billsewell(at)gmail.com Guest
Posted: Mon Aug 27, 2007 9:05 am Post subject: N601BZ Fly's! |
Today, August 27, 2007, at 8:56AM EDT N601BZ flew for the first time. The flight was unintentional, occurring during a high speed taxi test. I had the stick full back as is typical when taxing a conventional gear aircraft and as the aircraft accelerated past 40MPH and approached 50MPH, just as I was about to bring the tail up, the right wheel broke ground. I moved the stick to the right and the left wheel came up and we were flying. I moved the stick to lower the nose into a gentle climb attitude and added right trim to bring the stick back to neutral. I then trimmed the nose up to continue the climb at around 90 MPH, when I had a chance to look, and was at pattern altitude before I knew it. Since the there were clouds at about 2000 feet and since I hadn't intended to fly in the first place, I decided to make one circuit of the pattern and attempt to put the airplane back on the runway at the first opportunity. I made a gentle left turn to cross wind and another to down wind. Once on down wind, I reduced power to 2000 and added a bit more nose up trim. Once past the end of the runway I reduced power to 1500 and began a smooth gradual descent. Another gentle left turn to base and one more to final and before I knew it I was over the end of the runway. I pulled power back to idle as I flared and the propeller stopped just a second before I made a soft 3 point touch down. I rolled out and slowed down and restarted the engine with the starter. My first flight was over and it probably lasted all of 6 minutes.
So this is what I learned. First, the TD will take off in a 3 point attitude very easily. The 601XL accelerates very quickly once the throttle is fully open. I had heard about the left wing being heavy and needing right trim from other first flight reports so there was no surprise there. I'm not sure why the propeller stopped over the runway in the flair, the ground idle speed is set to 850 and hasn't been a problem. I realized after landing that I had forgotten to pull carb heat and it was a humid so I suppose there might have been some carb ice but I'm not convinced of that. I will download the EMS data and see if it contains any clue.
Even though my first flight was very short, my impression of the 601XL's flight characteristics are that it is very much like a Citabria or even a Cessna and I felt right at home flying it. The landing and taxi characteristics are also very similar to the Citabria that I have done most of my tail wheel flying in.
I will be posting some video to my web site in the near future.
Just want to thank Zenith Aircraft for a great design and all the other builders that have helped me out. And of course to thank my wife for supporting my hobby and for filming my "high speed taxi tests."
Bill Sewell
N601BZ [quote][b]
Posted: Mon Aug 27, 2007 9:52 am Post subject: N601BZ Fly's! |
Congratulations Bill,
This is one of life's best adventures. Pleased you made it in one piece.
Do continue to fly safe,
do not archive.
Bill Sewell wrote:
Bill Sewell
N601BZ
wjones(at)brazoriainet.co Guest
Posted: Mon Aug 27, 2007 10:04 am Post subject: N601BZ Fly's! |
Congratulations Bill ,you have built a beautiful aircraft and did well on your first flight .I have seen this happen before with high speed taxing and it is nice when your plane is prepared for flight even when it is not your intention .Thanks for the help you have given me and as always be safe and enjoy your new toy .
Wade Jones South Texas
601XL plans building
Cont. 0200
john.marzulli(at)gmail.co Guest
Posted: Mon Aug 27, 2007 10:27 am Post subject: N601BZ Fly's! |
Congrats and good luck tracking down the engine gremlins.
What engine are you using?
-John in Seattle
On 8/27/07, Bill Sewell < billsewell(at)gmail.com (billsewell(at)gmail.com)> wrote:[quote]
Bill Sewell
N601BZ [quote][b] http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com
"Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes.
-Airplane The Movie [quote][b]
dredmoody(at)cox.net Guest
Posted: Mon Aug 27, 2007 10:42 am Post subject: N601BZ Fly's! |
First, my congratulations on a successful (although "unintentional") first flight. That had to be a thrill to remember and I'm glad it went so smoothly for you.
Second, some recent posts have urged setting the idle rpm to 1,000 until the engine has run enough (25 - 35 hrs?) to loosen up a bit. I can't speak to that since mine isn't flying yet.
Third, I have to say that I find the "oops factor" somewhat suspicious in your story. Hell, call me a cynic, but I wouldn't expect the general public to buy that story at face value. I detect a touch of "Damn the torpedoes.... full speed ahead" in the account. But hey, it's your story so stick to it. It has been run up the flagpole and some will salute it even if there's a hint of N601BS rather than N601BZ in it. '-)
Dred
PS: Did you buy the kit then tell your wife, "Honey, it followed me home. Can we keep it?" As you were. Carry on.
eddies
Posted: Mon Aug 27, 2007 1:24 pm Post subject: Re: N601BZ Fly's! |
A big congratulations Bill, looking forward to seeing your flight video's on your website
Eddie
n801bh(at)netzero.com Guest
Posted: Mon Aug 27, 2007 2:12 pm Post subject: N601BZ Fly's! |
A BIG congrats to you,,,, I bet you still have that silly grin on your face too....
Ben Haas
N801BH
www.haaspowerair.com
Bill Sewell
N601BZ[quote]
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Mon Aug 27, 2007 3:03 pm Post subject: N601BZ Fly's! |
Congradulations!! The fun begins-------
George May
601XL 912s 147hrs
| Quote: | From: "Bill Sewell" <billsewell(at)gmail.com>
Reply-To: zenith-list(at)matronics.com
To: zenith-list(at)matronics.com, "Zenith AC Support" <support(at)zenithair.com>
Subject: N601BZ Fly's!
