Automatic upper cowl flap
Goto page Previous  1, 2
longg(at)pjm.com
PostPosted: Mon Jul 02, 2007 11:23 am    Post subject: Automatic upper cowl flap Reply with quote
This concept has been used in green houses for years. Yes, I suppose
ceiling windows are kind of like cowl flaps. Those motors are huge and
could not be used, but the concept is the same. Perhaps a green house
dealer would be a good source for the sensor/switch.
earl_schroeder(at)juno.co
PostPosted: Mon Jul 02, 2007 12:39 pm    Post subject: Automatic upper cowl flap Reply with quote
Try any junk Volkswagen engine [the air cooled version]They all have a
bellows in the lower right side easily removed and adapted to your
purpose. Tony Bingelis wrote articles about this approach in EAA
magazines and in his own publications. Earl
Carlos wrote:
where do you think I can get that "miraculous" bimetal spring?
Are those "calibrated" for the temperature we want it to actuate?
Carlos
Bill Schlatterer
PostPosted: Mon Jul 02, 2007 3:38 pm    Post subject: Automatic upper cowl flap Reply with quote
> "Get you a temperature bellows off of a VW engine. Sorry I don't know
the proper name. It expands when it gets hot, which it shouldn't do while
you're flying due to the airflow. But it will during post-flight taxi if
you rig it so that the expansion opens the hinged door that Charlie
suggests. Once the engine cools, it will contract to close the door again.
For a full description of the suggestion above, see pages 140, 141, 142, and
143 of Tony Bingelis book,...Firewall Forward. There are complete line
drawings, temp and bellows extension lengths, linkage design, etc. Very
informative and very simple,... almost elegant Smile
Bill S
7a Ark - not yet flying Sad
Bill Schlatterer
PostPosted: Mon Jul 02, 2007 4:10 pm    Post subject: Automatic upper cowl flap Reply with quote
OK, here is a teaser. This is one of the Bengilis pages (P141) showing one
of the cowl flap actuator bellows.
Bill S
 Filesize:  86.14 KB
 Viewed:  347 Time(s)
lm4(at)juno.com
PostPosted: Tue Jul 03, 2007 5:45 am    Post subject: Automatic upper cowl flap Reply with quote
Well Carlos,
I've been trying to find the Tony Bengelis solution. But havn't
found it yet. I think he said it was a air plunger that operates a door
on a Volkswagen. They use it as a sort of cowl flap. Tony used it as a
real cowl flap. When the engine room gets hot the air in the cylinder
gets hot and expands in the chamber and pushes the cylinder rod out. The
rod pushes the flap open.
HTH
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
On Mon, 2 Jul 2007 19:40:43 +0100 "Carlos Trigo" <trigo(at)mail.telepac.pt>
writes:
Thanks Glenn
That is really a very clever solution.
And where do you think I can get that "miraculous" bimetal spring?
Carlos
lm4(at)juno.com
PostPosted: Tue Jul 03, 2007 6:13 am    Post subject: Automatic upper cowl flap Reply with quote
Carlos,
I've found it.
Firewall forward by Tony--Page 141 shows the "VW or Porsche air intake
housing bellows" and measurments. Page 142 shows a picture of how it is
hooked up. It even has an manual over-ride and a flap position indicator.
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
On Sun, 1 Jul 2007 18:20:31 +0100 "Carlos Trigo" <trigo(at)mail.telepac.pt>
writes:
Since I'm using a Subaru engine, I need to have some
kind of ventilation exit on the upper cowling, to dissipate
heat after engine shutdown. Most builders just make a
row of 3/4" holes, and others put side louvers that look
like shark guilds.I intend to make the upper row of holes,
but don't want to let them always open, due to the
possibility of rain penetration and also because they
canhave a bad influence in the cooling air flow inside the
cowling.Therefore I thought of a small (some 15" x 1 1/2")
moving flap, which covers the holes, and is normally
closed in flight.Now the electrical challenge, that I put
here to the smart guys of this list: The ideal solution to
maneuver this flap would be to automatically open it
when the engine is turned off, which in this engine's
case is to turn Off an electrical switch.
How can it be done?
Carlos
RV-9A
P.S. - I know this is not a KIS solution...
PostPosted: Tue Jul 03, 2007 11:17 am    Post subject: Automatic upper cowl flap Reply with quote
Thanks Larry
Another fellow lister ( Bill S ) already sent me a scan of those pages from
Tony Bingelis' book.
Thanks to everybody who responded.
Carlos
hooverra(at)verizon.net
PostPosted: Tue Jul 03, 2007 5:02 pm    Post subject: Automatic upper cowl flap Reply with quote
Here is one source of the VW Temperature control Bellows.
[img]cid:part1.03040601.09050902(at)verizon.net[/img]
http://www.bugcity.com/cgi-bin/WebStore/indexNEW.cgi/mi=yes/srchcd=111119159AX
Ralph C. Hoover
RV7A
hooverra at verizon dot net
 Filesize:  2.92 KB
 Viewed:  4268 Time(s)
Page 2 of 2
