gascolator question
Goto page 1, 2  Next
clemwehner(at)sbcglobal.n
PostPosted: Wed Jul 11, 2007 8:12 pm    Post subject: gascolator question Reply with quote
Does a gascolator separate water from the fuel when fuel is flowing thru it, as the engine is running?
tnx,
Clem Wehner
Lawton, OK
KFIV-912
Michel
PostPosted: Wed Jul 11, 2007 10:51 pm    Post subject: gascolator question Reply with quote
It does on my marine diesel engine, Clem, where I get a lot of tank condensation. But I have never seen a drop of water in my aircraft fuel which is always in a hangar, so I wouldn't know.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Float Flyr
PostPosted: Thu Jul 12, 2007 5:36 am    Post subject: gascolator question Reply with quote
It's supposed to. It should be installed before the fuel pump at the lowest
point in the fuel system. The size of the gascolator is governed by the
maximum fuel flow expected...more fuel requires a bigger gascolator.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
mikeperkins
PostPosted: Fri Jul 13, 2007 5:43 am    Post subject: gascolator question Reply with quote
The answer to your question is yes and no. Fundamentally, a gascolator is nothing more than a “bulging low spot” in the fuel system where anything heavier than fuel can collect. Water can, and often does, collect there because water is heavier than fuel.
Gascolators were really designed as an inexpensive fuel filter for stationary engines before filters were created. The screen inside will pass water as well as fuel. There’s no guarantee that some water won’t make it through because a gascolator is really a “static collector.”
If the plane is sitting still and water accumulates in the tanks of a high-wing aircraft from condensation, it can “fall down” there if the conditions are right (path is open, etc). This is why it’s a good idea to leave the tank valves open. But water will accumulate in the first low spot it comes to.
Kitfoxes have a header tank which is usually rectangular. So on the ground, the header tank has “nooks and crannies” where water can accumulate. Only the excess water that overflows from the nook or cranny can make it out of the header tank in this attitude. Also, Kitfoxes have fuel lines that typically run up hill when the aircraft sits on the ground, so water can’t get to the gascolator unless there’s a whole lot of it.
Now start the engine. Any accumulated water in the fuel lines makes it to the gascolator. However, the water which is stuck the nooks and crannies stays in place until the aircraft is in an attitude where this water can run downhill to the gascolator. Imagine a stepped waterfall where each step has its own low spots where water can collect – when the water flow stops, these low spots still contain water. A good fuel system is one where fuel is always running downhill, even from the nooks and crannies. Most Kitfoxes aren’t made like this. Only when you tip the whole waterfall forward can the water run out of these places.
While the engine is running, in the gascolator itself, if the turbulence is low enough, water will settle to the bottom. However, if flow rate and liquid turbulence in the bowl is great enough, water can make it through to the engine. Turbulence in the bowl can be caused by the flow itself, the vibration of the engine, and aircraft maneuvers.
Almost all airplanes have a gascolator, yet many engines have stopped in flight because of water in the fuel.
One more thing. If there’s any alcohol in the fuel, water will combine with it. Get some 100LL fuel. Mix fuel and water about 50:1. The water will go right to the bottom. Shake it up. The water still goes to the bottom. A gascolator can catch this water.
But now use fuel containing ethanol and do the same thing. Strange things happen. Sometimes the water “disappears.” Sometimes the water eventually makes it to the bottom and sometimes it doesn’t. It’s really an interesting experiment to do in a test tube. With ethanol fuel, the gascolator is being called upon to do something that it wasn’t designed to do.
Someone makes a water separator funnel you can use when fueling your airplane. I’ve heard it really works well. But then afterwards, water can condense in your tanks. The only real way to get the fuel and water to separate is to have your aircraft designed where fuel can always run downhill to the gascolator when the airplane is sitting on the ground and then not use ethanol fuels. Otherwise it’s just sheer luck. [quote][b]
Float Flyr
PostPosted: Fri Jul 13, 2007 7:13 am    Post subject: gascolator question Reply with quote
It was recommended to me that after refuelling a plane take twenty minutes to have a coffee. In that time any water in the gas will dissipate out and can then be drained off when the tanks are dripped before flying on.
I know of at least one lake LA-4 that crashed due to water in the fuel which was just purchased at a large airport. Had that pilot taken his time and dripped his tanks before taking off he would probably still be alive today.
[img]cid:333410115(at)13072007-159A[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  516 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
pwmac(at)sisna.com
PostPosted: Fri Jul 13, 2007 7:48 am    Post subject: gascolator question Reply with quote
Mike,
Great job of explaining the old school gascolator. You are totally correct in all respects.
