Sunshades revisited
dredmoody(at)cox.net
PostPosted: Thu Aug 30, 2007 12:05 pm    Post subject: Sunshades revisited Reply with quote
Has anyone recently (last two years or so) put a Koger shade in a 601XL? The website for the Koger shade only lists models for the RV7 and RV8 as far as I can tell. There was a post in the archives quite a while back referring to a Koger shade in a 601 but nobody has talked about it since.
Anyone have recent info on the subject?
Dred
610XL/Jabiru
bryanmmartin
PostPosted: Thu Aug 30, 2007 1:44 pm    Post subject: Sunshades revisited Reply with quote
I put one in my Zodiac this year. I bought it from someone on the list. I saw another Zodiac owner installing one on his plane at Oshkosh this year, he bought it at the show. I don't recall if I still have the box mine came in to get a part number or such off of. It may be the same as the one for the RV7 since both planes are side by side seating.
On Aug 30, 2007, at 4:03 PM, <dredmoody(at)cox.net (dredmoody(at)cox.net)> <dredmoody(at)cox.net (dredmoody(at)cox.net)> wrote:
--> Zenith-List message posted by: <dredmoody(at)cox.net (dredmoody(at)cox.net)>
Dred
610XL/Jabiru
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
rickpitcher
PostPosted: Thu Aug 30, 2007 2:07 pm    Post subject: Re: Sunshades revisited Reply with quote
Dred
610XL/Jabiru
I bought one from Koger a couple of months ago. The RV style fits our Zodiac bubbles just fine.
I LOVE it! One of the best accessories I've bought for One Zulu Romeo
Rick Pitcher
PostPosted: Thu Aug 30, 2007 2:30 pm    Post subject: Sunshades revisited Reply with quote
Rick, was it an RV7 style shade? That would seem to me to be too short in the fore and aft direction. The RV7 has a rollover protection structure right behind the pilots so it has to stop there. We have a good bit more clear canopy going rearward from that point. Does the RV7 style shade do the job adequately for you?
Dred
Rick Pitcher
rickpitcher
PostPosted: Thu Aug 30, 2007 2:51 pm    Post subject: Re: Sunshades revisited Reply with quote
Dred
Rick Pitcher
I think he said it was for an RV6.
Send an email to :r.koger(at)mchsi.com and tell him you want a shade for the Zodiac. He knows which one we need.
Rick
rickpitcher
PostPosted: Thu Aug 30, 2007 2:53 pm    Post subject: Re: Sunshades revisited Reply with quote
Dred
Rick Pitcher
Rick
Here's their webpage: http://cleavelandtool.com/kogercompany/sunshade.htm
rstone4(at)hot.rr.com
PostPosted: Thu Aug 30, 2007 3:59 pm    Post subject: Sunshades revisited Reply with quote
Dred,
My dad Bob ordered and installed one of the Koger shades in my ZodiacXL
about five months ago and it is too small. It does a fair job but should be
just a little wider and about 9 inches longer. He worked with Ralph on a
suitable design for the ZodiacXL after he bought mine by designing one
specifically for the ZodiacXL and sent him the dimensions. If you e-mail
him at r.koger(at)mchsi.com, he should have the proper dimensions to make you
a shade that will provide maximum shade. Mention my dad's name, Bob Stone
and remind him that he was sent the proper dimensions
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
alex_01
PostPosted: Fri Aug 31, 2007 4:39 am    Post subject: Re: Sunshades revisited Reply with quote
my one is perfect see pic bought from cleveland tools
 Filesize:  720.42 KB
 Viewed:  1052 Time(s)
amyvega2005(at)earthlink.
PostPosted: Fri Aug 31, 2007 7:18 am    Post subject: Sunshades revisited Reply with quote
alex,
how is it stuck on?
alex_01
PostPosted: Fri Aug 31, 2007 9:23 am    Post subject: Re: Sunshades revisited Reply with quote
with a kind of a double side tape short strips (slightl foamy) about 2" long.
was ok but not really strong enought when parked outside in the sun.
i got some more from 3M it is used to stick mirrowglass to the wall on tiles etc.
used over the full lenght and perfect
i bought a 2nd one for my friend here who has my old xl and he had similar problems but now also ok.
