lwinger
Posted: Sun Jul 08, 2007 6:50 pm Post subject: Aileron bellcrank countersink |
This should be a simple question for you scratch builders. Where did you get the countersink for 6-W-10-2 (bellcrank spacers)? What model number/part number? It needs to be able to bevel for an AN426 rivet head in 1/4 aluminum.
I did a test using a countersink I had for woodworking, and at that depth it began to "chatter" and it made an irregular edge.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Posted: Mon Jul 09, 2007 2:40 am Post subject: Aileron bellcrank countersink |
any standard aircraft (100°) csk will do. That having been said - I would only consider countersinking using a microstop and the appropriate piloted bits.
lwinger <larrywinger(at)gmail.com> wrote:[quote] --> Zenith-List message posted by: "lwinger"
Larry Winger
Tustin, CA
601XL/Corvair from scratch
Control surfaces and wing spars complete
Read this topic online Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.[url= http://us.rd.yahoo.com/evt=49937/*http://tools.search.yahoo.com/toolbar/features/mail/] Check it out.[/url] [quote][b]
planejim(at)bellsouth.net Guest
Posted: Mon Jul 09, 2007 4:41 am Post subject: Aileron bellcrank countersink |
Larry,
Be aware that there are countersinks with different angles. The standard
aircraft one is 100 degrees. You will find them with different numbers of
flutes - standard is three. There are 120 degree countersinks although they
are scarce. In fact the Avex rivets we use are ( the flush type ) are 120
degrees. Wood countersinks are 82 degrees ( if my memory serves me
correctly - might have the wrong number - they are different than aircraft
types ).Just make sure the one you are using is sharp. If it has been use on
steel and then use it on aluminum, you won't be happy.
Someone ( I missed the name ) stated that you should use a microstop with
piloted bits. These are great and allow precise repeatablity once adjusted
and locked up. The big drawback with these is that they are expensive,
especially if you only have a few holes to do. Try to borrow one rather than
buying one. I've used a drill press ( with the stop set ) and a simple 100
degree countersink to do fairly precise countersinks on parts you can get in
place and clamped at the drill press. Experiment on scrap metal and you will
do a good job.
Jim Hoak
Posted: Mon Jul 09, 2007 8:27 am Post subject: Aileron bellcrank countersink |
eBay is great source for Microstops. i have about a half dozen, never paid more than $10 including shipping for any of them. I did get one with bad bearings...
Jim Hoak <planejim(at)bellsouth.net> wrote: [quote]--> Zenith-List message posted by: "Jim Hoak"
Larry,
do a good job.
Jim Hoak
lwinger
Posted: Tue Jul 10, 2007 3:44 am Post subject: Re: Aileron bellcrank countersink |
Thanks for all the responses. Once again, the list comes through!
Do not archive.
Tustin, CA
maarten versteeg
Posted: Tue Jul 10, 2007 5:59 am Post subject: Aileron bellcrank countersink |
Hello,
But these countersinks are made in the 1/4 in thick aluminum,
I made them using a sharp woodworking countersunk in the drill
press and they came out fine. I managed to control the "chatter"
by picking a slow speed and controlling the pressure. I don't
think a microstop is needed in this material, the proper depth
can easily be measured and there is no danger of drilling too
deep.
regards,
Maarten,
601XL plans building wings
| Quote: | Time: 03:40:30 AM PST US
any standard aircraft (100) csk will do. That having been said - I would only consider
_________________ Maarten Versteeg
601XL scratch building wings |
Posted: Tue Jul 10, 2007 7:52 am Post subject: Aileron bellcrank countersink |
there is a MAJOR issue here: the included angle of the "wood working" csk and the AN426/MS20426 are not at all compatible. This is the worst condition in a driven flush head rivet of all the possible error conditions. The rim of the rivet head is seated but the head to shank region is gapped - and awful (and blind to inspect until after failure) condition structurally.
Maarten Versteeg <maarten.versteeg(at)swri.org> wrote: [quote]--> Zenith-List message posted by: Maarten Versteeg
Hello,
think a microstop is needed in this material, the Take the Internet to Go: Yahoo!Go puts the [url=http://us.rd.yahoo.com/evt=48253/*http://mobile.yahoo.com/go?refer=1GNXIC]Internet in your pocket:[/url] mail, news, photos & more. [quote][b]
lwinger
Posted: Tue Jul 10, 2007 9:52 am Post subject: Re: Aileron bellcrank countersink |
For the record, Brown Tool came to the rescue again. I just ordered the #21 pilot 100 degree countersink (CC021) for $4.95 and the standard cage microstop (CC01-USA) for $21.95. John was very helpful, and I expect to be doing more business with them in the future.
Thanks again to the list for solid advice.
Tustin, CA