I would only add:
Skystar recognized the disfunction of a tail dragger high wing with a gascolator which is why they did 3 things.
1) Eliminated the gascolater
2) Replaced the gascolator with an automotive final fuel filter
3) Started selling a proper header (or collector) tank
The logic went just as you said when parked the water would drain to the header. So they provided a sump with quick drain in the header. I have not measured the sump volume, but rest assured it is many times the size of any gascolator. (The outlet to the engine is some distance above the bottom of the header in order to achieve this sump function).
This design makes the quick drains in the tiny sump in the wing tanks superfluous, thus they can be eliminated.
I understand that MurleWilliams gets the credit for urging the factory to get it correct.
Conclusion. Copy the latest Skystar fuel system design and have a much safer plane.
Regards, Paul
At 07:43 AM 7/13/2007, Perkins, Mike wrote:
[quote] The answer to your question is yes and no. Fundamentally, a gascolator is nothing more than a “bulging low spot” in the fuel system where anything heavier than fuel can collect. Water can, and often does, collect there because water is heavier than fuel.
Float Flyr
PostPosted: Fri Jul 13, 2007 8:28 am    Post subject: gascolator question Reply with quote
The gascolator on my model III-A is definitely at the lowest point of the fuel system. If the plane didn't have one I'd install it. It does separate some grit as well as water before the fuel pump. Installing a fuel filter before the fuel pump is a no-no. The only other option is the gascolator.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
eskflyer
PostPosted: Fri Jul 13, 2007 9:02 am    Post subject: Re: gascolator question Reply with quote
To tell people to remove the gascolator is bullshit and eliminate it totally is insane . HMMMM lets see i go from taildragger to floats and then what geee i need a gascolator . You always need one i dont care who thinks they dont . use it or loose it to drain your fuel off and get the water out . This is a no bariner one .
My model 2 has the 9 1/2 gallon front tank and a 14 gallon wing tank . no room for a header tank in front so a gascolator is a must and even if it did have a header tank it would still have the gascolator .
Im just going to ask . Would you be willing to go on record and sign a logbook of someones to say remove gascolator you dont need it .
FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus
wingnut
PostPosted: Fri Jul 13, 2007 9:37 am    Post subject: Re: gascolator question Reply with quote
Back when I ran Mogas, I'd often get water out of my gascolator. Maybe the gascolator wasn't catching all the water but if it catches any at all then it's a good thing right? Having the gascolator doesn't hurt anything does it? I switched to 100LL six months ago and have not found water in my fuel since.
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
PostPosted: Fri Jul 13, 2007 10:57 am    Post subject: gascolator question Reply with quote
Why is a filter before the fuel pump a no-no? My kit came with an in-line fuel filter which I placed between the gascolator and the fuel pump. Is this a bad idea? Should the filter be before the gascolator?
Thanks for the help, I live in the middle of no-where OKlahoma where there are zero other builders, so you guys are my only source of help. (now that John Perry decided that Alaska was a better place to live than Oklahoma!)
Clem Wehner
KF-IV, 912
Lawton, OK
kl7jw(at)chahtatushka.net
PostPosted: Fri Jul 13, 2007 11:45 am    Post subject: gascolator question Reply with quote
One of the main reasons there shouldn't be a fuel filter on a fuel pump input is that it's easier to push liquid than it is to pull it. The filter, by virtue of the small passages thru it to allow a liquid to flow, creates a resistance to liquid flow, thereby requiring more effective pressure to pass thru the filter. Pumps produce pressure on the output, but not the input.
Hell, Clem, you live in a BIG city! I'm one that lives in the back country, at Wilburton, OK, county seat of Latimer County, population 3000. Wink
My dad lives in Lawton. I went thru high school there, then left and stayed gone from Oklahoma for 44 years, but moved back when I decided to retire totally.
I just bought a Kitfox IV with a Subaru engine on it. Matter of fact, just got home with it a couple of hours ago.
John Hart
[quote] --
msm_9949(at)yahoo.com
PostPosted: Fri Jul 13, 2007 12:07 pm    Post subject: gascolator question Reply with quote
Good question, Clem. I have the see-thru "Purolator" type filter installed in each fuel line between wing tank and header, well ahead of the fuel pump. No flow problem experienced after 80 hours. First speck of crud in a filter and it gets removed, cleaned out. Elements changed at annual. What's wrong with that?
clemwehner <clemwehner(at)sbcglobal.net> wrote: [quote] Why is a filter before the fuel pump a no-no? My kit came with an in-line fuel filter which I placed between the gascolator and the fuel pump. Is this a bad idea? Should the filter be before the gascolator?
