wingnut
Posted: Tue Jul 31, 2007 9:03 am Post subject: Sliding window for camera |
Anyone know of a simple way to add a small sliding window to the upper door of a kitfox? I saw a picture once where someone converted the whole top half of the door into hinged window but I was thinking of something simpler. I just need to open a whole large enough to stick the lense of a camera through. My sister wants to explore some aerial photography from my kitfox but she's too chicken to fly with the doors off (come to think of it, so am I) and I don't think she can get a good quality picture shooting through the lexan.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxmike
Posted: Tue Jul 31, 2007 9:26 am Post subject: Re: Sliding window for camera |
Slow down and open the door, ya right, I haven't done that yet, but I'm getting my nerve up, may do it yet.
wingnut
Posted: Tue Jul 31, 2007 9:42 am Post subject: Re: Sliding window for camera |
I had the passenger door pop open on me on my first solo with the Kitfox so I know it's not a big deal. My instructor was unfamiliar witht he door latch and I failed to double check that it was secure. That was the passenger door though and I had to change my shorts after as it was. I can't imagine what it would be like for my sister to hold a camera out an open door while hanging out the bottom of a turn while I try to keep the target in view.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
runwayrex(at)juno.com Guest
Posted: Tue Jul 31, 2007 10:03 am Post subject: Sliding window for camera |
I fly with doors open sometimes. Keep this in mind. Remember how the door latch didn't do its job one time? Consider what happens if the seatbelt latch doesn't hold on either (for whatever reason) while turning sharply. Just keep that in mind so you don't land with one less person on board. It's a lonely final approach!
Rex in Michigan
-- "wingnut" <wingnut(at)spamarrest.com> wrote:
--> Kitfox-List message posted by: "wingnut" <wingnut(at)spamarrest.com>
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.p================================================sp; - The Kitfox-List Email Forum -<= Archive Search & Download, 7-Day B================================================ - NEW MATRONICS WEB FORUMS&n====================================================
mlpaton2000(at)yahoo.com Guest
Posted: Tue Jul 31, 2007 10:55 am Post subject: Sliding window for camera |
Its a lot easier to take the door off , we do a lot of photography from the plane and the doors havnt been back on in 2 years , I wouldnt put my doors back on in a hurry , much prefer the rush of freedom. good luck
Michael
9J-FOX
series 5, 912 100 hp
kitfoxmike <customtrans(at)qwest.net> wrote:
[quote]--> Kitfox-List message posted by: "kitfoxmike"
kitfoxmike
model IV, 1200
speedster
912ul
building
RV7a
slowbuild wings, fuse, finish kit
"if you're not getting razzed from pilots or the FAA then you're not flying enough"
Read this topic online [quote][b]
Michel
Posted: Tue Jul 31, 2007 11:39 am Post subject: Sliding window for camera |
On Jul 31, 2007, at 8:01 PM, Rexster wrote:
| Quote: | I fly with doors open sometimes. Keep this in mind. Remember how the
.. and don't do sideslips with the doors open. I understand a member
of this list lost his turtledeck doing that once. Do I remember
correctly?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
rexinator(at)gmail.com Guest
Posted: Tue Jul 31, 2007 12:08 pm Post subject: Sliding window for camera |
A snap vent probably the simplest vent and I expect you could just leave
it out before flight to use for photos.
http://www.aircraftspruce.com/menus/ap/vents.html
Rexinator
wingnut wrote:
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Posted: Tue Jul 31, 2007 12:21 pm Post subject: Sliding window for camera |
By "leave it out" I meant "Not installed" of course!
Rex
Rexinator wrote:
| Quote: | A snap vent probably the simplest vent and I expect you could just
leave it out before flight to use for photos.
Rex Hefferan
Float Flyr
Posted: Tue Jul 31, 2007 3:17 pm Post subject: Sliding window for camera |
Flying with the door open and taking pictures is thrilling! My camera is basically a right hand operated unit so looking through the viewfinder just isn't possible. I can point in a rough direction and press the button with reasonable results. I make sure I have a strap from the camera around my neck when the door is open and there is no paper or maps out to blow around.
