occom
Posted: Wed Aug 29, 2007 12:16 pm Post subject: pitot dimensions and alternate location |
I have a mangled pitot and a desire to see it somewhere other than the
stock 1991 location. I was eying rib 4 or 5 as an alternate to the
specified (in my instructions) rib 7. Has anyone done this? I can't see
any problems. I was also thinking of doubling it up and putting a static
source along under the pitot tube and epoxying them together. Two 1/16th
holes each side of the static should do I would think. I also need the
dimensions of the un-mangled pitot if anyone has them .
jezim(at)pro-ns.net Guest
Posted: Wed Aug 29, 2007 6:55 pm Post subject: pitot dimensions and alternate location |
My series 5 pitot is .250 OD X .177 ID. I ran mine where the plans said
except instead of drilling a hole in the spar I ran the tube in grommets
thru the ribs.
Jim Z Series 5 under const. 0-200
occom
Posted: Thu Aug 30, 2007 2:11 am Post subject: pitot dimensions and alternate location |
Thanks Jim, I actually needed the length. I read all I could find about
location and requirements etc for pitot tubes and it seems there are no
strict design requirements. So my new one will be rib 5 or 6 about 5" below
the wing surface.
Dave Goddard- Mod IV 1050/582
Posted: Thu Aug 30, 2007 8:51 am Post subject: pitot dimensions and alternate location |
5 1/2 X 8 3/4 to the center of the 90 degree. Jim
occom
Posted: Thu Aug 30, 2007 11:09 am Post subject: pitot dimensions and alternate location |
Thanks, I now have a new pitot, stainless this time as I was unable to buy
1/4" aluminum tube.
Lynn Matteson
Posted: Fri Aug 31, 2007 2:07 am Post subject: pitot dimensions and alternate location |
I've got a factory fresh pitot (1994) that you can have,if you want
it...I used a Spruce tube for my plane.
Lynn Matteson
flying w/395+ hrs
On Aug 30, 2007, at 3:09 PM, Dave G. wrote:
to buy 1/4" aluminum tube.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
occom
Posted: Fri Aug 31, 2007 3:18 am Post subject: pitot dimensions and alternate location |
Thanks Lynn, the new stainless one is now mounted.
Lynn Matteson wrote:
Lynn Matteson
flying w/395+ hrs
