lcfitt(at)sbcglobal.net Guest
Posted: Thu Feb 16, 2006 11:36 am Post subject: Wing Rig Alignment |
Matt,
Settling does occur. I remember checking mine every hour or so as the 3-M
structural adhesive set up and had to tweak constantly and still not
perfect.
In answer to your question, though, I suspect the only functional problem
you might see is if the rib in question is one that supports the flaperon
attach brackets. Alignment on those are pretty important. The others?
probably mostly cosmetic as gross misalignment will be visible through the
fabric.
Where are you in Fresno? Are you close to any GA airports or is FAT your
base?
Lowell
kerrjohna(at)comcast.net Guest
Posted: Thu Feb 16, 2006 12:51 pm Post subject: Wing Rig Alignment |
I remember running masking tape along the bottoms and tops to keep everything lined up until the epoxy set up.
John
-------------- Original message --------------
Matt,
perfect.
fabric.
base?
Lowell
mteixeira(at)wmlylesco.co Guest
Posted: Thu Feb 16, 2006 1:25 pm Post subject: Wing Rig Alignment |
Lowell
Thanks for your reply. You have settled my mind on my rib #2.
I'm usually based at work just 1/4 mile from FCH, Fresno's downtown
airport. Close enough to run down and take a pilot and their passenger
to lunch or to run cans to a local mogas station. Just let me know when
you are coming in. Right now, I'm 30 miles north building an Ethanol
Plant in Madera; basically a giant still on steroids. Yes, I can say
with relative certainty, that our mogas will now and forever be blended
with a percentage of ethanol.
Building my Kitfox is a dream come true. I can't wait to join the ranks
of you guys and fly a plane that you assembled yourselves.
I have to admit that I was very concerned when Skystar closed their
doors, but you and the others on this list as well as my local EAA have
kept me building and not selling.
I have a list of questions, but I'll hold back until I get closer to
those areas of the build.
Are you in Southern California or Oregon?
Matt IV-1200, Fresno, CA
