l.morris(at)tx.rr.com Guest
Posted: Sat Jul 28, 2007 6:04 am Post subject: counter wieght rivets |
I'm trying to figure out what rivets to use to attach the counter wieghts to the flaperon spar. There is a miss print in the manual on the model 4/classic 4 speedster. It is the same miss print as on the rivets for the fuselage butt ribs. It says to use p/n 95006- 1/8x3/8 AS. Looking at the inventory list shows 95006 as a plastic dent rivet and only 4 in the kit.The only 1/8x3/8 rivets are in the fuselage kit and are stainless and I assume the are for the butt ribs(total of 16).Oh, there are 4 of them in the cover and finish kit (not enough).All the other rivets in the flaperons are aluminum so I assume that is what to use,but no such rivets in the inventory. Leon Morris/Classic 4 (94)/50%/Flower Mound,TX
michaega(at)verizon.net Guest
Posted: Mon Jul 30, 2007 12:39 pm Post subject: counter wieght rivets |
My later model uses part number 90045 MONEL 3/32 x 1/8 pop rivets. Make sure the counter weight conforms smoothly with the flaperon or the rivets won't grab the aluminum. Yes, I had to drill them out before the epoxied set up and redo rivets.
l.morris(at)tx.rr.com wrote: [quote]--> Kitfox-List message posted by:
I'm trying to figure out what rivets to use to attach the counter wieghts to the flaperon spar. There is a miss print in the manual on the model 4/classic 4 speedster. It is the same miss print as on the rivets for the fuselage butt ribs. It says to use p/n 95006- 1/8x3/8 AS. Looking at the inventory list shows 95006 as a plastic dent rivet and only 4 in the kit.The only 1/8x3/8 rivets are in the fuselage kit and are stainless and I assume the are for the butt ribs(total of 16).Oh, there are 4 of them in the cover and [quote][b]
Posted: Mon Jul 30, 2007 2:25 pm Post subject: counter wieght rivets |
You are right on what you say. Those rivets are for the leading and trailing egde rivets on the flaperons. I was questioning the rivets in the middle that go thru the flaperon spar. I think I may have answered may own question whenI dug up the equation for determining rivet size. Guess I'll use 1/8x3/8 SS for the middle rivets,and I plan then to use 1/8x5/16 to attach the butt ribs to the fuselage. Leon Morris/Classic4/50%/Flower Mound, TX
---- SUE MICHAELS <michaega(at)verizon.net> wrote:
| Quote: | My later model uses part number 90045 MONEL 3/32 x 1/8 pop rivets. Make sure the counter weight conforms smoothly with the flaperon or the rivets won't grab the aluminum. Yes, I had to drill them out before the epoxied set up and redo rivets.
