Wing strut vibration
lcottrell
PostPosted: Wed Aug 01, 2007 2:41 pm    Post subject: Wing strut vibration Reply with quote
I am getting a rhythmic vibration in my wing struts. I had never noticed until I began trying to video out of the plane. I can stop it by putting my hand on the strut. It is my understanding that TNK has stream lined struts now. Will they stop this strumming? Any help would be appreciated.
Larry C
jbhart(at)onlyinternet.ne
PostPosted: Wed Aug 01, 2007 3:04 pm    Post subject: Wing strut vibration Reply with quote
Larry,
The answer is yes. I streamlined the struts on the FireFly.
See:
http://www.thirdshift.com/jack/firefly/firefly91.html
Jack B. Hart FF004
Winchester, IN
lcottrell
PostPosted: Wed Aug 01, 2007 3:23 pm    Post subject: Wing strut vibration Reply with quote
I actually have plastic streamlined fairings for the original round struts.
They perhaps are not aligned at the correct angle. Your finding was 6
degrees. The wing is 9 degrees at flight stance. Would this be 6 degrees at
flight stance?
Larry C
See:
Jack B. Hart FF004
Winchester, IN
PostPosted: Wed Aug 01, 2007 5:30 pm    Post subject: Wing strut vibration Reply with quote
flight stance?
Larry,
I built a meter (http://www.thirdshift.com/jack/firefly/firefly55.html) so I
could determine the FireFly angle of attack at cruise. It came out at six
degrees, ans so that is what I used. The basic configuration has not
changed for some time and can be seen on the bottom of:
http://www.thirdshift.com/jack/firefly/firefly.html
The only angle in doubt is thrust angle. I may have changed it and not up
dated the drawing.
Jack B. Hart FF004
Winchester, IN
Do not archive.
PostPosted: Wed Aug 01, 2007 5:39 pm    Post subject: Wing strut vibration Reply with quote
flight stance?
Larry,
I have thought about this some more. You are able to put much in much more
power and speed into the strut than I can with my FireFly. Do you notice if
the strumming goes away when you slow down to say 60 mph? If so there is a
good chance the preformed/shaped aluminum struts may do the trick. They
should have higher stiffness.
Jack B. Hart FF004
Winchester, IN
Do not archive.
gaman(at)att.net
PostPosted: Wed Aug 01, 2007 6:04 pm    Post subject: Wing strut vibration Reply with quote
John Williamson
PostPosted: Wed Aug 01, 2007 6:41 pm    Post subject: Re: Wing strut vibration Reply with quote
Larry and All,
I had the same lift strut harmonic vibration on the Kolbra when I did the first few flights without the streamlined plastic fairings on. It would only occur at a very narrow airspeed band about 90 mph. I installed the TNK fairings and have never had the vibration again.
As for the angle the fairings were set at, I just eyeballed them to an angle that looked okay.
John Williamson
Arlington, TX
Kolbra, 912ULS, 1,463 hours and counting
John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot
lcottrell
PostPosted: Wed Aug 01, 2007 8:18 pm    Post subject: Wing strut vibration Reply with quote
My vibration is in the 56 to 64 MPH range, or most likely all through all
the speed that I can stay in the air. I notice it most in the 6000 rpm
range. I also had it without the plastic cover so I am sure that it is just
that the round struts do not have the rigidity that the streamlined metal
ones do. Thanks for the help. Now for some creative financial planning.
Larry C
jindoguy(at)gmail.com
PostPosted: Thu Aug 02, 2007 8:00 am    Post subject: Wing strut vibration Reply with quote
Larry, The Challenger II I have in the shop has the plastic fairings filled with insulating foam and attached with two small screws at each end. No harmonics anywhere in the speed range of 40 to 80.
Rick
On 8/1/07, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:[quote] --> Kolb-List message posted by: "Larry Cottrell" <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)>
Larry C
JetPilot
PostPosted: Thu Aug 02, 2007 11:30 am    Post subject: Re: Wing strut vibration Reply with quote
[quote="lcottrell"]I am getting a rhythmic vibration in my wing struts. I had never noticed until I began trying to video out of the plane. I can stop it by putting my hand on the strut.
Larry C
Be very careful with that vibration, that can fatigue the ends to the point of failure. It would take many hours, but sooner or later something is going to let to, either the strut end, or the place on the wing that it attaches to.
My friend was flying a Flybaby, where a streamlined flying wire underneath the wing had a high frequency vibration. It flew hundereds of hours like that until one day it finally fatigued enough to break in the pattern on downwind. The wing came off, fortunately my friend had a parachute on, and was thrown out of the plane as soon as he released his belt. Those high frequency vibrations that you can not feel can be very bad.
