jfitzsy(at)stny.rr.com Guest
Posted: Wed Aug 08, 2007 8:19 am Post subject: Gonna be flyier |
Gettin a Firestar II hopefully on Sunday. Has Cayuna, ULII-02. Seems to run fine-- been sittin a couple years. Need to find where to buy pins and keeper clips for wings and struts etc. Also where to find best fuel lines and clamps. Lines are hard and cracked.
Life long dream- had to wait till mid 50's to start. Wife harpin about insurance, Will an all that stuff. Jut wantin to jump in it an teach myself to fly it. Even built a strip, bout 700'. Real bad case of the itch.
captainron1(at)cox.net Guest
Posted: Wed Aug 08, 2007 8:31 am Post subject: Gonna be flyier |
Good for you
most here are of the older generation.
just make sure you get good 2 cycle oil, and be rather richer with the ratio than poorer with the ratio, a bit more oil is better than a bit less oil in the mix. Ace hardware has pins, or if you want aircraft quality go to aircraftspruce.com.
kugelair.com
Posted: Wed Aug 08, 2007 9:04 am Post subject: Gonna be flyier |
We have an Ace hardware here, an since you mentioned them 1st maybe dont
need ones with the A on end. 1/4" pins any way. Dont know the mix ratio (no
book) an no response from Kolb Co. Hey what about the keeper clips. Thanks
fer response. New to list.
d-m-hague(at)comcast.net Guest
Posted: Wed Aug 08, 2007 9:08 am Post subject: Gonna be flyier |
At 12:30 PM 8/8/2007, Ron wrote:
| Quote: | ...Ace hardware has pins, or if you want aircraft quality go to
aircraftspruce.com.
Yikes! You DON'T want to buy wing attach pins from a hardware store!
-Dana
"The budget should be balanced, the Treasury should be refilled, public
debt should be reduced, the arrogance of officialdom tempered and
controlled, and the assistance to foreign lands should be curtailed lest
Rome become bankrupt" -Cicero, 68 B.C.
At 12:18 PM 8/8/2007, James Fitzsimmons wrote:
| Quote: | | Gettin a Firestar II hopefully on Sunday. Has Cayuna, ULII-02. Seems to run fine-- been sittin a couple years. Need to find where to buy pins and keeper clips for wings and struts etc. Also where to find best fuel lines and clamps. Lines are hard and cracked. |
A Firestar with a Cuyuna??? Doesn't sound right.
Aircraft Spruce for hardware. There are less expensive places but AS is super easy to deal with.
| Quote: | | Life long dream- had to wait till mid 50's to start. Wife harpin about insurance, Will an all that stuff. Jut wantin to jump in it an teach myself to fly it. Even built a strip, bout 700'. Real bad case of the itch. |
If you're talking about life insurance, get it BEFORE you fly at all, then the rate's locked in. Try getting it after you're flying, the rates will double.
-Dana
Rome become bankrupt" -Cicero, 68 B.C. [quote][b]
jindoguy(at)gmail.com Guest
Posted: Wed Aug 08, 2007 9:34 am Post subject: Gonna be flyier |
You can get circular safety clips from McMaster.com.
Rick
On 8/8/07, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:[quote] At 12:18 PM 8/8/2007, James Fitzsimmons wrote:
-Dana
Rome become bankrupt" -Cicero, 68 B.C. [quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Posted: Wed Aug 08, 2007 9:51 am Post subject: Gonna be flyier |
If you don't go out and get EXPERT ultralight training, BEFORE you try to
fly your own, you will most likely end up as a statistic. Simply put: You
could die, or be severely injured, without proper training.
Use ONLY aircraft hardware in an aircraft. No matter how flimsy,
light-weight, or basic an "Ultralight" is, it is STILL an aircraft! When a
bolt or pins gives out, the end result will NOT be good! The testing and
manufacturing processes for "AN" and "MIL" spec hardware are far superior to
anything you can buy at a hardware store.
Time, and time again, guys go out and get "Ultralights (and hang gliders,
too)" and since there is no "license" required, they interpret that to mean
"NO (formal)TRAINING REQUIRED." They strap themselves in, and go blasting
off into the wild blue yonder, and in many cases...CRASH HARD!!!
And then the News comes along, and says "Damn, those Ultralights (hang
gliders) sure are UNSAFE!!"
Please do yourself, and all of us a big favor. Get proper training, and
use only quality aircraft parts to build your airplane. Fly solo if, and
when, your Instructor says you're ready. And, then go have fun!
