bill(at)vondane.com Guest
Posted: Tue Aug 07, 2007 8:12 am Post subject: Infinity stick grips |
Anyone else pull their hair out trying to find anything on the infinity
web site?
I could use a wiring diagram for the infinity stick grips if anyone has
it...
Thanks!
-Bill
bill(at)vondane.com
Tailgummer(at)aol.com Guest
Posted: Tue Aug 07, 2007 8:56 am Post subject: Infinity stick grips |
Don't know if the pdf attachments will go through. All of the information is on the website, though. Once you go through the diagrams it all begins to make sense. If you can't get these, mail me off line.
Love this grip!!
John D'Onofrio RV8 N585JD
(Tailgummer(at)aol.com (Tailgummer(at)aol.com))
AOL.com.
159.6 KB |
275 Time(s) |
bicyclop(at)pacbell.net Guest
Posted: Tue Aug 07, 2007 9:05 am Post subject: Infinity stick grips |
Bill VonDane wrote: | Quote: | --> RV-List message posted by: Bill VonDane <bill(at)vondane.com> (bill(at)vondane.com)
Anyone else pull their hair out trying to find anything on the infinity web site?
I could use a wiring diagram for the infinity stick grips if anyone has it...
Thanks!
-Bill
bill(at)vondane.com (bill(at)vondane.com)
| http://www.infinityaerospace.com/gripwire.pdf
It's not a diagram, but it does show all the possible switch configurations and wire colors. You can easily verify the wires to the correct switches with an ohmmeter. I printed it out and highlighted the switches and wire colors for easy ID.
Pax,
Ed Holyoke
cbrxxdrv(at)aol.com Guest
Posted: Tue Aug 07, 2007 9:17 am Post subject: Infinity stick grips |
They are made to order and should come with a diagram. Get out your ohm meter
and do a little testing and it will all make sense. Some of the switches are momentary, some are normally open some are flap switches some are....well you get the idea. If you contact
them you may find he has a record of it and can send/fax you a copy.
Sal
N898SC RV8 Done
Lakeland FL
Carl
Posted: Tue Aug 07, 2007 11:27 am Post subject: Infinity stick grips |
How much are these now and who handle them?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tailgummer(at)aol.com
Sent: Tuesday, August 07, 2007 12:55 PM
To: rv-list(at)matronics.com
Subject: Re: Infinity stick grips
Love this grip!!
AOL.com.
_________________ Carl Bell
Building N947CB
RV 7A |
Posted: Tue Aug 07, 2007 12:45 pm Post subject: Infinity stick grips |
Sal
robin1(at)mrmoisture.com Guest
Posted: Tue Aug 07, 2007 1:15 pm Post subject: Infinity stick grips |
The basic grip went from $150 to $175 recently. The seller had not raised his pricing in 10 years.
One has to consider adding additional cable and any other custom item but of the 4 units I have ordered they all came in at just over the base price.
Rather than using his online or fax order system I always call. It simplifies all the research required to order exactly what you need (spacers etc…)
I am very happy with my Infinity grips.
Robin
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] Ontom Behalf Of Carl Bell
Sent: Tuesday, August 07, 2007 12:26 PM
Subject: RE: Infinity stick grips
Love this grip!!
AOL.com.
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Aug 07, 2007 10:38 pm Post subject: Infinity stick grips |
In a message dated 8/7/2007 4:17:02 PM Central Daylight Time, robin1(at)mrmoisture.com writes:
| Quote: | | One has to consider adding additional cable and any other custom item but of the 4 units I have ordered they all came in at just over the base price. |
I highly recommend ordering a lot of extra cable length- I ordered direct from ACS and the cable length was pretty skimpy. Probably better to get direct from Infinity. Also be very cognizant of which pushbuttons are included, such as momentary or on-off-on...
Mark
_________________ From The PossumWorks... |
