michel.dierick(at)yahoo.c Guest
Posted: Wed Jun 27, 2007 1:12 pm Post subject: EGT mal function |
Hi everybody,
I'm new to this list and I already have a question for my Kitfox Classic III.
I just bought my Kitfox but have a problem with the EGT gauge. I - well - my kitfox has the Rotax 582 engine. The EGT indicates the temperature of 1 cylinder, not the second. In flight, the reading of the first cylinder also stops, having no egt readings at all.
As I looked in the engine compartment, I see that the EGT probes are well connected to the cylinder but both lines that are made of metal touch each other while between de engine and the instrument.
Do I have to put some tape around them to avoid contact ?
How did you guys solve this problem.
Greetz,
Mchel Dierick "TheDailyFly" from Belgium where the weather isn't very "summer" today.
Yahoo!7 Mail has just got even bigger and better with unlimited storage on all webmail accounts. Find out more. [quote][b]
Michel
Posted: Wed Jun 27, 2007 2:13 pm Post subject: EGT mal function |
On Jun 27, 2007, at 11:08 PM, michel dierick wrote:
Quote: | I'm new to this list and I already have a question for my Kitfox
Classic III.
Hello Michel,
Well, I think we have a problem here My name is also Michel and I
am also from Belgium, although I have been living 30 years in Norway.I
also have a Kitfox III which also had a 582 but now changed for a
Jabiru 2200. Incidentally, I think the Kitfox Classic is the model IV
and not III.
Quote: | Do I have to put some tape around them to avoid contact ?
Well, since the EGTs are thermo-couplers and measure a variation in
electrical resistance, it is certainly not good to have them shortcut.
But I fail to understand why this would show one working correctly and
the other showing nothing. Another thing is that the EGT probes have to
be connected to the exhaust manifold (hence the name) and not the
cylinders but I guess that's what you meant.
By the way, do you fly a Kitfox in Belgium? Under the experimental or
the UL rule? The reason I ask is that I know there are no Kitfox
registered in Belgium under the UL rule. You might be the first. I
always wondered why. Norway that has half the population of Belgium has
about six Kitfoxes in flying condition.
Greetings from Norway where the summer isn't much better either,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
eskflyer
Posted: Wed Jun 27, 2007 5:22 pm Post subject: Re: EGT mal function |
Mine did the same thing . Changed the thermocouples and fixed the problem . It does not matter if the two wires are run touching together back to the instrument just make shure you have a good gromett through the firewall to keep them from rubbing and shorting out . Do you have the old style clamp-on, or the new thread in thermocouples?
Good luck hope you get it fixed soon
_________________ FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus |
thesupe(at)hotmail.com Guest
Posted: Wed Jun 27, 2007 9:05 pm Post subject: EGT mal function |
The thermocouples probably connect to an "extention cord" to reach the
instrument. Eight connections there all togeather, any one or more of
witch could be somewhat corroded. Also you might try to switch the
thermocouples around to determine if one half of the gauge is shot. Jim
Chuk, Avid MK IV, Chisholm MN
Quote: | From: michel dierick <michel.dierick(at)yahoo.com.au>
Subject: EGT mal function
Date: Thu, 28 Jun 2007 07:08:28 +1000 (EST)
Hi everybody,
III.
Greetz,
"summer" today.
Make every IM count. Download Messenger and join the i’m Initiative now.
It’s free. http://im.live.com/messenger/im/home/?source=TAGHM_June07
cliffh(at)outdrs.net Guest
Posted: Thu Jun 28, 2007 5:57 am Post subject: EGT mal function |
The thermocouples sometime burn out.
I have had to replace both of mine over the years.
Floran Higgins
Helena, Mt
Speedster
912ULS
Float Flyr
Posted: Thu Jun 28, 2007 6:45 am Post subject: EGT mal function |
So called "extension chords" of copper should never be used. By using a
copper wire extension you have just introduced resistances not to mention
four more couples to the circuit. Wires should be of continuous alloys from
the couple.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Thu Jun 28, 2007 7:04 am Post subject: EGT mal function |
I was refering to the extentions supplied with the gauges. Most
thermocouples I've seen are 4' long (to short to reach the gauge) and have
male ends. The connections on the gauge are also male. Therefore, you
need the extention to make the connection. Thanks, Jim Chuk Avid MK IV
[quote]From: "Noel Loveys" <noelloveys(at)yahoo.ca>
Subject: RE: EGT mal function
Date: Thu, 28 Jun 2007 12:12:35 -0230
from
the couple.
