10672
nielskock(at)get2net.dk
PostPosted: Wed Jul 25, 2007 11:14 am    Post subject: 10672 Reply with quote
Slightly embarrassed to ask:
What,exactly is mod 10672? Never heard about it
(or have plum forgotten, more likely).
Niels
OY-ODA
Jeg beskyttes af den gratis SPAMfighter til privatbrugere.
Den har indtil videre sparet mig for at få 1612 spam-mails
Betalende brugere får ikke denne besked i deres e-mails.
Hent en gratis SPAMfighter her. [quote][b]
richard(at)scarrhillalpac
PostPosted: Wed Jul 25, 2007 11:46 am    Post subject: 10672 Reply with quote
Niels,
This is the Club mod for the TP5 And TP6 sleeve, check out link below.
http://www.europaclub.org.uk/mods/improved_tp5_and_tp6_sleeve_retention.shtml
Visit - www.EuropaOwners.org
grahamsingleton(at)btinte
PostPosted: Wed Jul 25, 2007 2:45 pm    Post subject: 10672 Reply with quote
Niels
This mod is one that most of us wish we had done, unfortunately it isn't
easily retro fitted.
Graham
Niels
OY-ODA
Hent en gratis SPAMfighter her <http://www.spamfighter.com/lda>.
Graham Singleton
Tel: +441629820187
Mob: +447739582005
ptag.dev(at)tiscali.co.uk
PostPosted: Wed Jul 25, 2007 3:04 pm    Post subject: 10672 Reply with quote
Hi! Neils I patched the mod in direct . It can only be done during build and links the two tailplane bushes. Regards Bob harrison. Improved TP5 and TP6 Sleeve Retention
Ownership
Europa Club
Rickard Rating
Simple Mod
PFA Mod #
10672
Purpose
Reduce the risk of the torque-tube sleeves becoming disbonded from the tailplane, and the inside of the tailplane being damaged during fitting or storage
Description
Instructions for creating a bid tube surrounding the TP5 and TP6 torque-tube sleeves and bonding the sleeve into the TP2 foam and to the inboard and outboard tailplane ribs
Contact
Europa Club Membership Secretary
Details
(members only)
PDF
Photos: Enlarging hole, newspaper applied, laying up, cutting film, tube completed, rib completed, installed
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Niels Kock
Sent: 25 July 2007 20:13
Subject: 10672
Niels
OY-ODA
 Filesize:  33.14 KB
 Viewed:  355 Time(s)
DuaneFamly(at)aol.com
PostPosted: Wed Jul 25, 2007 7:48 pm    Post subject: 10672 Reply with quote
To All that might know,
This was done on builds with the foam cores that you covered with BID. What about the tailplanes that came precovered, as in the quick build kits? Since they came after the foam core, was this mod done to them? Or am I mistaken...again?
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
josok-e(at)ukolo.fi
PostPosted: Thu Jul 26, 2007 12:00 am    Post subject: 10672 Reply with quote
It's a club mod, not a factory mod and logic dictates that the factory does not incorporate club mods.
Maybe it's possible to do the mod after wards, but it will be difficult, especially the bond to the inboard rib. Maybe through enlarged pip- and drainage holes?
Jos Okhuijsen
g-iani(at)ntlworld.com
PostPosted: Thu Jul 26, 2007 1:05 am    Post subject: 10672 Reply with quote
"This was done on builds with the foam cores that you covered with BID. What about the tail planes that came pre-covered, as in the quick build kits? Since they came after the foam core, was this mod done to them"
Let me try and clear this up for you.
Quick build kits were foam cores that were taken to Czech and built up for you. From those I have seen they are extremely well made and are built exactly to the build manual. They do not have the mod 10672. They do vary slightly in that the TP6 bush (in one I have just done Mod 73 on) is 12mm longer than the TP6 in all the other tail planes.
