Ray.R.Doerr(at)sprint.com Guest
Posted: Tue Jul 03, 2007 5:48 am Post subject: More testing with OAT and Static Ports. |
Over the weekend I changed out my flat faced static ports from Cleveland Tools to there new dome faced ones. When I called them about the error (TAS was 5 - 6 knots low on my Dynon versus 4-way GPS TAS) I was having with the original flat faced ones, they sent me the new dome faced ones at no charge (awesome folks at Cleveland). I also mounted another OAT in my left wing on the wing spar flange right in front of the middle inspection plate, which was connected to a General Purpose input on my Dynon Engine Monitor. My other OAT is mounted in the aft half moon bulkhead under the emp fairing, which is connected to the compass module for the Dynon EFIS.
Well with these changes completed, Loal Wood (RV-7, XP-360 injected with cold induction, Dual OAT's in each wing) and Tom Deutsch (RV-10, IO-540, OAT in NACA vent inlet connected to Dynon Compass Module) went up to do some comparison testing. Loal was reading 61 degrees on both of his OAT's which were out in each wing, while I was reading 61 on my OAT that was out in the wing on the Dynon EMS, but my was reading 67 on my OAT under the emp fairing. Tom on the other hand was reading 68 on his OAT in the NACA vent inlet. Since all three of us had Dynon EFIS and EMS's with OAT connected, we concluded the correct OAT was from the OAT's that were mounted out in the wing regardless if they were connected to the EFIS or EMS, since Loal's both read the same value both on the ground and in the air.
Now as for the TAS error I was seeing after my post from last week, which showed my Dynon TAS being 5 - 6 knots low. I did another run and here are the numbers.
TRK IAS TAS GS OAT MAP RPM FF ALT DA
0 144 168 182 60 22.0 2450 14.6 8500 10420
90 144 168 164 60 22.0 2450 14.6 8500 10420
180 144 169 158 60 22.0 2450 14.6 8500 10420
270 144 168 176 60 22.0 2450 14.5 8500 10420
170.3
From this I concluded that the domed faced static ports have corrected my TAS error to the point where I am reading 1 - 2 knots low versus 5 - 6 knots before. I believe this is the same experience that Tin Olson has seen when he changed his static port out. Also since I now had the OAT on the EMS with Dynon's latest 3.0RC4 beta code which now has the % HP, it was showing that this test run was at 74% power ROP. There is no doubt my speeds would be faster trying this again at a DA of 8000 versus the 10420, but I need to leave something for another day.
Thank You
Ray Doerr
N519RV (40250) Hobbs 266
Tim Olson
Posted: Tue Jul 03, 2007 6:13 am Post subject: More testing with OAT and Static Ports. |
Ray,
You are absolutely to be applauded for your input and efforts on this.
It's very refreshing to see someone take the time to validate everything
to a good extent. Indeed you're right....I had the same flat-faced
ports and was reading 6.5-7.5kts low, and after swapping them for
the domed ports I'm now about 1.8kts low if my repetitive testing
averages are right. -1.8 is good enough for me, although the
perfectionist in me gets tempted to make it better...luckily the
lazy man in me tempers that a bit.
Also, that was great of you to take the time to verify OAT probe
positions and temp errors. Hopefully people will take that to
heart.
Doerr, Ray R [NTK] wrote:
Quote: |
<Ray.R.Doerr(at)sprint.com>
connected to the compass module for the Dynon EFIS. Well with these
same value both on the ground and in the air. Now as for the TAS
numbers.
----------------------------------------------------- 0 144 168 182
60 22.0 2450 14.6 8500 10420 90 144 168 164 60 22.0 2450 14.6 8500
10420 180 144 169 158 60 22.0 2450 14.6 8500 10420 270 144 168 176 60
22.0 2450 14.5 8500 10420 ---- 170.3
Thank You Ray Doerr N519RV (40250) Hobbs 266
rleffler
Posted: Tue Jul 03, 2007 1:53 pm Post subject: More testing with OAT and Static Ports. |
It doesn't appear that Cleaveland has updated their web site. What's the
new part number? I'm assuming they are the same price as the old ones?
