Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
amyvega2005(at)earthlink. Guest
Posted: Thu Aug 23, 2007 5:59 am Post subject: Fuel System Design |
just stick to the plans, its a good design.
Posted: Thu Aug 23, 2007 1:59 pm Post subject: Fuel System Design |
A few comments:
- since you are going with the Corvair I presume you will be following
William's design.
- consider adding a fuel flow sender and gauge. Fuel exhaustion is an all to
common cause of accidents and fuel flow can provide an instantaneous check
on the health of your fuel system and also help you track your fuel more
accurately.
- I'm paranoid enough about vapor-lock that I went with the Andair
extensions so I can mount my valve on the floor and the knob on the center
console.
-- Craig
Ron Lendon
Posted: Thu Aug 23, 2007 6:28 pm Post subject: Re: Fuel System Design |
Craig,
I have allowed for the pressure gage but hadn't thought about the flow. And yes it is a Corvair the WW way. I have been waiting for him to publish the 601 book but have gotten to the point I need to move forward.
Got any pictures of the Andair Valve mounted?
Thanks for the ideas.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Posted: Thu Aug 23, 2007 6:44 pm Post subject: Fuel System Design |
| Quote: | Got any pictures of the Andair Valve mounted?
Mine is still mounted in its box. But I've attached pictures of somebody
else's installation. Unfortunately I've lost track of whose plane it is.
-- Craig
107.52 KB |
870 Time(s) |
116.69 KB |
912 Time(s) |
davidhwright(at)mac.com Guest
Posted: Fri Aug 24, 2007 2:13 am Post subject: Fuel System Design |
Ron
I am more or less at the same stage as you are - I was considering
quick disconnects at each wing root - any thoughts on these?
Dave Wright
Washington UK
601XL Wings, Scratchbuild
On 24 Aug 2007, at 03:28, Ron Lendon wrote:
Craig,
to move forward.
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder
http://forums.matronics.com/viewtopic.php?p=130646#130646
Afterfxllc(at)aol.com Guest
Posted: Fri Aug 24, 2007 2:20 am Post subject: Fuel System Design |
I can send you pics of the complete fuel system I installed for the corvair install if you need them?
Jeff
Jaybannist(at)cs.com Guest
Posted: Fri Aug 24, 2007 5:04 am Post subject: Fuel System Design |
David,
I have an XL with the dual stick option. The outboard bearing brackets for the system have holes in them for fuel line support. In these holes, I mounted a AN bulkhead fitting. The inboard side is connected to the fuel selector with braided fuel line. I installed a hose barb fitting on the outboard side. When I attach my wings, I will route the ZAC-furnished rubber hose from the fuel tank, thru the side skin and to this hose barb. In that location, the connection, with a clamp, will be real easy to make. That is about as close to a quick disconnect as I want to be.
Jay in Dallas
David Wright <davidhwright(at)mac.com> wrote:
Ron
Dave Wright
Washington UK
> Craig,
> to move forward.
> http://www.mykitlog.com/rlendon
archerm
Ron Lendon
Posted: Fri Aug 24, 2007 6:54 pm Post subject: Re: Fuel System Design |
Craig and others,
Added a Floscan 210B to the design just down from the second pump, filter will come after that. It will connect right to the Dynon unit I plan to install.
I don't see the need for a quick disconnect at the wings, once they go on I hope to keep them on. I am planing on using the Stainless Braided hose though and keeping all the pressure on the engine side of the firewall. The braided hose is much less likely to rupture if the worse thing happens.
I am going to have to experiment with some clear line to decide about mounting the selector valve low.
Thanks for all the feedback, keep it coming,
CH 601 XLB
N601LT - Flying
doffill(at)cableone.net Guest
Posted: Fri Aug 24, 2007 7:21 pm Post subject: Fuel System Design |
Matt what did you use to paint the inside of the fuselage with. It looks
great.
Danny
archerm
Posted: Sat Aug 25, 2007 1:22 pm Post subject: Fuel System Design |
I used Stewart Systems water based paint. It takes a little getting used
to. But I really like it. This stuff is very durable and very safe. I
tried it on the interior to get the feel of it. I am glad I did. If you
order paint from them they will send you a video that shows how to do it.
They are really great to work with.
http://www.aircraftfinishing.com/
Good luck and happy building
Matt
www.zodiacxl.com
_________________ Matt
www.zodiacxl.com |
Ron Lendon
Posted: Sun Aug 26, 2007 11:10 am Post subject: Re: Fuel System Design |
Send the pictures.
| Afterfxllc(at)aol.com wrote: | I can send you pics of the complete fuel system I installed for the corvair install if you need them?
Jeff
Get a sneak peek of the all-new AOL.com. |
CH 601 XLB
N601LT - Flying
