clemwehner(at)sbcglobal.n Guest
Posted: Wed Jul 11, 2007 9:04 pm Post subject: barb-tite fittings |
My 912 engine kit came with a brass "Barb-Tite" fitting (hose barb). From what I've read these fitting require no hose clamp and just need the hose pushed up over the barbs. Supposedly good to 250 PSI.
Will these work with fuel injection hose or will they only work with specially designed hoses? Is it really safe to have a fuel line without a hose clamp?
Clem Wehner
KFIV-912
Lawton, OK
Float Flyr
Posted: Thu Jul 12, 2007 4:56 am Post subject: barb-tite fittings |
This is the first time I've heard of this. All my barb fittings have clamps over them
[img]cid:021095412(at)12072007-29C9[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
285 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Thu Jul 12, 2007 7:40 am Post subject: barb-tite fittings |
At 10:03 PM 7/11/2007, you wrote:
| Quote: | | Will these work with fuel injection hose or will they only work with specially designed hoses? Is it really safe to have a fuel line without a hose clamp? |
I use them extensively, but only as designed. There is an entire Aeroquip series that is clamp-less. Aeroquip is reputable and I'm ASSUMING their design is proven, though I didn't prove it myself. I used this system previously on a Porsche remote oil cooler and in 12 years never had a fitting failure, though I once had a mid-hose failure. Of course I replaced the line every few years.
On all other "barbs" I use clamps. (E.g. fuel pump, carburetors.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Posted: Fri Jul 13, 2007 11:08 am Post subject: barb-tite fittings |
Guy,
What about using the "Barb-Tite" fitting with typical fuel injection hose? Since everyone recommended the fuel injection hose over the old H6000, I changed all the hoses to fuel injection hose. But now I wonder if I can use it with the barb-tite fitting. Would it hold?
Thanks for the help,
Clem Wehner
Guy Buchanan
Posted: Fri Jul 13, 2007 7:51 pm Post subject: barb-tite fittings |
At 12:06 PM 7/13/2007, you wrote:
| Quote: | | What about using the "Barb-Tite" fitting with typical fuel injection hose? Since everyone recommended the fuel injection hose over the old H6000, I changed all the hoses to fuel injection hose. But now I wonder if I can use it with the barb-tite fitting. Would it hold? |
Don't know. I used the Aeroquip "Socketless" system for the fuel lines from the wing tanks to the fuselage, about 1' on each side. The rest of the fuselage fuel lines are aluminum. The "Socketless" system requires no clamps and is rated to 250 psi working. I can't imagine any unpressurized line coming off a "Barb-tite" fitting, but I don't have any even anecdotal data. Why not use clamps? I use them on all my fuel hoses in the engine compartment.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Fox5flyer Guest
Posted: Sat Jul 14, 2007 3:03 am Post subject: barb-tite fittings |
Yes, they'll hold. Just buy some of the hose and fittings. Install a fitting in a vise then install the hose. Try to pull it off. Clamps are optional.
Deke Morisse
N148DM
S5/Soob/CAP
NE Michigan
"The influence of each human being on others in this life is a kind of
immortality."
-- John Quincy Adams
pwmac(at)sisna.com Guest
Posted: Mon Jul 16, 2007 6:13 am Post subject: barb-tite fittings |
No info on "barb-Tite". The off road race trucks are now using Parker "Push-Loc". One heats the hose with hot water and push it on the fittimgs. Good for 250psi, once installed. Use on high pressurte fuel EFI fuel systems. Fittings are availble from multiple sources Like Parker, Earls, etc. Fittings are available for flared AN or pipe threads. The hose is special not the standard SAE stuff
They are real easy to install and no clamps are used.
Paul
