NSI transmission breather
smokey_bear_40220(at)yaho
PostPosted: Sat Jul 21, 2007 6:50 pm    Post subject: NSI transmission breather Reply with quote
I forgot who asked, but I didn't see a reply to the
question about the NSI GB breather.
The person to talk to is Peter Graichen. He has a
good number of mods for his plane pictured on his web
site and I think this breather is there too.
Peter, can you post your web site link again, or at
least the breather pic?
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
m4785(at)bellsouth.net
PostPosted: Sat Jul 21, 2007 7:06 pm    Post subject: NSI transmission breather Reply with quote
Kurt its me again ...oh shit landing guy
hey you are not that far from me ,do you want to get together and fly our foxes
I live near palatka and gainsville,no one around me flys there birds...all a bunch of hanger pilots..lol
PS: I hope you dont think im gay...we can pic up a couple of chics while were out...
See ya .....Mark N61AC
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Date: 2007/07/21 Sat PM 10:50:02 EDT
Subject: Re: NSI transmission breather
Kurt Schrader
S-5/NSI turbo
Florida and Panama
n10pg(at)neo.rr.com
PostPosted: Sun Jul 22, 2007 5:16 am    Post subject: NSI transmission breather Reply with quote
Hi Kurt,
I hope these pixs help
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
 Filesize:  30.15 KB
 Viewed:  269 Time(s)
 Filesize:  19.23 KB
 Viewed:  270 Time(s)
 Filesize:  30.96 KB
 Viewed:  289 Time(s)
 Filesize:  30.69 KB
 Viewed:  269 Time(s)
 Filesize:  19.23 KB
 Viewed:  279 Time(s)
GENTRYLL(at)aol.com
PostPosted: Sun Jul 22, 2007 6:36 am    Post subject: NSI transmission breather Reply with quote
Thanks Peter,
Looks like a simple setup. It looks like oil goes all the way to the reservoir. Is that correct?
wingsdown(at)verizon.net
PostPosted: Sun Jul 22, 2007 7:29 am    Post subject: NSI transmission breather Reply with quote
OK,
My bad. Should have looked and listened a bit closer. I didn’t realize
it was a different redrive. I will go back to seep now.
Rick
PostPosted: Sun Jul 22, 2007 7:33 am    Post subject: NSI transmission breather Reply with quote
FWIW,
I was told by Lance some time ago that the breather is actually detrimental. The mist created in the gear set is beneficial to lubrication. The vent diminishes this from forming. If the seal are good and the unit is not over filled there should be no need for one. I never needed one in 600 hours of operation. Please I don't care to get commentaries on Lance and get off topic. This is my general understanding of the closed reduction system and how it worked for me.
Rick
n10pg(at)neo.rr.com
PostPosted: Sun Jul 22, 2007 11:06 am    Post subject: NSI transmission breather Reply with quote
Hi Rick:
As you can see from the pixs I posted, I made a connection from the gearbox bottom drain to a plastic overflow bottle. The tube goes all the way to the bottom of the overflow bottle. The overflow bottle is vented. As the gearbox heats up during operation the internal pressure increases considerably without this vent. This does lead very easily to oil leaks around the seals.
During operation the pressure buildup expells about 5 fluid ounces of oil into the overflow bottle. As the gearbox cools after shut down, it sucks all the oil back into the gearbox. It is basically the same setup as the coolant overflow. As far as oil mist within the gearbox is concerned, I can not see where my setup would make any difference.
Peter Graichen
[url=http:/home.neo.rr.com/n10pg/kitfox.htm]http:/home.neo.rr.com/n10pg/kitfox.htm[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of GENTRYLL(at)aol.com
Sent: Sunday, 22 July, 2007 10:36
Subject: Re: Re: NSI transmission breather
Thanks Peter,
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
GENTRYLL(at)aol.com
PostPosted: Sun Jul 22, 2007 2:27 pm    Post subject: NSI transmission breather Reply with quote
Peter,
Since some oil obviously drains out of the gear box and into the tube, do you just try to add enough oil to start with to make the oil level in the gear box and the tube about the same height as the top of the gear box, or do you allow some space there also?
Float Flyr
PostPosted: Sun Jul 22, 2007 5:46 pm    Post subject: NSI transmission breather Reply with quote
Why is your breather out of the bottom of your redrive instead of the top?
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Fri Jul 27, 2007 7:18 am    Post subject: NSI transmission breather Reply with quote
Looks like you helped (again) Peter. Price of being a
leader.
Kurt Schrader
S-5/NSI turbo
Florida/Panama
--- Peter Graichen <n10pg(at)neo.rr.com> wrote:
Hi Kurt,
Peter Graichen
n10pg(at)neo.rr.com
PostPosted: Sun Jul 29, 2007 7:44 pm    Post subject: NSI transmission breather Reply with quote
I fill the gearbox with the specified quantity. In my case that is 850 ccm.
Peter Graichen
Sent: Sunday, 22 July, 2007 18:25
Peter,
