Leading Edge Spar Retaining Pin
akanka(at)kiamichiwb.org
PostPosted: Fri Aug 24, 2007 5:29 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
Does anyone know what the AN designation of the leading edge pins that go
through the leading edge (or front) spar and carry through adapter to hold
the wings in place for flight? From measurements, the closest I can guess
is a AN395-85 Clevis Pin. I'd hate to be wrong on this. It could ruin
one's whole day!
John Hart
Lynn Matteson
PostPosted: Fri Aug 24, 2007 6:06 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
That's the exact number that I find in my Packing List from the old
Skystar, John....pin, clevis:AN395-85 (This is for my model IV)
Lynn Matteson
Grass Lake, Michigan
flying w/395+ hrs
On Aug 24, 2007, at 9:29 AM, John W. Hart wrote:
<akanka(at)kiamichiwb.org>
that go
to hold
can guess
ruin
one's whole day!
John Hart
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Fri Aug 24, 2007 6:43 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
Thanks Lynn. I have a Model IV also, and I was pretty sure I had the right
critter, but I don't like guessing when it comes to parts as critical as
these. I bought the aircraft already built, and have a lot of the
paperwork, but couldn't locate anything telling me EXACTLY what the pin is.
I appreciate the help.
John Hart
msm_9949(at)yahoo.com
PostPosted: Fri Aug 24, 2007 8:19 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
Luggage? GPS? Comic books?
clevis_pins.pdf
 Filename:  clevis_pins.pdf
 Filesize:  271.75 KB
 Downloaded:  491 Time(s)
Lynn Matteson
PostPosted: Fri Aug 24, 2007 11:54 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
You're welcome, John.
I was gonna add this part earlier, but figured you didn't need
another thing to worry about. Now that you've got a few hours older
(joke), I think you can handle it. In Spruce's description of the
clevis pins, it says: "Used with clevis forks and in secondary
controls which are not subjected to continuous operation." Makes
you wonder, doesn't it? Smile
Lynn Matteson
flying w/395+ hrs
the right
critical as
pin is.
John Hart
Lynn
N369LM
PostPosted: Fri Aug 24, 2007 1:06 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
No Problem. And you're right, I am a little older now!
I wasn't sure whether this was a "high shear" rated pin or just a standard
AN pin. As I see it, these pins are in shear stress only, and not subject
to the working action you would find in a control that is constantly being
moved. The cad plating is gone from the ones I have, and they also have a
few minor scratches that I don't like (stress risers). I'd guess that with
all the Kitfox Aircraft flying today, that pin hasn't failed a lot, or there
would be all kinds of stuff out as service bulletins and such.
AC 43.13-1B says essentially the same thing as Aircraft Spruce:
7-102. FLATHEAD PINS (AN392
THROUGH AN406). Commonly called a clevis pin, this pin is used in
conjunction with
tie-rod terminals and in secondary controls which are not subject to
The pin is normally installed with the head up, or forward, to prevent loss
should the cotter
pin fail or work out.
Thanks again for verifying that number.
John Hart
Float Flyr
PostPosted: Fri Aug 24, 2007 5:08 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
That’s because clevis pins are usually used in moving shear applications e.g. axels for pulleys. The application on the 'Fox and the Avid is a static shear application. Because I fold my wings after every flight I keep an eye peeled on the condition of the clevis pin and if it ever gets to the point where the cad plate is worn through I'll replace them.
[img]cid:332255100(at)25082007-2B3F[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  379 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
thesupe(at)hotmail.com
PostPosted: Fri Aug 24, 2007 7:41 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
I wonder if that doesn't refer to continuous movement. On my Avid MI IV, I
didn't drive my pins in all the way, maybe 1/8" high, after a bunch of hours
of flying, they were still in the same place. (they don't move around)
Jim Chuk Avid MK IV Jabiru 2200 (now flying)
Subject: Re: Leading Edge Spar Retaining Pin Date: Fri, 24 Aug
2007 15:56:33 -0400
I was gonna add this part earlier, but figured you didn't need another
thing to worry about. Now that you've got a few hours older (joke), I
think you can handle it. In Spruce's description of the clevis pins, it
says: "Used with clevis forks and in secondary controls which are not
subjected to continuous operation." Makes you wonder, doesn't it? Smile
Lynn Matteson
flying w/395+ hrs
>right
>is.
>John Hart
Find a local pizza place, movie theater, and more….then map the best route!
http://maps.live.com/default.aspx?v &ss=yp.bars~yp.pizza~yp.movie%20theater&cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=950607&encType=1&FORM=MGAC01
klschooley(at)hotmail.com
PostPosted: Sat Aug 25, 2007 12:30 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
Just a quick note regarding the wing retaining pins, I was told as an Avid
Flyer salesman. That there is practically NO shear on these pins. Because of
the location of the wing lift struts at the lower pivot point, the pin has
approx. 18 lbs. forward load at nominal cruise (there is virtually no
rearward load). The reason for the size of this pin is for pilot confidence,
not necessarily for strength. The most loading will occur during landing
configuration or ground movement.
Thanks, Ken
[quote]From: "Noel Loveys" <noelloveys(at)yahoo.ca>
Subject: RE: Leading Edge Spar Retaining Pin Date: Fri, 24 Aug
2007 22:37:42 -0230
That's because clevis pins are usually used in moving shear applications
keep
Canada
Aerocet 1100s
<mailto:noelloveys(at)yahoo.ca> noelloveys(at)yahoo.ca
Float Flyr
PostPosted: Sat Aug 25, 2007 4:33 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
The operative word there I think is, "practically" . The only load at all
is shear but you are right that is minimal. No doubt the clevis pin could
be a lot smaller and still do the job. For the reason you give, pilot
confidence, if the cad plating ever wears off my pins I'll replace them.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
hflynn46531(at)yahoo.com
PostPosted: Sun Aug 26, 2007 3:24 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
When building my S5 in 1996 I talked to the tec. department at skystar about the forward wing spar bolts. They told me that the wings had a forward lifting force on them and in theory in level flight the bolts could be removed and the wings would remain in place. How about that!!!
Noel Loveys <noelloveys(at)yahoo.ca> wrote: [quote]--> Kitfox-List message posted by: "Noel Loveys"
Noel
[quote] --
Float Flyr
PostPosted: Sun Aug 26, 2007 6:10 am    Post subject: Leading Edge Spar Retaining Pin Reply with quote
I don't disbelieve it, especially if the air velocity over the wing is constant. I'm not going to try it...U first!! Wink
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sun Aug 26, 2007 12:14 pm    Post subject: Leading Edge Spar Retaining Pin Reply with quote
I don't think I want to personally test that theory! ;<)
John Hart
[quote] --
