william(at)gbta.net Guest
Posted: Fri Feb 17, 2006 8:38 am Post subject: Tailcone longeron hole clearance --one more time |
Posted this yesterday morning and only got one response. I even sent the same question and pictures to Vans and they didn't even answer yet. Anyway, on page 10-13 steps 4, 6, and 7 we are instructed to drill the end holes of each piece to #12's into the longerons. What is the proper, or acceptable hole clearances (to the edge of the longerons)??? Mine range from 1/4" to 1/8 inch on the closest ones. Is this an acceptable distance or do I need to get new longerons and start over???
Pictures are attached.
Thanks in advance,
Bill Britton
RV-10 Tailcone
Posted: Fri Feb 17, 2006 9:04 am Post subject: Tailcone longeron hole clearance --one more time |
Forgot to attach the pictures.
45.69 KB |
583 Time(s) |
46.37 KB |
549 Time(s) |
millstees(at)ameritech.ne Guest
Posted: Fri Feb 17, 2006 9:31 am Post subject: Tailcone longeron hole clearance --one more time |
The holes on my longeron are uniformly 1/2" from the outboard edge of the longeron. Sounds like your F-1014 aft deck was not square when you drilled the longeron. As has often been said, the parts are cheap, so order a new part and do it right.
Steve Mills 40486
N750SM reserved
wings
Posted: Fri Feb 17, 2006 10:11 am Post subject: Tailcone longeron hole clearance --one more time |
Bill and Tami Britton wrote:
| Quote: | Posted this yesterday morning and only got one response. I even sent the same question and pictures to Vans and they didn't even answer yet. Anyway, on page 10-13 steps 4, 6, and 7 we are instructed to drill the end holes of each piece to #12's into the longerons. What is the proper, or acceptable hole clearances (to the edge of the longerons)??? Mine range from 1/4" to 1/8 inch on the closest ones. Is this an acceptable distance or do I need to get new longerons and start over???
Thanks in advance,
Bill Britton
RV-10 Tailcone
| You should have a copy of AC43.13. It will tell you far more than you ever wanted to know about different construction materials and how to work with them.
Go to http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument&Highlight=43
(you may have to cut and paste .... I haven't mastered 'small URL' yet) and look in chapter 4 ...... 4-57 to be more exact, and you'll find metal repairs .... and a whole lot more. AC43.13 will be almost (I did say almost) as valuable as a set of plans or an extra set of hands. Trust me.
Linn
Do not archive ...... which was missing from the original message.
Tim(at)MyRV10.com Guest
Posted: Fri Feb 17, 2006 10:19 am Post subject: Tailcone longeron hole clearance --one more time |
I guess I have the question of: Do you think you can do it
better the 2nd time around? If so, it may not be a bad
thing to rework. See if you're able to move things around
so that the next longeron would be drilled better. Then
you at least know if that option will help.
Thanks in advance,
Bill Britton
RV-10 Tailcone
ninepapa(at)bendbroadband Guest
Posted: Fri Feb 17, 2006 10:23 am Post subject: Tailcone longeron hole clearance --one more time |
For your reference here is how mine came out. The outside edges of the deck were lined up flush with the outside edges of the longerons, not the skins.
If the holes were moved outward much more the might be a problem with the washer under the nut seating properly because of the radius of the extrusion.
[img]cid:000b01c633ef$131ce960$640fa8c0(at)hb2tl21[/img]
86.93 KB |
543 Time(s) |
