		Vince Frazier
				 Posted: Wed Aug 22, 2007 6:02 am    Post subject: tailwheel problem...solved |
				*******************SNIP Subject: RV-List: Tail wheel question
 I just purchased the 6" double fork tail wheel from Aviation Products,
 Inc.
 to give me increased clearance over Van's tail wheel.  It appears to
 have a vertical pilot hole which I must use to drill a new vertical hole
 through the
 tailspring onto which it mounts.
 1.  Are there any tricks/suggestions for drilling this hole?
 2.  Can this be easily and accurately done with the tailspring still
 installed on the airplane?
 3.  Is the one vertical hole adequate or should I try to match up the
 two horizontal holes which Vans has in their tailspring and drill them
 too?
 I understand many of you have installed this upgrade tail wheel and I
 would appreciate hearing of your experience.
 Further, the new tail wheel weighs 5 pounds (bathroom scale).  I
 haven't removed my Van's tail wheel yet, but suspect the new one is
 heavier and  will change my CG.  Any thoughts?
 Pete SNIP************************
 Peter,
 Before you drill any new holes for a new tailwheel, please take a look
 at mine.  It will retrofit into a Van's socket in 5 minutes with no
 drilling whatsoever.  A direct replacement.  It weighs virtually the
 same as the Van's unit, within 1/2 ounce by my scale.
 My tailwheels have better clearance than the Van's, better handling, and
 a smaller frontal area than other units.  You can even install a
 wheelpant on mine (see the website) and it will still full swivel as
 designed.
 My product was originally designed to meet the needs of the F1 and HRII
 Rockets.  It works equally well on the RV brethren.  Over 90 of mine are
 out there now and I have them IN STOCK for quick delivery.
 Vince Frazier
 Screaming Eagle Graphics and Accessories, LLC
 3965 Caborn Road
 Mount Vernon, IN 47620
 812-464-1839
 http://vincesrocket.com/products.htm
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Vince Frazier
3965 Caborn Road
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
		jrstone(at)insightbb.com Guest
				 Posted: Wed Aug 22, 2007 3:59 pm    Post subject: tailwheel problem...solved |
				Hey Vince,
 I bought their stainless steel spring to go with the new tailwheel and had
 them match drill the new one. I had the luxury of a non flying Rocket so I
 was able to send them my spring and wheel.  In my opinion, it is a great
 looking product and they were easy to deal with.  They have not considered
 the steering link so I had to bend my own arm.  The spring was slightly
 larger in diameter and required some Emery cloth and some muscle to reduce
 it slightly.  The hole did line up, and I was in business in no time.
 Hope this helps,
 Jim Stone
 Harmon Rocket II
 1-2 weeks to go
		Mytyweav(at)earthlink.net Guest
				 Posted: Wed Aug 22, 2007 7:52 pm    Post subject: tailwheel problem...solved |
				Yo Jim...... You shoulda bought the one from Vince. You'll figure it out
 with a little time....
 Weav
 Jim Stone wrote:
  Hey Vince,
  had them match drill the new one. I had the luxury of a non flying
  Rocket so I was able to send them my spring and wheel.  In my opinion,
  it is a great looking product and they were easy to deal with.  They
  have not considered the steering link so I had to bend my own arm.
  The spring was slightly larger in diameter and required some Emery
  cloth and some muscle to reduce it slightly.  The hole did line up,
  Hope this helps,
  Jim Stone
  Harmon Rocket II
  1-2 weeks to go