Has anyone measured the ones from Rivethead-Aero yet? Do they exhibit
similar issues?
_________________ Bob Leffler
N410BL - Phase I
rv10builder(at)bellsouth. Guest
Posted: Tue Jul 03, 2007 2:16 pm Post subject: More testing with OAT and Static Ports. |
I know Mike follows this list...he can probably answer.
BTW Mike...can you have a supply of the new static ports on hand at OSH'08?
Brian
#40308
Nashville, TN
similar issues?
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Jul 03, 2007 6:00 pm Post subject: More testing with OAT and Static Ports. |
Thanks for the update.
Kevin
40494
----- Original Message Follows -----
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
_________________ Kevin
40494
do not archive |
Posted: Tue Jul 03, 2007 6:40 pm Post subject: More testing with OAT and Static Ports. |
Sorry...OSH'07. Wow...I just added another year to my construction by
mistake!
OSH'08?
Brian
#40308
Nashville, TN
> the
> similar issues?
elhershb(at)comcast.net Guest
Posted: Wed Jul 04, 2007 6:33 am Post subject: More testing with OAT and Static Ports. |
Pardon my comment on this. When Cleaveland Tool came out with the new domed static ports I became worried because I had the original flat ones installed. I called Mike about this and was told that the reason for the design change was to account for the fact that many were priming the inside of the skin. When doing this it took away the designed protuberance of .010". When the back side is primed the face of static port becomes practically flat with the outside of the skin. This will not allow them to be in clean undisturbed air.
So if you have primed the inside skin, you either need the new domed static ports or you need to machine the flat ones so they stick out .010" above the outside skin.
Ed Hershberger
Wings Top Skins
N410EP (res)
Bob Leffler wrote:
--> RV10-List message posted by: "Bob Leffler" <rvmail(at)thelefflers.com> (rvmail(at)thelefflers.com)
similar issues?
VHMUM(at)bigpond.com Guest
Posted: Wed Jul 04, 2007 2:17 pm Post subject: More testing with OAT and Static Ports. |
I just dont get it with my 6 we just used the Vans pop rivet. All acurate and no stuffing around reinventing ....whats the diference with the 10.....please excuse my ignorance.
Is the location wrong?
Chris 388
sam.marlow
Posted: Wed Jul 04, 2007 2:38 pm Post subject: More testing with OAT and Static Ports. |
It's driving me crazy, I wished I knew. I've installed the new Cleveland ports, and it helped, but it's still not correct. Van's can do better than this, I'm disappointed.
Sam
---- The McGough Family <VHMUM(at)bigpond.com> wrote:
[quote] I just dont get it with my 6 we just used the Vans pop rivet. All acurate and no stuffing around reinventing ....whats the diference with the 10.....please excuse my ignorance.
Chris 388
jwt(at)roadmapscoaching.c Guest
Posted: Wed Jul 04, 2007 4:34 pm Post subject: More testing with OAT and Static Ports. |
Does anyone know if the ports from SafeAir have the same errors that the
Cleveland flat ports have?
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep and interior
Posted: Wed Jul 04, 2007 5:47 pm Post subject: More testing with OAT and Static Ports. |
Has anyone tried the vans method?
DAVELEIKAM(at)wi.rr.com Guest
Posted: Wed Jul 04, 2007 7:32 pm Post subject: More testing with OAT and Static Ports. |
Good question, I installed the Safe Air ports. I second. Any known errors?
Dave Leikam
40496
rvbuilder(at)sausen.net Guest
Posted: Thu Jul 05, 2007 5:11 am Post subject: More testing with OAT and Static Ports. |
The common theme here is that the static ports must extend out approx .010 in order to clear the boundary layer and give accurate readings. Van's do this from the shear fact that they are a domed pop rivet. A lot of people are concerned, and I believe a few have experienced, that the van's pop rivet doesn't hold the static tubing on with any type of long term positive grip. Other than that thousands are flying with the pop rivet.