Mike in SW Utah
PS. One of my favorite saying goes something like this; "Flying is NO
more unsafe than many other activities, however, it is incredibly
UNFORGIVING of mistakes."
| Quote: | From: "James Fitzsimmons" <jfitzsy(at)stny.rr.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Gonna be flyier
Date: Wed, 8 Aug 2007 12:18:50 -0400
Now you can see trouble…before he arrives
http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_protection_0507
Arksey(at)aol.com Guest
Posted: Wed Aug 08, 2007 10:21 am Post subject: Gonna be flyier |
I second what mike told you....also call the Kolb factory you can get a lot of the stuff you would need from them. There Ph is 606-862-9692.
jim swan firestar ll 503 N663S Michigan
Kolb-List message posted by: "Mike Welch" <mdnanwelch7(at)hotmail.com>
beauford173(at)verizon.ne Guest
Posted: Wed Aug 08, 2007 10:50 am Post subject: Gonna be flyier |
James...
Congratulations on your Firestar...
Some free advice: Listen to what the experienced guys on this list are telling you.
-- Get yourself training... That thing is an airplane, not a bicycle. It can easily kill you or maim you, and if
you try to "teach yourself" there is roughly a 50-50 chance it will.
-- No hardware store junk...(see paragraph above). Fasten your aircraft together with aircraft parts.
Welcome to aviation.
Worth what ye paid fer it...
Beauford
Firefly 076 - N173BW
Brandon, FL
DO NOT ARCHIVE
Posted: Wed Aug 08, 2007 11:25 am Post subject: Gonna be flyier |
James
I would like to third what Mike said. Also that isn't a ultralight! it is a real airplane and as such needs to flown by a licensed pilot or signed off student. Also you will want to get the airplane registered. If you want to register it as a light sport time is running out so you may want to spend your time getting that done. After 12/31/07 you will not be able to get it registered and you will be flying a illegal airplane.
As for your wife's concern the airframe if built properly and maintained properly is not going to let you down if YOU are up to the task and you will be with training. The engine is a bit of a concern because it has a bad history. If you fly it always were you have a safe landing area with in gliding range it can be fairly safe and fun but you will want to be looking in to a better engine at some point. Also for learning purposes that 700 ft strip is a bit short.
My $.02 worth
Rick Neilsen
Redrive VW Powered MKIIIC
Posted: Wed Aug 08, 2007 11:30 am Post subject: Gonna be flyier |
I would feel pretty good with the grade 8 hardware, they should have everything you need.
But before you do that go check out Aircraft Spruce for the AN type stuff, they have a nice online catalog and it ain't that expensive.
I use Ace hardware grade 8 or SS type fasteners. Make sure its grade 8 nothing less.
Ron
Posted: Wed Aug 08, 2007 11:58 am Post subject: Gonna be flyier |
Ron
Careful out there with that advice. Grade 8 bolts are very strong but are
also kind of brittle. It really depends on where you are using them and what
is called for. Are they Chinese made? Can you be assured they are what they
say they are?
Don't use anything but aircraft grade stuff in a airplane.
Rick Neilsen
Redrive VW powered MKIIIC
flymichigan(at)comcast.ne Guest
Posted: Wed Aug 08, 2007 12:30 pm Post subject: Gonna be flyier |
I apologize in advance for the condescending tone of this email, but why in the hell would anyone use grade 8 bolts to attach wings to an airplane. AN hardware is designed to bend if it takes on too much stress. A grade 8 bolt is likely to brake if subjected to the kinds of loads that turbulence and added g's that we ask of those connections. Hard=Brittle
Please do not use these on your plane. If you decide to, please don't fly over my house!!!
Bryan Dever
-------------- Original message ----------------------
you need.
less.
Ron
ElleryWeld(at)aol.com Guest
Posted: Wed Aug 08, 2007 4:53 pm Post subject: Gonna be flyier |
Welcome to the Kolb list and Good luck with your new toy You cant buy a better little airplane anywhere but Personally I would get aircraft pins from Aircraft Spruce or Wicks Aircraft especially if there holding your wings in place wouldnt want you to get hurt using inferior hardware
its only worth what you paid for it its your call
Ellery in Maine
pj.ladd(at)btinternet.com Guest
Posted: Thu Aug 09, 2007 8:13 am Post subject: Gonna be flyier |
Jut wantin to jump in it an teach myself to fly it. >>
James,
we all started out like that , full of enthusiasm and `get up and go`. Of all the people on this list and the many pilots I have met I only know one person who actually taught himself to fly and live to tell the tale.
You `other half` is absolutely right to be going on about insurance, but no insurance company in the world will pay out on an illegal pilot. That is what you will be if you try to fly without proper lessons and a licence.