Noel
Posted: Thu Jun 28, 2007 12:33 pm Post subject: EGT mal function |
Well Michel, now you got me.
And what do I do now ? Do I respond in english, in het nederlands ou en français ? hahaha !
If you want to see my Kitfox, I put 2 pictures of my UL on the kitfox/photoshare.
I'll put tape around to avoid shortcuts and check the connection. It has been put on the exhaust and not on the cylinders but it's possible that they are not well placed. I'll check.
I bought the Kitfox in France (Airfield Brienne-le-Chateau) and continue to have it registered in FR via DGAC Lille Lesquin. The procedure to fly with the Kitfox in Belgium is to ask the Belgian Authorities a 'Laissé passer de survol" so that you can enter Belgian Airspace.
Greetings from where we had wonderful cumulus today (good for glider pilots)
Michel
Michel Verheughe <michel(at)online.no> wrote:
[quote]--> Kitfox-List message posted by: Michel Verheughe
Classic III.
Hello Michel,
and not III.
But I fail to understand why this would show one working Yahoo!7 Mail has just got even bigger and better with unlimited storage on all webmail accounts. Find out more. [quote][b]
lcfitt(at)sbcglobal.net Guest
Posted: Thu Jun 28, 2007 1:43 pm Post subject: EGT mal function |
Not quite true Noel. As I understand it the temp difference between the
sensor in the probe in the exhaust and the end of the braided end (cold
junction) determines the EGT reading. When we wired the Lancair there was
insuffecient length to run to the gauge so we ensured that all the ends were
in the same ralative location and pigtails are run from there to the gauge.
This system is working fine. Actually my Kitfox is wired the same way with
copper from the cold junction to the gauge.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 850 hrs.
Michel
Posted: Thu Jun 28, 2007 1:46 pm Post subject: EGT mal function |
On Jun 28, 2007, at 10:29 PM, michel dierick wrote:
Quote: | I'll put tape around to avoid shortcuts and check the connection.
You received some very good advices from the people on this list,
Michel. Try them and maybe switch the two thermocouplers as advised
first. Incidentally, it is a good way to check how they work. You'll
always see one cooler than the other. To check if it is the gauge or
the real temperature, you swap them and see how it works then. Good
luck.
For the rest, I have sent you a direct email in French. We will not
bother our English speaking friends and force them to use Babelfish!
Greetings from Norway where we also have perfect glider weather. (due
to prevailing winds, whatever weather is over Belgium, it will be over
Norway 24 hours later! )
Michel Verheughe
Norway
Float Flyr
Posted: Thu Jun 28, 2007 7:42 pm Post subject: EGT mal function |
Let me see if I have this right you are saying that you can connect copper to the alloys of a thermocouple with out creating a thermo couple within the connection. To maintain a linear calibration the wires should have alloy continuity right from the hot junction to the cold junction to the gauge itself.
What is true is the small EGT gauges we use may not be sensitive enough to display the difference and lets face it none of us are flying in -60C so the use of a cold junction is or questionable value. However no one, other than the man upstairs, will know for sure what the introduction of another four cold junctions will do for the linearity and accuracy of the system as a whole.
Ref: Aircraft Instruments, Second Edition, ISBN 0-582-01898-6, E.J.H. Pallett
Ch. 11, Pg.291
External Circuit and Resistance
The external circuit of a thermoelectric indicating system consists of a thermocouple and it's leads, and leads form the junction box at the engine bulkhead to the indicator terminals. From this point of view, it might therefore be considered as a simple and straight forward electrical instrument system. However, whereas the latter may be connected up by means of the appropriate copper leads or cable normally used in aircraft, it is not acceptable to do so in a thermoelectric system.
This may be explained by taking the case of a copper/constantan thermocouple which is to be connected to a cylinder-head temperature indicator. If a length of normal twin-core cable is connected to the thermocouple terminal box, the one copper lead will be joined to it's thermocouple partner, but the other one will be joined to the constantan lead. It is thus apparent that the joining of two dissimilar metals introduces another effective hot junction which will respond to temperature changes at the junction box, and in unbalancing the temperature/e.m.f. will cause the indicator readings to be in error. Similarly, all terminal connections which may be necessary for routing the leads through the aircraft and connections at the indicator itself will create additional hot junctions and so aggravate indicator errors.