JettPilot
Kolb MK-III Xtra, 912-S
lcottrell
PostPosted: Thu Aug 02, 2007 7:48 pm    Post subject: Wing strut vibration Reply with quote
That sounds like a good idea, but I am curious as to how you got the foam all through the plastic fairing. Possibly easier than I think, but I am used to things being harder than they sound.
Larry C
gaman(at)att.net
PostPosted: Fri Aug 03, 2007 9:32 am    Post subject: Wing strut vibration Reply with quote
Larry, I had vibration in the struts also but they were engine or prop harmonics.Have you tried doing ground run-ups to check for this ?
Larry Cottrell <lcottrell(at)fmtcblue.com> wrote:[quote] --> Kolb-List message posted by: "Larry Cottrell"
Larry C
PostPosted: Fri Aug 03, 2007 10:08 am    Post subject: Wing strut vibration Reply with quote
Larry, I didn't build the aircraft, so I can't say for sure, but the foam in a can stuff has always spread well for me in similar applications.
Rick
On 8/3/07, gary aman <gaman(at)att.net (gaman(at)att.net)> wrote:[quote]Larry, I had vibration in the struts also but they were engine or prop harmonics.Have you tried doing ground run-ups to check for this ?
Larry Cottrell < lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:[quote] --> Kolb-List message posted by: "Larry Cottrell"
Larry C
noelbou(at)vif.com
PostPosted: Fri Aug 03, 2007 10:14 am    Post subject: Wing strut vibration Reply with quote
Hello Larry,
What about this picture ? (In attach. "shrinked to 13KB ")
But i think it's more of an optical illusion than realty ...
.. but to keep this on topic, on my Twinstar MK II
the "strut shaking" definitely is related to engine harmonics
and occurs at a rather low and quite narrow band RMP ...
so it is less of a concern ...
Noel
 Filesize:  12.95 KB
 Viewed:  523 Time(s)
Eugene Zimmerman
PostPosted: Fri Aug 03, 2007 1:03 pm    Post subject: Wing strut vibration Reply with quote
Hey,
You really ought to remove the black snake living inside that strut
and fill it with foam.
Smile
Positively do not archive.
On Aug 3, 2007, at 2:14 PM, Noël Bouchard wrote:
Hello Larry,
... but to keep this on topic, on my Twinstar MK II
Noel
> this ?
> <Struts.jpg>
huronflyer
PostPosted: Fri Aug 03, 2007 7:46 pm    Post subject: Re: Wing strut vibration Reply with quote
Hi,
I fly another ultralight.
As of today I may consider Kolb, because of some performance differences.
Please I am not trying to be a jerk; a very well know, popular ultralight had a bracket fail recently causing the stut and its other strut same side to fail.
Fortunately, they had a BRS.
I went to my planes forum and asked some heavy questions, the result was our
planes attach point is designed better and includes an aluminum/nylon plug, to
overcome unwanted over compression...an inspection of the ronnie bracket show
ed no visible fracture.
Anyhow, I am considering the purchase of a Kolb, but I know nothing about its
design integrity, i.e. struts, etc.
Would you be kind enough to give me some insight.
drh
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Sat Aug 04, 2007 5:27 am    Post subject: Wing strut vibration Reply with quote
WARNING: Strong Opinion following!!!!!!!
IMHO the Kolb, any Kolb, with it's welded cage, is the only ultralight based aircraft that's built like an aircraft and NOT like a lawn chair. There are things on my MK III that I'd like to change to get rid of some drag and make it a bit more efficient, but not enough that I'd ever consider getting rid of it.
Rick
On 8/3/07, huronflyer <herrondr(at)yahoo.ca (herrondr(at)yahoo.ca)> wrote:[quote] --> Kolb-List message posted by: "huronflyer" <herrondr(at)yahoo.ca (herrondr(at)yahoo.ca)>
Hi,
drh
"Ya'll drop on in"
takes on a whole new meaning
WillUribe(at)aol.com
PostPosted: Sat Aug 04, 2007 4:55 pm    Post subject: Wing strut vibration Reply with quote
What is a ronnie bracket?
Hi,
I went to my planes forum and asked some heavy questions, the result was our planes attach point is designed better and includes an aluminum/nylon plug, to overcome unwanted over compression...an inspection of the ronnie bracket show ed no visible fracture.
Anyhow, I am considering the purchase of a Kolb, but I know nothing about its design integrity, i.e. struts, etc.
drh