Date: Mon, 27 Aug 2007 13:04:46 -0400
at
I'm
I
Bill Sewell
N601BZ
Booking a flight? Know when to buy with airfare predictions on MSN Travel.
http://travel.msn.com/Articles/aboutfarecast.aspx&ocid=T001MSN25A07001
archerm
Posted: Mon Aug 27, 2007 3:38 pm Post subject: N601BZ Fly's! |
Congratulations Bill, I have been following your progress on your website and it has really helped when I run into problems.
Great News.
Keep Safe
Matt Archer
www.zodiacxl.com
_________________ Matt
www.zodiacxl.com |
rgeese
Posted: Mon Aug 27, 2007 6:33 pm Post subject: Re: N601BZ Fly's! |
Congratulations, Bill! I, like others, am very grateful to you for your website. I always seem to go to it when I have a problem, and usually find a solution there. Thanks for all your hard work in keeping it updated. It is appreciated. Our building speeds are about the same, so I could always depend on you for help.
I had the same experience of "unintended flight" several years ago while high-speed taxi testing my Dragonfly MKI. All of a sudden everything got really quiet, and upon looking out at the end of the canard, found that my wheels were a couple of feet in the air. I firewalled the throttle and away I went for a 45 minute first flight. The thrill was indescribable.
Again, congratulations, and please be safe!! Someday I hope to meet you in person-maybe on one of my business trips to VA.
Do not archive.
Ron Geese
Columbus, Ohio
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Mon Aug 27, 2007 9:01 pm Post subject: Re: N601BZ Fly's! |
Congrats!
You inspire the rest of us.
- Pat
XL/Corvair
lgingell
Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
Posted: Tue Aug 28, 2007 12:55 am Post subject: Re: N601BZ Fly's! |
Big congratulations Bill! I didn't even know you got started again after completing the airframe.
Can't wait to see the video!
..lance, 210hours
_________________ Zodiac XL/Jab 3300
http://lancegingell.com |
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Tue Aug 28, 2007 3:35 am Post subject: Re: N601BZ Fly's! |
CAN SOMBODY GIVE ME A LINK TO BILL'S WEBSITE
THANKS
GLENN
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
jeffrey_davidson(at)earth Guest
Posted: Tue Aug 28, 2007 4:06 am Post subject: N601BZ Fly's! |
THANKS
GLENN
Links to many builders' web sites, including Bill's, are at the following
URL:
http://www.ch601.org/Builder_links.htm
Jeff D.
Float Flyr
Posted: Tue Aug 28, 2007 5:04 am Post subject: N601BZ Fly's! |
I also drive a Miata. One of the very first ones to come across from the land of the rising sun. No power steering (it's supposed to be a sports car!) No Air conditioning ( just the drop top) No Power anything (I can reach most anything except the outside passenger side mirror) It does have a half decent, for '89, stereo but it gets in the way of enjoying the car. Now if I could only shoe horn in a bigger engine !
Now that's out of the way. The Miata has a very small tank. Around ten Gal., 12 Gal. U.S.. If you refill from one of those service stations that have the one hose for all grades of gas places you will no doubt end up pumping a considerable quantity of low octane gas into your car before the good stuff even gets to the nozzle.
Lets assume the inside of the hose is around 1.25 in in diameter and it is around 20 feet long to account for some of the plumbing that goes to the overhead connector the hose is attached to. this gives us 93.75 cubic inches or .4 Gal U.S.. If you have a habit of keeping your car full and refill the tank as soon as the needle hits 3/4 then you actually have a lot less high octane gas in your tank.
This is important to an engine like the Miata and the 912/Jab or even the TSC'd Lycoming. They will knock like, never mind (PG 13), and you can be sure it isn't good for the engine either.
My advice is:
Only purchase your high octane gas at service stations where they have dedicated nozzles for each grade of gas or put the first Gal into a separate container to use in your lawn mower.
Check to make sure you aren't getting fuel contaminated (no better word) with Ethanol when buying gas for your plane. Personally because of the increase in carbon footprint I won't use Ethanol contaminated fuel in anything. If you want to debate that statement I'll do it off list.
Try to buy gas at busy locations. It may cost a few pennies more but the gas gets delivered there more often so it should be fresher.
Never add any thing to your gas. A lot of petroleum distillates will eat parts of your engine. I haven't seen MTBE, the agent used to increase octane, for sale any where. But hey, if you can get it.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Tue Aug 28, 2007 6:48 am Post subject: N601BZ Fly's! |
Congratulations!
So, maybe you could call yourself the “Accidental Pilot.”
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
Gig Giacona
Posted: Tue Aug 28, 2007 6:48 am Post subject: Re: N601BZ Fly's! |
Congrats on the first flight.
But this should be a reminder to all. When doing fast taxi testing, BE PREPARED TO FLY.
601XL Under Construction
leo(at)zuehlfield.com Guest
Posted: Tue Aug 28, 2007 7:19 am Post subject: N601BZ Fly's! |
Bill, Those darn CH designs just want to fly! Oh, Joy, Joy.
Leo Gates
N601Z
do not archive.
Bill Sewell wrote:
Bill Sewell
N601BZ
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Tue Aug 28, 2007 8:31 am Post subject: N601BZ Fly's! |
Congratulations on a great building job and successful first flight. And thank you for the great website.
Terry
At 01:04 PM 8/27/2007 -0400, you wrote:
| Quote: | Today, August 27, 2007, at 8:56AM EDT N601BZ flew for the first time. ...
Bill Sewell
N601BZ |
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 slow build kit - Rudder done--finally; working on the stab
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