There are some "pre-moulded" tail planes (ie no foam core) but as far as I know only Andy Draper's (G-GBXS) and Peter Kember's (G-TOPK) have them fitted. I believe the factory has a small number of them in stock.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Fergus Kyle
PostPosted: Thu Jul 26, 2007 6:05 am    Post subject: 10672 Reply with quote
Well, I don't recall ever seeing this mod mentioned - and I have
been a member for many years. How was this mod promulgated - only to
members?, by publishing in the Flyer?, as an adjunct to a fly-in? How? I
note that to acquire the mod, I needed to apply my membership particulars to
enter. How can we argue for the good of all if foreign aircraft may come
hurtling out of the sky?
Having completed the construction of the stabs the best way I know
how, it means another construction job I guess. Do the latest kits contain a
cure?
It appears to me that the discovery of a possible fault is on the
conscience of the discoverer - and that a universal and repairable solution
be made available. If it be PFA, then we should all wait for their
acceptance of AAIB proof and propose a cure.
Just as well because the first time I applied the stabs to the
trailer, one of them captured the plastic cap from the vertical tube and
it's still in there................
Happy (and successful) Landings,
Ferg
josok-e(at)ukolo.fi
PostPosted: Thu Jul 26, 2007 9:18 am    Post subject: 10672 Reply with quote
Hi Ferg,
The mod is available for all on the club's pages :
And that of course is the way it should be. It has been there probably before i ever heard of the Europa kit plane. and that's a few years ago.
One of the problems with information is that there is so much of it. Life would be a lot easier if it all was in one place. Now we have a factory website, a club website, the list, the forum, and probably some 50 more or less comprehensive builders websites. At the time Steve Dunsmeir started the forum i have tried to combine as much as possible, and it turned out to be impossible. For owners and builders the offer of a free site, for each and every project still stands. Even help for setting it up, just write me or Steve. Yesterday i noticed that we are up to 8500 pictures, something for a rainy day eh?
Kind Regards,
Jos Okhuijsen
PostPosted: Thu Jul 26, 2007 2:04 pm    Post subject: 10672 Reply with quote
Jos
I think there are a lot of people on the forum who still don't realise
how much you have done for the Club. There aer those who do though so
"never give up!"
Graham
and fly safe!
josok wrote:
Hi Ferg,
Kind Regards,
Jos Okhuijsen
Graham Singleton
Tel: +441629820187
Mob: +447739582005
josok-e(at)ukolo.fi
PostPosted: Thu Jul 26, 2007 11:36 pm    Post subject: 10672 Reply with quote
Graham,
It's the other way around. I feel this community has helped me with the build, the thinking aound the built, and most important kept me going at the moments i thought about dropping the whole thing. Now that it's really flying and very good, all that seems a long way ago. But, if i can get my hands on any other build to help, i will travel and do the same work again with pleasure. But hey, thats what you are doing as well eh?
Kind regards,
Jos Okhuijsen
philip_lincoln(at)hotmail
PostPosted: Fri Jul 27, 2007 1:26 am    Post subject: 10672 Reply with quote
The first I heard about it was on this mailing list back in 2000 (maybe even
1999?). I think the complete text/description may have been posted. I'm not
even sure it was an "officially approved PFA mod" with number and all back
then (maybe wrong here...). I incorporated it on or about July 2000 (kit
426, Tri-Gear) and even then was glad I did - the whole assembly just seems
more "solid", which, of course, it is.
Still building (every now-and-then...),
Philip (Stockholm, Sweden)
Reply-To: europa-list(at)matronics.com
To: "EUROPALIST" <europa-list(at)matronics.com>
Subject: 10672
Date: Thu, 26 Jul 2007 10:03:58 -0400
to
a
cure?
Ferg
Fergus Kyle
PostPosted: Fri Jul 27, 2007 6:35 am    Post subject: 10672 Reply with quote
"Jos
"never give up!"
Graham
and fly safe!"
Amen to that.
My diatribe wasn't meant to complain about anyone - just amazement that I
had missed a mod. Probably one day off. Perhaps I should monitor the PFA
list if that's possible.
Jos, thank you!
Ferg