With the -10 many people just didn't like the idea of a cheesy pop rivet static port and just as many are planning on using the -10 for IFR so it would seem prudent to use something better like the Cleaveland or SafeAir. Back when I made my decision there was a lot of conjecture on why people would see various errors and I discussed this briefly with SafeAir and went with their package anyway knowing I might have to replace the ports (I mainly was interested in the tubing and connectors). It was acknowledged back then that there was a potential for problems but most people didn't seem to care that they might have an error as they fly for fun.
So we now know, with some hard data, that you probably need at least a .010 protuberance for accurate readings. I would be interested to know if .015 would clear up that additional 1-2 knot discrepancy. If your ports are flush you will probably have an error. If you use Van's pop rivet method or anything else that sticks out a bit you will probably be ok.
Michael Sausen
-10 #352 Limbo.
Tim Olson
Posted: Thu Jul 05, 2007 5:47 am Post subject: More testing with OAT and Static Ports. |
I'd agree with everything Michael just said. It really is just
sticking the port out a bit that fixes things. I had my old
Cleveland flat ports in, and cut flat washers to tape over the
area and that did the job too as a test...just getting the ports
to stick out a bit. The pop-rivet will do that, and there's
probably many more ways, but as Michael also said, you want
something really good for IFR flight that securely holds
the tubing on, so the pop rivet doesn't cut it from a mechanical
perspective, even if it worked perfectly from an accuracy perspective.
Also, I know, cleveland said that the primer is the cause of the
flat ports not working right. While that may add to the
poor function of the flat ports, IMHO, if the primer is enough
to wreck it's function, then they weren't NEARLY stuck out
enough to begin with. Even the domed ones don't stick out that
far, and if I were building my own, I'd probably want to at
least test them being another .020-.030 stuck out than
the domed ones are. It would be interesting if the additional
~2kt error would then go away.
So I don't think the location is much at fault at all, but it's
absolutely apparent that the static port must stick out from the
skin. If the SafeAir ports do that, then you should be fine.
If not...don't expect much.
Also, if you don't paint the ports, the skin's thickness will
detract from how far the port sticks out, so apparently you
are supposed to paint the ports with the skins. Again though,
I think the ports should just be cut thick enough that they
can go on unpainted and still work.
RV Builder (Michael Sausen) wrote:
<rvbuilder(at)sausen.net>
Michael Sausen -10 #352 Limbo.
AV8ORJWC
Posted: Thu Jul 05, 2007 3:51 pm Post subject: More testing with OAT and Static Ports. |
Before Dr. Carl Cadwell built the first Epic LT Kitbuilt Single Engine
Turbo-prop, he finished a beautiful Lancair (N25CL) that used the
boundary layer disrupter in the attached picture. This might help
clarify why the pickup port should Not be flush with the skin. Notice
the accent color pinstripe on the lower red to bring out the clarity.
One Shot - lettering paint was used.
Just a Trivia Note: It was the completion of Dr. Cadwell's Epic that
caused Comp Air of Florida to whine about the competition and trigger
the secret 51% Committee Meetings. Has anyone seen any progress from
the private committee? I will wager Mass Produced Kit Build is here to
stay with non American QB labor.
John Cox - KUAO
#600
PS - I hear that the RV-12 with a new wing is ready for "Prime Time" OSH
'07
Description: |
Filesize: |
573.62 KB |
Viewed: |
535 Time(s) |
wcurtis(at)nerv10.com Guest
Posted: Thu Jul 05, 2007 6:33 pm Post subject: More testing with OAT and Static Ports. |
I don't know about boundary layer disruptor but these are stock S-Tec (Meggit) static ports used on their autopilots. I know this cause I have two of these on the tailcone sides of my Cardinal feeding the S-Tec 30 altitude hold. Ironically, the stock static ports on the Cardinal are flush and forward of the cabin door.
William
http://wcurtis.nerv10.com/
