DOUGPFLYRV(at)aol.com Guest
Posted: Thu Feb 16, 2006 5:46 pm Post subject: RV-7 Defog fans |
Someone requested photos of defog fans. Not much to see. Attached to glare
shield...no ducts, just cabin air sucked under panel.
DO NOT ARCHIVE
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Thu Feb 16, 2006 9:35 pm Post subject: RV-7 Defog fans |
I installed two small (2-1/4") computer fans on the glare shield of my
slider equipped 6a.
I mounted the fans on approximately 3-1/2" x 3" rectangles of .032 aluminium
sheet material. The squares have small tabs bent on the front edge that slip
into and under the slightly smaller dimensioned glare shield fan openings. A
6-32 plate nut at the rear edge of the opening allows the fans to be held in
place with one screw each. Remove screw, tilt up the fan and lift it out. A
short wire with an insulated spade connection allows for disconnection. Some
screen material over the fan opening makes them look good and should keep
junk out of the fans. A small switch on the panel handles the small current
required
As described below no ducting etc. needed. This aircraft has yet to fly so
actual defog performance is as yet an unknown.
Pictures available on request.
I think this would be somewhat harder to do with the tip up canopy.
Jim in Kelowna
_________________ "I never make mistreaks" |
Gerald Richardson
Joined: 11 Jan 2006 Posts: 7 Location: Medicine Hat, Alberta
Posted: Thu Feb 16, 2006 10:17 pm Post subject: RV-7 Defog fans |
_________________ RV6A |
highflight1(at)gmail.com Guest
Posted: Fri Feb 17, 2006 4:23 am Post subject: RV-7 Defog fans |
Using a defogger is something I've given thought to, but am not sure how
necessary it really is.
I'd like to hear from frequent flyers who have NO defogging installed and
get some reports about them ever wishing they had them.
Vern W.
alexpeterson(at)earthlink Guest
Posted: Fri Feb 17, 2006 5:44 am Post subject: RV-7 Defog fans |
not sure how necessary it really is.
installed and get some reports about them ever wishing they had them.
Vern W.
Vern, I am not sure why you only wanted those without fans to answer...mine
doesn't have fans until I turn them on:
) The need depends upon the
temperature and whether or not there are two people on board. If the OAT is
at or below about 10F, and the ground ops time is more than 5 minutes, you
will have a frosted up windscreen. Noticably faster with two on board. It
will clear up after several minutes in flight. There have been takeoffs
that I would not have been able to make without the fans. Both fans are
directed at the pilot's side, and the copilot's side has been completely
obscured. So, the necessity is totally dependent upon the OAT that you plan
to taxi in. Another option is to keep the canopy cracked open while
taxiing, something I've not found comfortable at all. Most GA pilots do not
fly when the temps are in the 10F and below range, based upon my
observations.
Alex Peterson
RV6-A N66AP 714 hours
Maple Grove, MN
ronlee(at)pcisys.net Guest
Posted: Fri Feb 17, 2006 6:27 am Post subject: RV-7 Defog fans |
At 05:17 AM 2/17/2006, you wrote:
800 hours in three years and no need for it.
Caveat: I live in a dry climate.
Ron Lee
Knicholas2(at)aol.com Guest
Posted: Fri Feb 17, 2006 10:41 am Post subject: RV-7 Defog fans |
I put 2 computer cooling fans in my RV9A. Here in the damp Seattle area it
does help to defrost the windshield. Another great benefit is that it draws
warm air off the radio stack to keep the radios cool. I run the fans all the
time for the radio cooling.
Kim Nicholas
Auburn, WA
RV9A 77 hours!
Al.Herron(at)Aerojet.com Guest
Posted: Fri Feb 17, 2006 3:16 pm Post subject: RV-7 Defog fans |
I've placed a similar fan to circulate air around my avionics stacks to try
to provide a little cooling. I've yet to wire up and test the avionics, and
I'm concerned about electrical noise from the fan motor. Does anyone have
any experience with a similar setup?
Al Herron
WPAerial(at)aol.com Guest
Posted: Fri Feb 17, 2006 7:34 pm Post subject: RV-7 Defog fans |
i put two computer cooling fans in to defog.
no noise.
but they were a waste of time. don't really need them. a soft towel works
better. after you get going the fog is gone.
Jerry wilken
rv6a
n699wp
rv6n6r(at)comcast.net Guest
Posted: Fri Feb 17, 2006 11:11 pm Post subject: RV-7 Defog fans |
| Quote: | > I'd like to hear from frequent flyers who have NO defogging
Okay that's me.
I built a "defroster vent" into the glareshield with a duct routed to it.
The tube goes down and just kind of hangs there next to where the heat inlet
is thru the firewall. Seemed like a good idea at the time but in fact it
doesn't do a damn thing. In the winter I get fogged plexi fairly often and
sometimes it stays fogged once I get flying unless I open the cold air
vents.
I keep meaning to either 1) plumb the SCAT tube so the heat inlet blows more
directly into the glareshield duct or 2) put a fan in there. But 5 years and
750 hrs after first flight I can't seem to get around to it... too many
other fun things to do (like go flying!)
Randall Henderson
RV-6
highflight1(at)GMAIL.COM Guest
Posted: Sat Feb 18, 2006 5:19 am Post subject: RV-7 Defog fans |
Thanks Randall, that kind of says it all. If you've been "meaning" to
install a defog system, but haven't in over 750 hours of flying, then I
think when it comes right down to it, a defogger simply that much of an
importance.
A soft rag tucked into a side pocket seems to be plenty good for the purpose
for those times when called for.
Vern W.
On 2/18/06, randall <rv6n6r(at)comcast.net> wrote:
Okay that's me.
more
and
Randall Henderson
RV-6
Posted: Sat Feb 18, 2006 10:20 am Post subject: RV-7 Defog fans |
"meaning" to install a defog system, but haven't in over 750
hours of flying, then I think when it comes right down to it,
a defogger simply that much of an importance.
for the purpose for those times when called for.
Vern W.
Vern, there are people who don't ever use the heaters in their cars either,
as they live in warm climates. To repeat my previous post, if you taxi in
OAT's at or below about 10F, you will either need to leave the canopy
cracked open or have some sort of defrost system. A rag will not clear
frost. Everything depends on the temperatures where you live or plan to
fly.
Alex Peterson
RV6-A N66AP 712 hours
Maple Grove, MN
stein(at)steinair.com Guest
