effectus(at)rogers.com Guest
Posted: Wed Jul 18, 2007 8:10 pm Post subject: Smart Aircraft Management Systems |
I would like to invite all RV-10 builders who are attending Oshkosh this year to see a new advanced electrical system architecture that we have been developing over the last couple of years. We will have an interactive display set up at Cleaveland Aircraft Tools' booth for the entire show this year.
The overall system includes:
An Electrical System Fuel Gauge (Tells you how many minutes of battery life you have left after losing an alternator)
Alternator Over-Voltage Protection
Solid State Switching (No Relays)
Solid State Circuit Breakers (No Fuses or Mechanical Breakers)
Low Voltage Warning
No Voltage Transients During Starting (Go ahead and start with your electronics on)
Electrical System Fault Detection and Warning System
Usable Battery Power is Increased by 10% or More
Smart Alternator Regulator that Increases Battery Life and Reduces Alternator Load
Smart Alternator Protects Alternator from Over Temperature
Supports Internally and Externally Regulated Alternators as well as Our Smart Regulator
System Can be Scaled for the needs of Simple VFR to Complex IFR
I will be at the show all week to introduce the system to you and to get your feedback. We are currently in the process of solidifying the design so your input and comments are greatly appreciated at this point.
I will be spending some time at the "RV-10 HQ" so grab me and I'll tell you more about this very cool system.
See you there.
Dave Hertner
#40164
Wiring the Wings
 Download |
| Filename: |
David_R._Hertner.vcf |
753 Bytes |
| Downloaded: |
339 Time(s) |
Posted: Wed Jul 18, 2007 8:27 pm Post subject: Smart Aircraft Management Systems |
Sorry I won't see you at OSH. Since your web site isn't working ..... got any more info and pricing???
Linn
David Hertner wrote:
[quote] I would like to invite all RV-10 builders who are attending Oshkosh this year to see a new advanced electrical system architecture that we have been developing over the last couple of years. We will have an interactive display set up at Cleaveland Aircraft Tools' booth for the entire show this year.
Low Voltage Warning
See you there.
Dave Hertner
#40164
Wiring the Wings
etekberg(at)gmail.com Guest
Posted: Sat Jul 21, 2007 2:46 pm Post subject: Smart Aircraft Management Systems |
I love to hear about all of these new upstart products. I'm curious, how do you plan on computing the number of minutes left on the battery? As a EE (although not a battery guy by any means) I know that this isn't an easy thing to accurately predict, unless the exact specifications about the battery are known. How do you plan to account for different battery types?
Eric
On 7/18/07, David Hertner <effectus(at)rogers.com (effectus(at)rogers.com)> wrote: [quote] I would like to invite all RV-10 builders who are attending Oshkosh this year to see a new advanced electrical system architecture that we have been developing over the last couple of years. We will have an interactive display set up at Cleaveland Aircraft Tools' booth for the entire show this year.
Low Voltage Warning
See you there.
Dave Hertner
#40164
Wiring the Wings
Posted: Sat Jul 21, 2007 6:46 pm Post subject: Smart Aircraft Management Systems |
Eric,
We have designed the system to work specifically with the Odyssey PC680 and PC925MJ. These are the most popular batteries used in the experimental market and by requiring their use we were able to design the system to be as accurate as possible. We also will require the builder to perform a battery test with a specific type of battery draw-down discharge unit suplied in the kit to accurately establish the individual battery's performance. This device will also be used during your yearly inspection to ensure that the battery performance is noted by the system.
We have just finished uploading a majority of our information on this product onto our website. www.smartaircraftsystems.com
Please go there and have a look.
Dave Hertner
President
Effectus AeroProducts Inc.
