Tow bar
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
Bernhard10
PostPosted: Sun Jul 22, 2007 4:01 pm    Post subject: Tow bar Reply with quote
Does anybody use a tow bar. If so, which one are you using ??
I would like to find out if a regular tow bar with adjustable fork will fit the allegro 2000 ?
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
Thom Riddle
PostPosted: Mon Jul 23, 2007 2:04 am    Post subject: Tow bar Reply with quote
I made a tow bar from a piece of 1" square aluminum tube and a piece of
all-thread that just fits through the nose wheel axle hole for a total
cost of less than $10. It works fine, is light weight, and easily stows
in the baggage compartment if needed for overnight flights.
I don't remember for sure what the diameter of the all-thread is but
believe it is 3/4". I drilled two holes in the 1" square tube, one for
the nose gear all-thread (about 12" long to go all the way through the
axle hole), and the other for the handle all-thread (about 8" long) at
ninety degrees from the first hole so the handle sticks up when the
tow-bar is in use to make it easier to steer the nose wheel. I wrapped
a piece of foam rubber around the handle and duck taped it in place to
make the handle more comfortable. A piece of pipe insulation would work
as well or better. I used hex nuts and lock washers on both sides of
the 1" square tube to clamp the all-threads in place. I made the 1"
square tube short enough so that with one hand on the handle the other
is comfortably located on the prop blade near the hub for pushing or
pulling.
Next time I go to the hangar I'll take a couple photos and post them
here.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
airgriff(at)surferz.net
PostPosted: Mon Jul 23, 2007 2:29 am    Post subject: Tow bar Reply with quote
We use the tow bar from Fantasy Air. Works fine!
Bob Griffin Berne NY
Bernhard10
PostPosted: Mon Jul 23, 2007 8:43 am    Post subject: Re: Tow bar Reply with quote
Thanks a lot for your input.
I look forward seeing the pics.
Thom Riddle
PostPosted: Tue Jul 24, 2007 7:38 am    Post subject: Re: Tow bar Reply with quote
Attached are a couple photos of the tow bar I built. The photos plus my previous description should be sufficient to build something similar. This is more a Steering Bar than a tow bar since I use my hand on the prop near the hub for pushing/pulling while steering with this home-made bar.
 Filesize:  858.47 KB
 Viewed:  1114 Time(s)
 Filesize:  888.38 KB
 Viewed:  1173 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Bernhard10
PostPosted: Sun Jul 29, 2007 11:57 am    Post subject: Re: Tow bar Reply with quote
Thanks for the pics, I'll be working on a similar tow bar next week
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