In order to eliminate those hot junctions, it is the practice to use leads made of the same materials as the thermocouple itself, such leads being known as extension leads. It is sometimes the practice also to use thermocouple materials having similar thermoelectric characteristics in combination; for example, a chromel/alumel thermocouple may be joined to it's indicator by copper/constantan leads, known as compensating leads. These leads not only compensate for parasitic effects but also reduce the cost as chromel/alumel is expensive.
There is more going into consistency of resistance to the system but I think you get the idea. As anyone who has read my posts will know there will probably be enough typos in here to qualify me into the non-typist pool... I apologize for typo errors that may occur as I transposed this myself.
Long and short is it may work, after a fashion, with speaker or telephone copper wire extensions wired in, but it is in no way right or proper.
[img]cid:304383103(at)29062007-0D0E[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
Archive this one
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
369 Time(s) |
Kitfox III-A
Float Flyr
Posted: Thu Jun 28, 2007 7:47 pm Post subject: EGT mal function |
You can also test the output of the thermocouples at relatively low temperatures by putting the tips of the probes in boiling water ( just below 212 F for most people) or in the flame of a butane lighter which should be above 500F... just make sure you test both probes at the same time. and get the same readings.
[img]cid:606524403(at)29062007-0D15[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
384 Time(s) |
Kitfox III-A
Posted: Thu Jun 28, 2007 8:40 pm Post subject: EGT mal function |
I believe that in the directions that come with the gauge, there is a number
(resistance?) you should be able to read on an electrical meter between the
black and white wire on the thermocouple if it is working correctly. I just
looked at an instruction sheet for a Westach gauge. They call the
"extention cord" I refered to a patch cable. This is what they say: Patch
cable may be shortened or lengthened up to 20 feet without affecting
accurity of unit. Useing 20-22 gauge stranded wire is recommended. Thanks,
Jim Chuk Avid MK IV
Date: Fri, 29 Jun 2007 01:15:00 -0230
below
the same readings.
Canada
Aerocet 1100s
<mailto:noelloveys(at)yahoo.ca> noelloveys(at)yahoo.ca
pwmac(at)sisna.com Guest
Posted: Thu Jun 28, 2007 9:13 pm Post subject: EGT mal function |
The aeroelectric list has beat this subject to death. Small error, just keep the junctions in the same place. Lots of planes flying with copper wire extensions. No need to be theoretically correct for EGT.
Test it at low temps and see a big error. Test it at 1400 degrees and the error is lost.
Paul
At 09:39 PM 6/28/2007, you wrote:
[quote]Let me see if I have this right you are saying that you can connect copper to the alloys of a thermocouple with out creating a thermo couple within the connection. To maintain a linear calibration the wires should have alloy continuity right from the hot junction to the cold junction to the gauge itself.
Ch. 11, Pg.291
[img]cid:7.1.0.9.0.20070628230350.01e48f20(at)sisna.com.1[/img]
Canada
Aerocet 1100s
Archive this one
Description: |
Filesize: |
19.77 KB |
Viewed: |
383 Time(s) |
Float Flyr
Posted: Fri Jun 29, 2007 8:41 am Post subject: EGT mal function |
Let's see... Westach, eh.(just practicing 2 days from Canada day) Isn't that the company that manufactured the great tachometers that everyone has been having problems with?? The harness with my EGTs (Westach) were long enough to require some shortening. It could have been a problem if I had a pusher style plane. The units are of such high calibre that a quarter turn of one of the probes corrected a 40 degree mismatch in EGT readings.
Never the less if you want to avoid problems, do it right. If that means getting the correct wire (chromel/alumel) to connect the instrument so be it.
There is a strong point to be made that even a poor EGT is preferable to none. Let's face it we are only looking for temperature trends at this level. When an uncalibrated, uncompensated instrument featuring several additional hot junctions of unknown value and a harness resistance of un known value reads 950F are you really willing to accept that until you check your plugs and verify that in fact it's probably closed to 1100F.
I stand by my experience and training in this particular topic.
[img]cid:679392916(at)29062007-0D5F[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
375 Time(s) |
Kitfox III-A
Posted: Fri Jun 29, 2007 12:25 pm Post subject: EGT mal function |
Nope!
Lowell