Clem Wehner
KF-IV, 912
Lawton, OK
Glenn Horne
PostPosted: Fri Jul 13, 2007 12:19 pm    Post subject: gascolator question Reply with quote
Do you know any Indians in Lawton names Pacoddy. I was in the army with an Indian
from Lawton Ok.
GLENN HORNE
Kitfox Model II
PostPosted: Fri Jul 13, 2007 1:01 pm    Post subject: gascolator question Reply with quote
1. Based on several responses, I'm thinking that there should be no filter between the header tank and the fuel pump except for the gascolator. Is that right?
2. If true, then should an inline filter be placed after the fuel pump enroute to the carbs, or just not use an inline filter at all?
John, my wife asks what year you graduated from HS. She was from Lawton high, class of '64 (Frances Sue Jacks). Heck, ya'll might be cousins!
tnx,
Clem Wehner
Lawton, OK
KFIV-912, under construction since 1991. (going for the record!)
Float Flyr
PostPosted: Fri Jul 13, 2007 1:07 pm    Post subject: gascolator question Reply with quote
Fuel pumps do a pretty good job of pushing fuel but when it comes to sucking, well they suck! Fuel filters should be placed between the pump and the carb/fuel injection.
Slight blockage of a fuel filter before the pump can cause your pump to airlock and the fan to stop. Some plane have a small facet electrical pump very close to the tanks in that case placing the filter after the electric fuel pump is good.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
pwmac(at)sisna.com
PostPosted: Fri Jul 13, 2007 6:50 pm    Post subject: gascolator question Reply with quote
Hey, It all depends on how your fuel system is configured. If you have wing tanks and the header behind the seat vs a header up high behind the panel, nose gear , or floats. The fuel flow is different for each because of the flow from the tanks. More head pressure results with the behind the seat header. Any thing that reduces the pressure to the header tanks or reduces the pressure (and subsequent flow) to the pump is a no-no. Normal design for many vehicles & planes require a filter ahead of the pump. Like when one uses a Facet. If the pump is sensitive to particles then you need a pre filter. If not the put the filter downstream.
The gascolator is a filter. with a tiny sump to collect water. Do you need both a gascolator and another filter?
If your fuel system does not have a low point drain like the recent Kitfoxes with the behind the seat header, then you need to add one and a gascolator can accomplish this function. That is why the M 2,3 with panel tank have a gascolator instead of a normal filter like the M4 etc.
Paul
At 12:56 PM 7/13/2007, you wrote:
[quote]Why is a filter before the fuel pump a no-no? My kit came with an in-line fuel filter which I placed between the gascolator and the fuel pump. Is this a bad idea? Should the filter be before the gascolator?
Clem Wehner
KF-IV, 912
Lawton, OK --
pwmac(at)sisna.com
PostPosted: Fri Jul 13, 2007 7:02 pm    Post subject: gascolator question Reply with quote
I would never advocate removing the low point drain. Like I said in my other post the latest Skystar design is the only design that removed the gascolator.
Several owners have updated their fuel system to the low point behind the seat in the header. Think about that design and realize that it opens up other options.
Paul
At 10:27 AM 7/13/2007, you wrote:
[quote]The gascolator on my model III-A is definitely at the lowest point of the fuel system. If the plane didn't have one I'd install it. It does separate some grit as well as water before the fuel pump. Installing a fuel filter before the fuel pump is a no-no. The only other option is the gascolator.
Noel
pwmac(at)sisna.com
That is not a very nice message. I guess you don't care to figure it
out what the discussion is about.
I wonder if you read Mikes & my message.?
Paul
off and get the water out. This is a no bariner one .
John Perry
Kitfox 2 N718PD
WHEELS NorthAire Floats
http://forums.matronics.com/viewtopic.php?p=123610#123610
pwmac(at)sisna.com
What I am suggesting is that there is a better way, especially for the M4 TD.
Paul
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=123619#123619
pwmac(at)sisna.com
Is this an M4 with the header behind the seat? The flow restriction of a filter between the wing tank and header is not a critical as a filter after the header and before the pump. Good to have see thru filters so they cam be monitored. Filters on an M 2, 3 between the tank and header with the panel tank wound not be so good.
Paul
At 02:06 PM 7/13/2007, Marco wrote:
[quote]Good question, Clem. I have the see-thru "Purolator" type filter installed in each fuel line between wing tank and header, well ahead of the fuel pump. No flow problem experienced after 80 hours. First speck of crud in a filter and it gets removed, cleaned out. Elements changed at annual. What's wrong with that?
Clem Wehner
KF-IV, 912
Lawton, OK
Goto page 1, 2  Next
Page 1 of 2