Dont be a fool. .Flying is a great sport but it is not worth getting yourself killed.
Wise up
Pat
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Aug 09, 2007 11:39 am Post subject: Re: Gonna be flyier |
I echo all those warnings.
Use AN(Aircraft) Quality hardware EVERYWHERE since that minimal investment will pay back by allowing your aircraft to withstand the loads it was designed for.
Otherwise you are making weak points that will likely get you killed, or worse you'll live and then the wife will kill you SLOWLY!
You have waited this long, its better you do it right so you can succeed with your dreams.
That goes for training also. Getting to the point where you can Solo take-off, cruise and Land any kind of aircraft will get you off to a good start with an Ultralight.
Untrained New pilots ALWAYS eventually respond incorrectly on the flight controls, thats why training is required.
If you are wrecking your own aircraft on every flight, assuming you live, and have to repair it each time, does that sound like fun???? NO!
Go get trained and THEN enjoy your new Ultralight.
Ray
PS: I told one guy that I would sell my Lazair to him AFTER he got some training.....he cleared a 1000' strip on his farm and wanted to fly. He is still alive to this day and has put off his flying ambitions until he gets some training.
I know another guy who had about 5 hours training in Cessna's and took his Lazair ultralight out and destroyed the wing on his attempted take-off.
(He attempted a X-wind takeoff in to strong conditions for his skill level)
He has not flown in several years because the rebuild has taken all the fun out of his dream to fly, plus he is now a little scared to fly.
Its better to get sufficient and relavent training!
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
russ(at)rkiphoto.com Guest
Posted: Sun Aug 12, 2007 11:09 am Post subject: Gonna be flyier |
Well said, Pat!!
On Aug 9, 2007, at 12:05 PM, pat ladd wrote:
[quote]Jut wantin to jump in it an teach myself to fly it. >>
James,
Wise up
Pat
Posted: Sun Aug 12, 2007 1:27 pm Post subject: Gonna be flyier |
Hi Russ,
I reckon this flying game is difficult enough when you have been taught properly let alone doing it with no training.
I have had my plane back about 3 weeks now. Still waiting for paperwork clearance to test fly. In the meantime I have been trying to sort out where the radio goes, ariel etc and rigging up a pulley system to enable me to back the machine into my hangar singlehanded. Unlike the Challenger there are no metal bits to grab hold of to push the plane about. I can get her out by pushing on the prop hub. Going backwards is the problem. I have also been reaquainting myself with the joys of taxying a tail dragger. Surprising what you forget after a years lay off. I managed a downwind taxy in a stiffish breeze, only having to do a 360 once but I dropped the starboard wheel in a hole just as I gunned the engine to turn into wind. You guessed. The wheels went nowhere and the nose went down and I managed to side swipe the pitot tube before I could cut the throttle. I could see the sense of the hoops some people fit under the nose cone. No fibreglass damage but I have to find a small boy I can stuff inside the nose cone with a spanner to unbolt the pitot fitting. I am too big and too stiff in the joints to get in there myself.
Happy sailing
Pat
Richard Pike
Posted: Sun Aug 12, 2007 2:11 pm Post subject: Re: Gonna be flyier |
Hi Pat, here is our attempt at a pulley system. This allows me to pull the MKIII up a slight incline that is barely possible unassisted. Ed uses a similar system on his FSII, and since his airplane is a bit lighter, his pull is easier.
The clamps are simple. On mine, axle extensions with holes bored in the flat stock to slip over the the extensions. For Ed's - a bolt at either end of the clamp bracket to stick in the tube of the stock Kolb tailwheel assembly.
You will need at least 100' of rope.
Richard Pike
MKIII N420P (420ldPoops)
131.56 KB |
289 Time(s) |
144.47 KB |
282 Time(s) |
156.56 KB |
272 Time(s) |
170.45 KB |
285 Time(s) |
planecrazzzy Guest
Posted: Sun Aug 12, 2007 3:01 pm Post subject: Re: Gonna be flyier |
Hey Guys,
I'll add a little local story....
Old "Goat" , Ray Lejeune built a Firestar ( with Help )
Had 5 hrs training in a Cessna 150.....and thought that was enough...
Ground looped his plane a few times , ( Lucky to be alive )
Wrecked his plane so bad that he had to scrap it....
He NEVER got it into the air......Probly would have been in BIG trouble
if he did....
Ralph Burlingame Bought the engine (477) off it.....
Gotta Fly...
Mike & "Jaz" in MN - FSII/N381PM
Private Pilot w/ Taildragger endorsement & 5 hrs in "Like" Aircraft
