Rivnut question
occom
PostPosted: Wed Aug 08, 2007 2:16 am    Post subject: Rivnut question Reply with quote
I've seen rivnuts in 6-32 and they look awfully big to sneak into the rib
capstrip. Has anyone got pictures of this installation?
Dave Goddard- Mod IV 1050/582
lcfitt(at)sbcglobal.net
PostPosted: Wed Aug 08, 2007 6:32 am    Post subject: Rivnut question Reply with quote
Dave,
Maybe when saying rivnuts, some mean to say nut plates. That is the way I
will go when I do my next replacement. I find rivnuts a bit more challenging
than nutplates and thickness of the material matters. I don't know how a
rivnut would work with a backing and a 1/8" capstrip.
If anyone has actually used rivnuts, how did you do it.
Lowell
john(at)leptron.com
PostPosted: Wed Aug 08, 2007 2:28 pm    Post subject: Rivnut question Reply with quote
Lowell,
I used ruvnuts on my bubble door and my windshield, they sale keyed and
unkeyed, there is a tool that you insert into the drilled hole and pull the
leaver much like a rivet gun. It cuts the keyway for the rivnut. You then
install the rivnut and use the squeeze tool, again much like a rivet gun and
it pulls and wrinkles the rivnut to the needed thickness. If I remember
right the rivnut come in varying thickness again like rivets.
My windshield and several other attachments are done using rivnuts.. I will
continue using them in other projects.
John Oakley
Fox5flyer
PostPosted: Wed Aug 08, 2007 4:11 pm    Post subject: Rivnut question Reply with quote
For the windshield I used #6-32 SS panhead screws with nylock nuts. I can't
remember the part number but you can get the nuts that are about half the
thickness of regular nylock nuts. No washers necessary. Very simple
install and no need to buy any special tools (rivnut installer).
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 359+ TT
"If you don't read the newspaper you are
uninformed, if you do read
the newspaper you are misinformed."
Mark Twain
Float Flyr
PostPosted: Thu Aug 09, 2007 3:25 pm    Post subject: Rivnut question Reply with quote
John:
I think on GA aircraft riv nuts are allowed in basically non-structural applications. This however is not GA but we want out planes to be safe. I expect a riv nut will be safe in any application where you would use a blind rivet. It's a great idea for installing glass.
[img]cid:457200623(at)09082007-1F87[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  368 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dcaofak(at)acsalaska.net
PostPosted: Fri Aug 10, 2007 11:42 am    Post subject: Rivnut question Reply with quote
I used #8 rivnuts to attach the wingtips. A dab of the rib to spar epoxy mix under the rim of the manufacturer's head to prevent twisting. An aluminum washer under the shop head, slightly flattened on the side next to the rib flange, to provide a larger rivet to wood contact surface. Has been fine for the last 14 years. Dragged a wing tip once and the rivnuts held up just fine, and made removal of the tip for repair a simple task.
John Stoner
KF III, 582
Alaska
torgemor(at)online.no
PostPosted: Fri Aug 10, 2007 1:49 pm    Post subject: Rivnut question Reply with quote
Hi Folks,
Lowell is very right (as usual), rivenuts is really not meant for
"primary" structure attachment (ref. standard practice), -nutplate is the
answer -and maybe the kind with floating nut.
Torgeir.
Kitfox Model II, 1993
Engine: Rotax 532 with B gearbox
Propeller: IVO UL 366Q
Tromsoe
NORWAY.
Weather in Tromso right now:
http://met.no/troms/index.html
City map of Tromso:
http://www.avinor.no/English/Airports/Tromso_Airport/?module=Articles;action=ArticleFolder.publicOpenFolder;ID=1453
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
On Wed, 08 Aug 2007 16:31:50 +0200, Lowell Fitt <lcfitt(at)sbcglobal.net>
wrote:
Dave,
I will go when I do my next replacement. I find rivnuts a bit more
challenging than nutplates and thickness of the material matters. I
don't know how a rivnut would work with a backing and a 1/8" capstrip.
Lowell
