royjp(at)yahoo.ca Guest
Posted: Tue Aug 28, 2007 9:14 am Post subject: RE : Re: Painting Layout |
Hello Jay. How about using a little piece of masking tape temporiraly applied until you have the proper tape in place.
Hope this helps
Jean-Paul
Paul Mulwitz <psm(at)att.net> a écrit :
[quote]--> Zenith-List message posted by: Paul Mulwitz
Hi Jay,
I think you can use the Sharpie to mark your paint limits. You might
need to wait a couple of days for the paint to harden before removing
the Sharpie marks, but the paint should not be a problem once it is hardened.
My understanding is that "Enamel" paints are not subject to solvent
destruction after dry. Lacquer paints are indeed always limited in
their resistance to solvent. I also believe all the paints you are
likely to use on your plane will indeed be enamels.
You Découvrez ce qui fait jaser les gens ! Visitez les groupes de l'heure sur Yahoo! Québec Groupes. [quote][b]
dougsnash(at)yahoo.com Guest
Posted: Tue Aug 28, 2007 10:52 am Post subject: RE : Re: Painting Layout |
A fine tip dry erase marker might also work for
layout. You then don't have to worry about using
solvents to remove the marks after your masking is
layed out.
Do not Archive
Doug MacDonald
CH-701 Scatch builder
NW Ontario, Canada
--- Jean-Paul Roy <royjp(at)yahoo.ca> wrote:
| Quote: | Hello Jay. How about using a little piece of masking
tape in place.
Hope this helps
Jean-Paul
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search
