Fuel Filter
coop85(at)cableone.net
PostPosted: Sun Aug 05, 2007 7:33 am    Post subject: Fuel Filter Reply with quote
I was wondering if anyone has any tricks/tips on cleaning the standard fuel
filter in the tunnel. Primarily how to remove it without dumping fuel and
the best way to clean it.
Marcus
40286
Ray.R.Doerr(at)sprint.com
PostPosted: Mon Aug 06, 2007 5:17 am    Post subject: Fuel Filter Reply with quote
Just run the engine and then turn the fuel selector off and wait for the engine to quit. Then fold up about 6 or so paper towels and place then under the connections of the fuel filter, then simply remove the filter. It is not a tough job, just a pain taking off all the screws to get at the tunnel, but then you have to do it anyway to see the rest of the stuff anyway. I had lint mostly in my filter. Very easy to clean and re-install.
Thank You
Ray Doerr
40250
N519RV (Hobbs = 295)
greghale
PostPosted: Mon Aug 06, 2007 6:37 am    Post subject: Re: Fuel Filter Reply with quote
I mounted my fuel filter vertical. I used this same installation on my RV8 and it work great. The fuel filter is removed from the top. I shut off the fuel valve before removal and no spills.
Greg...
nwacaptain.com
 Filesize:  291.24 KB
 Viewed:  441 Time(s)
Greg Hale rv10 -- N210KH
www.nwacaptain.com
