wjones(at)brazoriainet.co Guest
Posted: Thu Jul 05, 2007 9:22 am Post subject: Control cables |
Hello group , I am getting ready to construct my rudder control cables .Question : Since I am building my cables and will keep close tolerances is there any need for the expensive turnbuckles . Thanks
Wade Jones South Texas
601XL plans building
Cont. 0200
steerr(at)bellsouth.net Guest
Posted: Thu Jul 05, 2007 9:49 am Post subject: Control cables |
How will you maintain the required tension on the cables? Also, if the
cables stretch slightly over time, how will you compensate if you don't
have turnbuckles?
Bill
wade jones wrote:
| Quote: | Hello group , I am getting ready to construct my rudder control cables
Cont. 0200
Jaybannist(at)cs.com Guest
Posted: Thu Jul 05, 2007 10:12 am Post subject: Control cables |
Wade,
Over time, your cables will stretch. You need to be able to compensate for that to maintain the proper tension. You could always build in idler pulleys to do that job, but that introduces a bunch of other problems. Turnbuckles are the easy way.
Jay in Dallas
"wade jones" <wjones(at)brazoriainet.com> wrote:
| Quote: | Hello group , I am getting ready to construct my rudder control cables .Question : Since I am building my cables and will keep close tolerances is there any need for the expensive turnbuckles . Thanks
Cont. 0200
planejim(at)bellsouth.net Guest
Posted: Thu Jul 05, 2007 10:28 am Post subject: Control cables |
Wade,
I built a 601HD 11 years ago. I used the pieces of aluminum extrusion and various lengths of 1/4" diameter bolts - all supplied in the kit, ( to set the tension). I'm an A & P with some experience and was turned off by this at first. I even had certified A/C turnbuckles on hand but decided to go with Chris' simple design. It worked fine, 11 years and 550 hours later - no problems. ( You still have to use safety wire as a precaution). Remember the cables will "stretch" very little in the long run, because we will only have about 18 to 20 pounds tension on them anyway. ( Just take the slack out! ) I've never had to re-adjust mine yet.
Of course the expensive "store bought" turnbuckles look nice and certainly will work. But you still have to make the cables the proper length even with them!
Jim Hoak - 601HD - 912UL - 550 hours
Jeyoung65(at)aol.com Guest
Posted: Thu Jul 05, 2007 11:13 am Post subject: Control cables |
Jim. I am building a 601 HD and saw the Zenith turnbuckles and like you rejected them but sounds like they are the way to go. Also, never did like to safteywire a turnbuckle. Jerry of GA
DO NOT ARCHIVE
See what's free at AOL.com.
Posted: Thu Jul 05, 2007 11:19 am Post subject: Control cables |
Thanks Jim ,Jay & Bill for your responses .The reason I asked this question is because my 48 year old Piper Tripacer & my 30 year old Sonerai do not use turnbuckles in this application .Don't want to sound argumentative but if is OK on a certified aircraft why not on an experimental .It would be the same amount of work and would save a little expense.Thanks again and I give all responses consideration .
Cont. 0200
NYTerminat(at)aol.com Guest
Posted: Thu Jul 05, 2007 12:10 pm Post subject: Control cables |
Wade
Cable stretch and want to be tightened after a while, much easier with turnbuckles than the flat stock that Zenith uses.
Bob Spudis
In a message dated 7/5/2007 1:24:23 P.M. Eastern Daylight Time, wjones(at)brazoriainet.com writes:
Cont. 0200
VideoFlyer(at)aol.com Guest
Posted: Thu Jul 05, 2007 12:17 pm Post subject: Control cables |
I'd use the turn buckles...for a number of reasons. I have made quite a few cables.....cut them to length...swaged the ends, etc. I can get them pretty close to the exact length that I want....but having the turnbuckle lets you fine tune the tension. It also lets you fine tune the position of your stick..or pedals. For example, I decided that I wanted the neutral position of my stick a little further forward than it was initially. Somehow, it just felt more comfortable having the stick about an inch further forward. With the turnbuckles, it's a snap. Just be sure to cut your cables so the turnbuckles are at a midpoint of their adjustment range to start with.
Dave
601XL/Corvair N618PZ
Posted: Thu Jul 05, 2007 4:08 pm Post subject: Control cables |
turnbuckle are a requirement in my opinion, as the cable over time is prone to streching. you need to be able to abjust the tension on the cables to the apropiate foot Lbs.
Juan Vega
Posted: Thu Jul 05, 2007 4:21 pm Post subject: Control cables |
Thanks to all that responded to my control cable issue .Since I always fly with my feet on the rudder pedals and this controls my cable tension I may not use turnbuckles on the rudders. Due to the control stick torque tube having no forward movement control stops and relying on cable tension only to keep it in place . I think it best to use the turnbuckles on the elevator cables .Do you guys think this will work out OK .
Cont. 0200
heatonhe36(at)msn.com Guest
Posted: Thu Jul 05, 2007 5:16 pm Post subject: Control cables |
Wade,
I think you will need turnbuckles on the rudder cables too. Since the
rudder pedals are connected to the nose gear strut with pushrods, you will
have to have some way to balance the tension on the rudder cables. If the
cables are loose you can't take the slop out by pushing on the rudder
pedals.
Herb
[quote]From: "wade jones" <wjones(at)brazoriainet.com>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: Re: Control cables
Date: Thu, 5 Jul 2007 19:19:37 -0500
Cont. 0200
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Thu Jul 05, 2007 5:36 pm Post subject: Re: Control cables |
Wade,
I'm a fellow plans builder and a bit confused by your plan. Are you doing the standard tri-gear, or will it be a tail dragger? On the tri-gear the rudder peddles are tied together through the front gear steering linkage, so it seams like feet on the peddles will have little if any effect on rudder cable tension. My plan is to adjust the tie rod ends on the stearing gear until the rudder peddles are in the neutral position with the front wheel straight ahead, then adjust the rudder cables to also put the rudder in the neutral position. I wouldn't want them not to be coordinated. Maybe you have some other adjustment mechanism in mind?? If you're doing a tail dragger this may become a mute point.
Dan
XL/Corvair
| Quote: | Since I always fly with my feet on the rudder pedals and this controls my cable tension I may not use turnbuckles on the rudders. Due to the control stick torque tube having no forward movement control stops and relying on cable tension only to keep it in place . I think it best to use the turnbuckles on the elevator cables .Do you guys think this will work out OK .
601XL plans building |
_________________ Scratch building XL with Corvair Engine |
Posted: Thu Jul 05, 2007 6:26 pm Post subject: Control cables |
Good point Leinad ,I am going the tri-gear route but I was thinking the tail
gear route .When I fly my Sonerai (tail wheel} I control the tension by my
feet on the rudder pedals .My Tri-pacer is so easy to fly anything goes
.Guess I will have to stop being so cheap and buy the turnbuckles ,case
closed. Do not Archive
Cont. 0200
bryanmmartin
Posted: Thu Jul 05, 2007 8:47 pm Post subject: Control cables |
Sounds like you're building a tail wheel Zodiac. In that case you might
not need turnbuckles in the rudder cables. In the nose wheel version,
foot pressure on the pedals has little effect on the cable tension due
to the direct connection of the nose wheel steering rods.
wade jones wrote:
| Quote: | Thanks to all that responded to my control cable issue .Since I always
OK .
Cont. 0200
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
