Gas Gauge intermittent
nick(at)container.com
PostPosted: Tue Aug 07, 2007 8:44 am    Post subject: Gas Gauge intermittent Reply with quote
Dear Commander Owners:
I am having continual problems with intermittent readings of the fuel gauge on my 1974 690 A ( serial 11226 ) ….I know there is a $26,000 fix but hoping there is a better way….anyone know of a fix to the problem ?
Nick Martin N690DB
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe - Ross Racing Pistons
Sent: Tuesday, August 07, 2007 7:27 AM
Subject: RE: Commander-List: Outflow Valve
Jerry,
Thanks for the tip, I will contact Gary.
Regarding the oil pressure problem. It is generally accepted that the oil pumps on the IGSO 540 series are too small. I can’t remember the GPM (gallons per minute), however, this has been, as I understand it, a long standing problem. Once the pump has in-adequate volume, no amount of spring shimming will raise the oil pressure. Some suggestions:
  1. Have you checked the accuracy of your oil pressure gage? (Laugh, but I have heard some real horror stories)
  2. Screw an oil pressure gage into the oil galley at the front of the engine and compare the oil pressure on the two gages. Lycoming has a maximum differential that is acceptable, again, I can’t remember what it is, but will look it up for you if necessary.
  3. Will the oil pressure stay in the green while in flight?
  4. Will the engine maintain a minimum of 35 PSI at hot idle and about 1,500 RPM (minimum for the fuel pump computer to work)?
Moe
N680RR
680F(p)
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jerry Sprayberry
Sent: Tuesday, August 07, 2007 3:54 AM
Subject: Re: Commander-List: Outflow Valve
Moe,
Mine were replaced at Commander Aero, you might check with Gary.
Another Subject;
Has anyone had any trouble with IGSO 540 Oil Pressure, I bought a New Rebuilt Engine by Performance Engines and it came with (7) Seven Washers under the Pressure Regulator but still cant get but 53 psi after warm-up. any suggestions will be appreciated.
Jerry
 Filesize:  7.29 KB
 Viewed:  1802 Time(s)
bobf(at)feldtman.com
PostPosted: Tue Aug 07, 2007 12:12 pm    Post subject: Gas Gauge intermittent Reply with quote
A wooden dipstick and a watch?
bobf
On 8/7/07, Nick Martin <nick(at)container.com (nick(at)container.com)> wrote: [quote]
Nick Martin N690DB
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com)] On Behalf Of Moe - Ross Racing Pistons
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Subject: RE: Outflow Valve
Jerry,
Regarding the oil pressure problem. It is generally accepted that the oil pumps on the IGSO 540 series are too small. I can't remember the GPM (gallons per minute), however, this has been, as I understand it, a long standing problem. Once the pump has in-adequate volume, no amount of spring shimming will raise the oil pressure. Some suggestions:
  2. Screw an oil pressure gage into the oil galley at the front of the engine and compare the oil pressure on the two gages. Lycoming has a maximum differential that is acceptable, again, I can't remember what it is, but will look it up for you if necessary.
Moe
N680RR
680F(p)
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com)] On Behalf Of Jerry Sprayberry
Subject: Re: Outflow Valve
Moe,
Another Subject;
Jerry
 Filesize:  7.29 KB
 Viewed:  1800 Time(s)
