Posted: Wed Jul 04, 2007 6:56 am Post subject: gps off topic a little |
Hi John,
I just bought my third GPS. It is a Nuvi 200 from Garmin. I love it
since it actually works well in my car.
My second one was a Lowrance GPSmap 350 (or something close to
that). It was a horrible machine. I returned 3 or 4 of them because
they kept dying. If you put one on your dashboard it would overheat
and the power supply would die. If you put it lower down inside the
dashboard console then it would run but couldn't find enough
satellites to navigate. There was no external antenna.
My first was a Lowrance Airmap 500. This works great in an airplane
and reasonably well in a car. It is limited by the small black and
white display and a bit difficult to set up for car use.
The real differences I have found from one GPS to another are how
well the device actually acquires and keeps satellites and how good
the database is.
I think you will get a lot more utility out of a low end air GPS for
flying than trying to use a ground based design of any quality. The
air database includes things like Class B, C, and D airspace along
with frequencies to contact the controlling authority. It has all
the airports displayed and can find any airport or VOR (maybe) just
by its 3 or 4 letter code. The air GPSs seem to all have a faked
instrument panel which would actually be very useful for navigating
your plane if your primary instruments go south. None of these
wonderful features would be found in a ground based unit.
One more comment - to get much use out of any GPS in the air you must
learn to work the complex button sequences. This can be very
difficult while also trying to fly your plane. To make it even worse
by trying to use a device oriented toward cars or boats instead of
one carefully optimized for air use would add a great deal to the workload.
My own plans were to get a high end Lowrance air GPS for my plane,
but after the problems with the ground based one I am thinking
seriously of changing to a Garmin. At least in the auto GPS domain
the Garmin functions so much better than the Lowrance that I think it
worth the outrageous price.
Good luck,
Paul
XL fuselage
At 06:50 AM 7/4/2007, you wrote:
| Quote: | hi list
i saw an ad for a portable gps system for an
automobile. it has all the bells and whistles for
ground use, and i wondered if any of you people have
used one in the air. if so, was it of any value. i
will have a gps for my machine but was just wondering
if the portable auto type gave enough info to make it
worth taking along on a flight. it will at least give
the addresses of places to stay and eat on a X-country
john butterfield
XL, corvair
torrance, ca
Posted: Wed Jul 04, 2007 6:59 am Post subject: gps off topic a little |
Hi John,
The aircraft GPS used is probably a better way to go, but an auto GPS
could provide what you need if you have an AOPA Airport Directory. This
paper bound
aid provides all phone numbers, fuel, frequencies, coordinate data and
runway info, etc for all airports and
for the price would allow you time to eventually upgrade to a Lowrance-500
or equal. I sold a Lowrance-100 a year or so ago for less than you'd
pay for
an automotive GPS, so keep an eye out.
john butterfield wrote:
hi list
john butterfield
XL, corvair
torrance, ca
stol701(at)yahoo.com Guest
Posted: Wed Jul 04, 2007 11:30 am Post subject: gps off topic a little |
That would work fine until you try and fly in an area w/ lots of restricted airspace. I live in Southern New Mexico and would not fly without my airmap 2000.
Rob
