				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| gus.fraser(at)gs.com Guest
				|  Posted: Tue Feb 14, 2006 9:42 am    Post subject: 4340 Alloy steel sheet needed. |   |
				| I need to get a specific steel sheet I need not a lot about 4 inches sq of 4340 alloy. The Russian part I am replacing is made of GOST4543-71 who's US equiv is 4340. Trouble is aircraft spruce etc only supply 4340 in bars.
4130 is not quite hard enough.
 Any help much appreciated.
 See spec below
 Gus
 steel grade     GOST
 TU      fraction total mass of elements, %
 C       Si      Mn      Cr      Ni      Ti      Mo      V       Co      S       P
 not more than
 30čçóá  GOST 4543-71    0.28-0.34       0.9-1.2         0.8-1.1         0.8-1.1                                                 0.035   0.035
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| dsavarese(at)elmore.rr.co Guest
				|  Posted: Tue Feb 14, 2006 9:58 am    Post subject: 4340 Alloy steel sheet needed. |   |
				| See if these folks can help.
http://www.advancedglobalmaterials.com/4130-4340sheet.asp
 Dennis
 Alloy Steels
 4340Mod
 4620
 4720
 6150
 8620
 8740
 9310
 52100
 H11
 HY60 -        100
 D6AC
 HP 9 - 4        -  20
 300M
 HP 9 - 4 -        30
 D6-AC
 HY -        TUF
 Maxel 3        1/2
 Maraging  250,  300,       350
 Aircraft Quality & Vacuum      Melted
 *All materials        available  in the following:
 Plate, Sheet,        Rod, Bar, Tubing, Pipe, Wire, Forgings, Custom Shapes & Sizes
 [quote]   ---
		| Back to top |  |
				|  Posted: Tue Feb 14, 2006 10:18 am    Post subject: 4340 Alloy steel sheet needed. |   |
				| Dennis,
Thanks for that I called them yesterday and they only have  larger sizes available. .1 and up. For reference this is the steel used for  undercarriage units also.
 Thanks again
 Gus
 [quote]         From: owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis    Savarese
 Sent: Tuesday, February 14, 2006 12:57 PM
 To:    yak-list(at)matronics.com
 Subject: Re: 4340 Alloy steel sheet    needed.
 Dennis
 Alloy Steels
 4340Mod
 4620
 4720
 6150
 8620
 8740
 9310
 52100
 H11
 HY60 -          100
 D6AC
 HP 9 - 4          -  20
 300M
 HP 9 - 4          - 30
 D6-AC
 HY          - TUF
 Maxel 3          1/2
 [quote]     ---
		| Back to top |  |
		| cgalley(at)qcbc.org Guest
				|  Posted: Tue Feb 14, 2006 1:24 pm    Post subject: 4340 Alloy steel sheet needed. |   |
				| Have you tried Dillsworth
 [quote]   ---
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
