Tailplane Recess
ward.t(at)xtra.co.nz
PostPosted: Thu Jun 28, 2007 1:37 am    Post subject: Tailplane Recess Reply with quote
Hi Europa Builders from the deep cold south,
In regard to the recent tragic events and the PFA Airworthiness Information that eventuated from it, I decided to go ahead with a quick fix to the Tailplane pip-pin recess.
I am one of those 'non compliance' builders with regard to the recess, using, like many others I think, a circular plastic plumbers end fitting with a screw top end. See photo. Sent to me by a UK builder back in 1997!!!
This circular recess entered the tailplane touching TP 6 Sleeve with a screw top lid. I found, to my horror, that the position of the pip-pin head could just about move the distance of the TP12 bushes if the TP 6 outboard sleeve became loose. I did not have any bid over the TP 6 Sleeve as per the manual. It was necessary therefore to have a backup and not allow the head of the pip-pin to move at all restraining the tailplane from moving outwards.
I cut 2 x 16mm diameter aluminium tube to fit over the pip-pin head and glued those into position to the TP6 sleeve. I established those positions by wrapping insulating tape around the pip-pin head to increase their diameter to fit snugly into the tube and installing the pip-pin in the TP6 sleeve. I put grease on the insulating tape to stop gluing the pip-pin to the tube just in case. I then filled the surrounding area within the circular plastic fitting with epoxy plus flox up to the level of the aluminium tube holding the pip-pin.
On one of the tailplanes I had to use a PVC tube( increasing the diameter slightly by using black insulating tape, greased the tape,) and placed it in the TP4 hole to form a circular floor (boundary) up against the TP4 ceiling where the floor broke through the blue foam to stop flox running into the TP 4 cavity.
See photos to make better sense. I had another Europa builder visit today to check it out.He liked it. The tailplanes can now only move 1/2mm before the head comes up against the aluminium tube sides as a good backup.
Email me if you think you may do likewise and need some help.
 Filesize:  68.01 KB
 Viewed:  363 Time(s)
 Filesize:  100.49 KB
 Viewed:  311 Time(s)
 Filesize:  105.72 KB
 Viewed:  393 Time(s)
 Filesize:  63.36 KB
 Viewed:  355 Time(s)
 Filesize:  82.34 KB
 Viewed:  354 Time(s)
Tim_Ward.vcf
 Filename:  Tim_Ward.vcf
 Filesize:  384 Bytes
 Downloaded:  314 Time(s)
grahamsingleton(at)btinte
PostPosted: Thu Jun 28, 2007 2:39 pm    Post subject: Tailplane Recess Reply with quote
Is it really cold in Christchurch? Cold in UK right now! I reckon all
the 747 vapour trails are reflecting heat out and helping to cool the
planet!
I admit to trying to guess what Andy is thinking but my understanding is
that the object of the proposed exercise is to prevent the pip pin from
pulling through the tailplane structure and uncoupling the drive pins.
This is just a back up in case of failure of the TP6 bush bonding.
I was puzzled by the insistence on a "Minimum" area of BID lay up fore
and aft. However this will be more difficult to pull through the foam
core ( and the skin) than the cylindrical structure many of us have
built. The PFA amendment also insists on a flox corner with the skin, no
doubt for the same reason.
Open to correction?
Any comment Nev?
Graham
Graham Singleton
Tel: +441629820187
Mob: +447739582005
raimo.toivio(at)rwm.fi
PostPosted: Thu Jun 28, 2007 2:41 pm    Post subject: Tailplane Recess Reply with quote
Tim,
I had planned to make something similar
but your plan & realization is much much
more sophisticated.
Can somebody there out see anything wrong in it ?!?!
If I did my tailplanes again, I should fit also one long
internal sleeve instead of two short ones. Rigging
would be not so irritating event...
Thank you, Raimo
karelvranken(at)hotmail.c
PostPosted: Fri Jun 29, 2007 1:08 am    Post subject: Tailplane Recess Reply with quote
Graham,
When I was reading how the holes must be drilled through the TP6 and TP4 for
the pip pins on the bench with a friend looking at 90° for correct position,
I knew that it was practically impossible to ream the burrs at the
underside. At the same time drilling first through SS TP6 with a cobalt
drill means that you need directly to apply a certain force to have grip
otherwise the drill would slide. This would result in all but perfect
straight pip pins in all but perfect holes. So, before laying up the cloth
on the tailplanes my holes were drilled and reamed. The recesses of 3 x bid
were made and floxed to the rib, the TP6 and the foam. Even small pipes were
glued at the underside to drain eventual captured water before the final lay
ups. Didn't you have the impression of bad amaturisme when executing
following the manuel?
Best regards,
Karel Vranken # 447 F-PKRL
PostPosted: Fri Jun 29, 2007 4:16 pm    Post subject: Tailplane Recess Reply with quote
Karel
yes I do. the engineering could have been done better. We have to
remember though, Ivan was under a lot of pressure to get the whole
design finished and sell some kits to start earning some money. Paying
wages for three years with nothing coming in is quite scary. I have
learned to accept Ivan for his strengths and forgive his shortcomings,
without people like Ivan things like the Europa don't happen.I know I
could not have done what he did, the Europa has given a lot of people a
lot of pleasure. The rest of us can help each other to refine it and
make it even more rewarding
Graham
karelvranken wrote:
<karelvranken(at)hotmail.com>
of bad amaturisme when executing following the manuel?
Best regards,
nielskock(at)get2net.dk
PostPosted: Sat Jun 30, 2007 1:31 am    Post subject: Tailplane Recess Reply with quote
Well spoken, Graham!
Niels
jrgowing(at)bigpond.net.a
PostPosted: Sat Jun 30, 2007 3:29 pm    Post subject: Tailplane Recess Reply with quote
And I add my
"well spoken" to Neils and Graham -
very few have drive and ability to do what Ivan Shaw has accomplished!
JR (Bob) Gowing UK Kit 327 in Oz
willie.harrison(at)tinyon
PostPosted: Sun Jul 01, 2007 12:18 am    Post subject: Tailplane Recess Reply with quote
There's a piece by Ivan in August's edition of Flyer, describing a
recent trip in a Liberty around the Middle East and then across
Europe to the UK. Although entirely lacking in vanity, his piece
shows he is something of a legend.
Its just a real shame he and Europa didn't stick together long enough
to push through the sort of continuous refinement that, say, the RV
range has had. What he did do however was so good that owners and
builders have been able to pick up where he left off.
Willie Harrison
G-BZNY
On 1 Jul 2007, at 00:26, Laptop JR wrote:
<jrgowing(at)bigpond.net.au>
And I add my
accomplished!
fklein(at)orcasonline.com
PostPosted: Sun Jul 01, 2007 6:17 am    Post subject: Tailplane Recess Reply with quote
It's always been a mystery to me how the company evolved from the
vision and accomplishments of Ivan into the chicanery of Keith Wilson.
Some historical perspective from someone who has some knowledge on the
subject, including the spin-off of the XS from the XL would be much
appreciated.
Fred
PostPosted: Sun Jul 01, 2007 8:01 am    Post subject: Tailplane Recess Reply with quote
Graham,
I completely agree with your opinion and I highly estimate Ivan for the
dream he gave to me. I hope to show you my Rolls Royce Europa some day.
Perhaps in Popham next week-end? When the weather .....
Karel Vranken, # 447 F-PKRL
