spare parts at all. In fact I
would be very surprised how much longer they will even have parts.
JPI bought them out but they are kind of like little orphans stuck in a
little hanger in Texas with little to no facilities. My hangar at home is
better equipped than VM.
If it isn't installed, have you asked them about upgrading (actually
downgrading cost wise) to the VM1000c version? I would steer completely
away from VM but since you have it they might swap you for a VM1000C latest
version.
Anyway, just my thoughts. I am not happy with them and was very
un-impressed when I went to their facility. It actually wasn't a facility
at all.
[quote] --
Posted: Sun Sep 09, 2007 4:23 pm Post subject: VM1000 manifold pressure and CHT sensors |
The rough rule of thumb for lower altitudes is one inch per
thousand. The altimeter setting is an entirely different thing than
the true pressure.
Larry
On Sep 9, 2007, at 5:45 PM, sarg314 wrote:
Larry:
in. of pressure difference, but I admit I was just guessing.
> 2,700 feet the MP is probably correct.
> Larry Pardue
> Carlsbad, NM
Posted: Sun Sep 09, 2007 4:37 pm Post subject: VM1000 manifold pressure and CHT sensors |
There is a big difference between altimeter setting and barometric
pressure. At sea level they would be the same thing. If the
altimeter setting is 29.92, that just means that the barometric
pressure at that location is the same as the standard atmosphere
pressure for that elevation. The standard pressure for 2200 ft
elevation is 27.62 " HG, so your MP gauge should read somewhere
around that value, depending on whether the pressure of the day is
higher or lower than a standard atmosphere.
The altimeter setting is just a way to adjust the altimeter to
account for non standard pressure. 2200 ft elevation with an
altimeter setting of 30.00 gives a pressure altitude of 2127 ft, and
the standard pressure for that altitude is 27.69 inches of mercury.
So, the MP indication should have been 27.7, which isn't a huge
amount different from the 27.3 that you reported. You might have a
small error, but in my experience many MP gauges have errors of
around 0.5". HG.
Kevin Horton
On 9 Sep 2007, at 19:45, sarg314 wrote:
Larry:
> Larry Pardue
> Carlsbad, NM
Posted: Sun Sep 09, 2007 5:37 pm Post subject: VM1000 manifold pressure and CHT sensors |
Kevin:
That's awfully close. I'd better check this before I "fix" the MP
sensor. I guess I was shooting from the hip on that one.
Thanks.
Kevin Horton wrote:
Posted: Sun Sep 09, 2007 5:42 pm Post subject: VM1000 manifold pressure and CHT sensors |
Tim:
Thanks for relating your recent experiences. I'm afraid I'm
"married" to the thing at this point. It's fully installed. These
things seemed to be the way to go 5 or 10 years ago, but I guess they
are quite dated now. The JPI buy out certainly doesn't help.
Advice to other builders who aren't as far along as I am: Don't buy the
expensive, complicated electronic stuff until you really have to in
order to proceed. This stuff changes fast and gets smarter and more
cost effective as time goes on. I bought the VM1000 because I was
offered a good price just before a price hike was going to happen. Of
course, I didn't think it was going to take me this long to finish the
plane at that time, but that's a different problem.
Tim Bryan wrote:
Tom,
Tom Sargent
Posted: Mon Sep 10, 2007 4:03 am Post subject: VM1000 manifold pressure and CHT sensors |
I have one of the early ones too. Initially Vision Microsystems was the best on the market and their service was pretty good too. I had mine upgraded to the RS232 connectors and the DPU was initially set up for the wrong fuel pressure sender (but they shipped the correct sender). I got a great deal when I bought it. It was completely installed - waiting for the rest of the project to finish.
Since reading about their purchase by JPI (another can of worms itself) and their dropping of support for the first and second generation units, I've decided to remove it and install an AFS3400EM - it's now completely installed and I've been parting out the VMS1000 parts to keep existing units running.
Ralph Capen
Posted: Mon Sep 10, 2007 7:29 am Post subject: VM1000 manifold pressure and CHT sensors |
In a message dated 9/9/2007 4:13:59 P.M. Pacific Daylight Time, sarg314(at)comcast.net writes:
| Quote: | Thanks, I guess I'll have to swap CHT sensors. I don't like handling
web page has no downloads. How did you get yours? |
Tom-
I have a sheet of troubleshooting info for each of the instrument systems in hard copy. I will happily fax it to you if you like.
Posted: Mon Sep 10, 2007 7:45 am Post subject: VM1000 manifold pressure and CHT sensors |
Tom,
You are right it was once the one to have. I understood Mooney was putting
them in there certified planes. These were the reasons why I chose it. Too
bad it had to go down hill from there. Of course I purchased the UPS
slimline stack for my airplane also just before Garmin bought them out and
discontinued some of the product. I noticed the MX20 is now discontinued
also. It really sucked to have my stuff all discontinued even before my
airplane flew. It still works great however and I am enjoying it but would
like to see some updates (never will happen).
[quote] --
