DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Mon Aug 20, 2007 8:54 am Post subject: Oil Pressure Sending unit location |
Can the oil pressure sending unit be located on the lower port. My new sending unit is larger diameter than the factory unti and won't fit in the regular location. Attached photos show standard location and the plug port I want to use.
Thanks in advance
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
382.7 KB |
1269 Time(s) |
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
matronics(at)rtist.nl Guest
Posted: Mon Aug 20, 2007 9:28 am Post subject: Oil Pressure Sending unit location |
| Quote: | From what I understand you can place it at some other place in the oil
circuit but your pressure reading will be a bit too optimistic. The factory
oil sender is located just before the oil pump, where the oil pressure is
the lowest in the chain. If you can, run both the original sender and the
new sender side by side and see what the difference is.
Rob
andy(at)suncoastjabiru.co Guest
Posted: Mon Aug 20, 2007 10:51 am Post subject: Oil Pressure Sending unit location |
Martin,
Rob's almost right, but the standard position for the sender is right AFTER
the pump, so it'll measure higher than the lower position, which despite it
being only just below the sender, is actually at the other end of the oil
system. Between the two points are the oil cooler and filter, but the
'lower' point is the gallery supplying the bearings etc. My preference would
be to put the sender at the lower point, but this would have the sender
possibly interfering with the prop flange or other forward parts as it would
stand-out in front of the engine. If you can get a sender into the lower
point, by all means use it.
Andy
Suncoast Sportplanes, Inc.
39248 South Ave, Zephyrhills, FL 33542
Tel: (813) 779 2324 Fax: (813) 779 2246
www.suncoastjabiru.com
Posted: Mon Aug 20, 2007 11:46 am Post subject: Oil Pressure Sending unit location |
Hi Andy,
I just checked the drawings and it appears we're both wrong.. Looking at
page 93 of the inspection and maintenance manual (drawing 9493013-1), it
shows that oil from the oil pump goes to the 'donut' adapter, from there
through the oil cooler, then through the oil filter, and then into the oil
gallery. The pressure sensor sits right at the exit of the oil filter, but
before the oil gallery.
We have a bit low oil pressure reading when the run-in oil is hot, and we
connected a secondary sensor to the line feeding the oil cooler using a 'T'
adapter. Pressure reads about 5 psi higher than the original sensor.
DanM
Posted: Tue Aug 21, 2007 8:48 am Post subject: Re: Oil Pressure Sending unit location |
So guys, is it ok to use the lower port?
Kitfox IV
Sensenich 62x46
N443DM |
Posted: Tue Aug 21, 2007 9:24 am Post subject: Oil Pressure Sending unit location |
Dan,
Yes, it's OK to use the lower port. I've looked at the Drawing Rob refers
to, and I think it's wrong. It's ambiguous the way it's drawn, showing the
connection through the oil pump output port, and down into the gallery, when
in fact the connection should stop at the (upper) pump output port. I'll
clarify with Jabiru and will post here if different. However, I've measured
the pressure at both points, and the lower port is definitely at a lower
pressure, consistent with it being after the cooler and filter. I note that
the drawing isn't included in the later manual version for hydraulic
lifters!
Andy
Posted: Tue Aug 21, 2007 10:52 am Post subject: Oil Pressure Sending unit location |
Andy,
Thanks for looking into this. I'm very interested to hear what Jabiru's take
is on this.
Rob
DanM
Posted: Tue Aug 21, 2007 11:05 am Post subject: Re: Oil Pressure Sending unit location |
Thanks Andy & Rob, I'll watch the forum for any additional info on this subject.
Kitfox IV
Sensenich 62x46
N443DM |
Posted: Tue Sep 04, 2007 5:32 am Post subject: Oil Pressure Sending unit location |
Rob and all,
I got confirmation from Jabiru that the drawing in the manual is (at best)
misleading and the routing of the oil circuit is as I described. For those
who didn't see the earlier posts, there was confusion as to the sensing
location of the oil sender. It senses the pressure right after the pump and
in some (instrument) setups, this can show-up as pressure fluctuations on
the gauge during normal running. The lower sensing location - just
underneath the electric sender - is at the end of the oil gallery supplying
the bearings. Between those two points (despite being close together) are
the oil cooler, the oil filter and the pressure relief valve. If you want to
sense the oil pressure at the lower point, you will notice a pressure
difference of some 50kPa lower (7 psi) than the standard position, but the
lower position gives a steadier reading and reflects the pressure supplied
to the bearings before the oil returns to the case.
I've asked Jabiru to amend the drawings of the respective oil circuit
schematics in the manuals to make this clearer.
Andy Silvester
rshannon(at)cruzcom.com Guest
Posted: Wed Sep 05, 2007 6:56 am Post subject: Oil Pressure Sending unit location |
Andy,
Can you clarify the second location? By "just underneath the electric
sender" are you referring to the oil pressure switch?
Ron
| Quote: | Rob and all,
Andy Silvester
wypaul
Posted: Wed Sep 05, 2007 8:54 am Post subject: Re: Oil Pressure Sending unit location |
See the attached pix.
297.38 KB |
1300 Time(s) |
_________________ Paul Spackman
Q-2 Jabiru 3300 |
Andy Silvester
Joined: 10 Jan 2006 Posts: 18 Location: Marica, Rio de Janeiro, Brazil
Posted: Wed Sep 05, 2007 9:22 am Post subject: Re: Oil Pressure Sending unit location |
Perfect - Thanks, Paul. This is why the web-based format of this list is soooo much better than the YahooGroups offering!
Andy
