Battery Tray for a pair of Odyssey 680s
MauleDriver(at)nc.rr.com
PostPosted: Wed Aug 15, 2007 2:52 pm    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
I'm looking at putting a pair of 680s in the normal battery location. I
know several others have done this... would you be so kind as to share
your tray design?
The plan is to do a Z-14 with the ability to crank the engine with 1 or
both batts. Any comments on that welcome.
rleffler
PostPosted: Wed Aug 15, 2007 3:45 pm    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
Dan Lloyd had designed a nice tray, but I couldn't find any pictures in the
archives. Dan also made some seat levers too.
Dan,
Can you share your battery tray and seat levers with us again?
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
scottmschmidt(at)yahoo.co
PostPosted: Wed Aug 15, 2007 3:49 pm    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
Here are some pictures of how I did it.
http://www.scottandranae.smugmug.com/gallery/554620#50657776
Scott Schmidt
scottmschmidt(at)yahoo.com
Deems Davis
PostPosted: Wed Aug 15, 2007 3:52 pm    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
William
Here's a link to a photo album it's got about 10 pics (follow the
controls on the left of the page) that shows how I modified mine, I've
got 2 680's and am building a Z14 arch.
Battery tray const.
http://deemsrv10.com/album/Sec%2039%20Control%20System/slides/DSC02860.html
With Batteries installed :
http://deemsrv10.com/album/Wiring/slides/DSC03227.html
I'm using a 60 amp alt as the main and the SD-20 as the Aux. (parallel).
To the best of my ability it's wired per Nuckols drawing. (except batts
grounded to airframe in rear)
In the picture below the START switch (lower left) will momentarily
couple both batteries together, moving the switch the other direction
activated the Cross feed contactor couple the systems if desired/necessary.
http://deemsrv10.com/album/Panel/slides/DSC05267.html
Deems Davis # 406
'Its all done....Its just not put together'
I know several others have done this... would you be so kind as to
share your tray design?
or both batts. Any comments on that welcome.
ricksked(at)embarqmail.co
PostPosted: Wed Aug 15, 2007 4:50 pm    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
Check Mike Sausens page, I used his method, very simple.
Rick S.
40185
zackrv8
PostPosted: Wed Aug 15, 2007 5:47 pm    Post subject: Re: Battery Tray for a pair of Odyssey 680s Reply with quote
Here's the way I did it...
Zack
quote="MauleDriver(at)nc.rr.com"]I'm looking at putting a pair of 680s in the normal battery location. I
your tray design?
both batts. Any comments on that welcome.[/quote]
 Filesize:  53.12 KB
 Viewed:  383 Time(s)
 Filesize:  68.53 KB
 Viewed:  371 Time(s)
 Filesize:  44.46 KB
 Viewed:  326 Time(s)
RV8 #80125
RV10 # 40512
LloydDR(at)wernerco.com
PostPosted: Thu Aug 16, 2007 5:03 am    Post subject: Battery Tray for a pair of Odyssey 680s Reply with quote
Tim has them posted on his website under the modifications section, at
least for the battery tray. The seat levers were based off of someone
else's, but I had an Mechanical Engineer in New York redesign them
because the ones that the other person were selling were breaking at the
pivot point.
What we did was to put in a floating pin, so that the pivot stress was
reduced. I can take some pictures and post them if anyone is interested.
Dan
N289DT RV10E
