kevin(at)bondedcomponents Guest
Posted: Mon Jul 23, 2007 6:23 am Post subject: Initial Poor Rocket Performance |
Hi Guys,
As you know (if you've read here a while) my father has a HRII, the
first and only in the UK, a 10yr labour of love and its almost through
its 10 flight pre-test flight envelope, which is good.
However so far the performance is quite hitting the right
marks....Initialy thinngs looked great, with the first flight getting
180-200mph off half throttle....However opening her up has only yielded
220-230mph, which from what i gather is somewhat off the mark for full
bore straight and level ??? RPM is a tocuh over 2500
The engine is an IO-540-D4A5, which was a new build by Norvick, there
wasn't a stock C4B5 available and an extra 10hp can't hurt. The prop is
a Hartzel HC-M2YR-1BF/F8475D-4. The governer is by Mccauley, i don't
have the model no. to hand, but i don't know if this is the weak link.
Anyone use this engine/prop combination, if so whats you governer/set-up ?
Any ideas ???
Lee
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
sa300(at)uniserve.com Guest
Posted: Mon Jul 23, 2007 7:19 am Post subject: Initial Poor Rocket Performance |
It sounds like your governor needs setting up. It should go to 2700 rpm
for max hp. 2500 is 200rpm too slow.
Lee Armstrong wrote:
<kevin(at)bondedcomponents.freeserve.co.uk>
Hi Guys,
yielded 220-230mph, which from what i gather is somewhat off the mark
for full bore straight and level ??? RPM is a tocuh over 2500
is a Hartzel HC-M2YR-1BF/F8475D-4. The governer is by Mccauley, i
don't have the model no. to hand, but i don't know if this is the weak
link.
governer/set-up ?
Any ideas ???
Lee
__________ NOD32 2411 (20070721) Information __________
mark936(at)webtv.net Guest
Posted: Mon Jul 23, 2007 7:48 am Post subject: Initial Poor Rocket Performance |
1/2 turn for 50 rpm. is what I heard from Cliff Johnson IIRC
we just increased ours last week.
jrstone(at)insightbb.com Guest
Posted: Mon Jul 23, 2007 8:23 am Post subject: Initial Poor Rocket Performance |
Seems about right. John Harmon's brochure claims 230 mph cruise. I flew
with him many years ago and that is exactly what we cruised at. We are
talking Indicated airspeed which as you know will decrease with altitude.
Jim Stone
98% done
Sept first flight