[img]cid:638510623(at)31072007-2E50[/img]
This picture taken out an open door of my home (with boathouse) Camera was actually held upside down and shutter was released with my thumb. Picture was later cropped and resized. Picture taken two years ago.
[img]cid:638510623(at)31072007-2E57[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
64.05 KB |
741 Time(s) |
19.77 KB |
699 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Tue Jul 31, 2007 3:27 pm Post subject: Sliding window for camera |
Slowing down is good. So is not slipping to the open door! Came close once
while step taxiing. (honest)
Fresh air is ok too. The view when the door opens!!!! Awesome!
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Jul 31, 2007 3:33 pm Post subject: Sliding window for camera |
Keep your turns coordinated and neither of you will have any problems. Fly
slow and try to fly parallel to the area photographed. If you need to go
around and fly by again. Remember most cameras are mildly wide angle which
is ok on the deck but when you're at 3-500 ft a little zoom helps. I stay
away from turns at slow speeds. I never know what I have until I get home.
Canada
Aerocet 1100s
[quote] --
Kitfox III-A
wingnut
Posted: Tue Jul 31, 2007 3:35 pm Post subject: Re: Sliding window for camera |
The snapvent idea is kind of what I had in mind but I need a larger opening. I've seen pictures of conventional airplanes with rectangular sections of window that slide open that would be perfect. I figured that I'd have to fabricate something similar but I have no idea how to go about it.
| rexinator(at)gmail.com wrote: | A snap vent probably the simplest vent and I expect you could just leave
Rexinator
wingnut wrote:
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxmike
Posted: Tue Jul 31, 2007 4:14 pm Post subject: Re: Sliding window for camera |
you mean like these:
2.76 MB |
879 Time(s) |
kitfoxmike
Posted: Tue Jul 31, 2007 4:16 pm Post subject: Re: Sliding window for camera |
only one went through
kitfoxmike
Posted: Tue Jul 31, 2007 4:25 pm Post subject: Re: Sliding window for camera |
lets try this again
44.7 KB |
691 Time(s) |
53.64 KB |
707 Time(s) |
65.98 KB |
697 Time(s) |
kitfoxmike
Posted: Tue Jul 31, 2007 4:26 pm Post subject: Re: Sliding window for camera |
You have to view the pics from bottom to top, it was an entry into runway16.
Tom Jones
Posted: Tue Jul 31, 2007 5:50 pm Post subject: Re: Sliding window for camera |
Luis, your question has got me thinking about this. There is no way my photographer (wife) is going to fly with the door open or off either. I just went out and sat on the passenger side. The place I would need a camera port is too curved for a sliding window.
I think a hinged window would work easier. Why don't you have her sit in the airplane and mark where the camera port needs to be for her? Cut a rectangular hole and go fly with her to see if it works. When you have it the right size and place make a door to cover the port that swings down to open???
By the way, I fly a lot in helicopters with the doors off. You couldn't pry me out of there with a crow bar even if the seat belt came loose.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
wingnut
Posted: Tue Jul 31, 2007 7:25 pm Post subject: Re: Sliding window for camera |
Good point. I was looking at a Cherokee 6 tonight that had exactly that kind of setup. It looked really simple. Just a rectangle cut out of the window with a door piano hinged at the bottom. The material used in that Cherokee's window is nice and thick so the access door made of the same material was quite sturdy. I'm concerned that the thinner material used in my window will make a flimsy access door requiring some kind of stiffener around the edge. Hope it doesn't come out too ugly.
| Quote: | | Luis, your question has got me thinking about this. There is no way my photographer (wife) is going to fly with the door open or off either. I just went out and sat on the passenger side. The place I would need a camera port is too curved for a sliding window. |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Jim Shumaker
Posted: Tue Jul 31, 2007 9:17 pm Post subject: Sliding window for camera |
Just take the door off and then you don't have to go through the door opening shock. Tie the camera to the plane or person. Lens cap off the camera and in the pocket (so it does not flap around). Actually I don't take the door off very often. It is easier to just open the door and use the rudder to raise or lower it. The slower you fly the higher the door floats, and the easier to open and close.
Jim Shumaker
_________________ Jim Shumaker |