Tim Juhl
PostPosted: Fri Aug 31, 2007 10:34 am    Post subject: Re: Sunshades revisited Reply with quote
Has anyone tried little suction cups to support the rail? That way it would be removable.
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
bryanmmartin
PostPosted: Fri Aug 31, 2007 12:06 pm    Post subject: Sunshades revisited Reply with quote
I've tried the suction cup mounted sunshades in my plane, the little square ones about 18" square. They kept falling off because the suction cups wouldn't hold. I seriously doubt any suction cups would hold the Koger sunshades in place for long.
If you thoroughly clean the surfaces before applying and carefully bend the aluminum rail to match the curve of the canopy, the 3M double sided tape should hold the sunshade in place with no trouble. I've seen no signs of mine coming loose so far.
As far as being removable is concerned, the Koger sunshade can be easily removed, leaving just the narrow aluminum center frame behind.
--> Zenith-List message posted by: "Tim Juhl" <juhl(at)avci.net (juhl(at)avci.net)>
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive.
PostPosted: Fri Aug 31, 2007 12:34 pm    Post subject: Sunshades revisited Reply with quote
Bryan,
You are right about the suction cup shades coming off. I have the RV-7 shade installed in my ZodiacXL and it does not cover the last part of the canopy so I use two of the black 18 inch square suction cup shades and the right one seems to be holding very well but the left one is always falling off. As for the Koger center rail, it glues on after being bent to match the conture of the canopy and I don't think you could pull it off without destroying the canopy. My dad sent Ralph Koger an e-mail some time ago with a drawing of a shade with dimensions suitable for the ZodiacXL so he should have shades that will fit by now.
Tracy Stone
Harker Heights, Tx
PostPosted: Sat Sep 01, 2007 3:59 am    Post subject: Sunshades revisited Reply with quote
Alex,
did you buy the 3m doub le side tape on line, ? where would you recommend?
Juan
alex_01
PostPosted: Mon Sep 03, 2007 12:08 am    Post subject: Re: Sunshades revisited Reply with quote
Hello Juan,
I got mine here in Germany we have it in our workshop,
but please look here this should help you
http://www.tesatape.com/professional/industry/products/doubl4249/doubl4300/46800.html
and i looked for you where you could order online
http://www.pamarcoglobal.com/flexo-pages/_body-flexo-content8-02c.htm
TESA 4977 will do the job perfect
bryanmmartin
PostPosted: Mon Sep 03, 2007 7:04 am    Post subject: Sunshades revisited Reply with quote
The tape that was supplied with my sunshade has held up well so far. Just make sure to adjust the bend of the rail to closely match the curve of the canopy to reduce the stress on the tape and thouroghly clean the surfaces before attaching. If you need to buy attachment tapes, they are probably available at you your local auto parts store or auto body shop. The 3M AcrylicPlus tape looks good for this application.
See: http://tinyurl.com/2fjbn8
Here are some on-line sources for attachment tape if you don't mind paying the shipping:
Amazon.com: http://tinyurl.com/2hhlyk
JCWhitney also caries attachment tape: http://tinyurl.com/ywzggr
Some eBay stores also sell it.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive.
dasduck(at)comcast.net
PostPosted: Mon Sep 03, 2007 8:11 am    Post subject: Sunshades revisited Reply with quote
Regarding the Koger Sunshades - I installed one in my RV-6 Tip-up canopy
very early in his production, 1995 or 6?
Anyway, I have never had any issue with it of any kind, the sticky strips
are still sticky, the slide still slides.
I use it all the time - extended for taxi/ground work, pulled back for
takoff and pattern work.
The only time it doesan't cover enough is cross country where you are at
altitude on a sunny day.
I usually just put a map up under the edge of it to block the side sun if
it's an issue (one of those small suction cup shades may be better for that
side sun than a map Wink.
The fact that it's always there and so easy to extend/retract, makes it
worth the price IMO.
Don
