Ray.R.Doerr(at)sprint.com Guest
Posted: Thu Jan 05, 2006 5:32 am Post subject: Locks for the doors of the RV-10. |
Has anyone solved the problem on how to provide a keyed lock for
both RV-10 doors? If you have and you have pictures, I would love to
see them.
Thank You
Ray Doerr
40250
Both doors are now hinged to the airplane.
Tim(at)MyRV10.com Guest
Posted: Thu Jan 05, 2006 5:52 am Post subject: Locks for the doors of the RV-10. |
Jesse Saint solved it by drilling a hole through the thumb button
latch release, and sticking a small paddlock through. Other than
that method, I don't see a very easy way.
Tim Olson -- RV-10 #40170
Doerr, Ray R [NTK] wrote:
jesse(at)itecusa.org Guest
Posted: Thu Jan 05, 2006 3:03 pm Post subject: Locks for the doors of the RV-10. |
A code padlock, to be exact, so you don't have to carry around another key.
It isn't very high-tech, but it works. Nobody has stolen the plane yet.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
Tdawson(at)avidyne.com Guest
Posted: Thu Jan 05, 2006 3:26 pm Post subject: Locks for the doors of the RV-10. |
Got a picture of your lock in action?
TDT
dlm46007(at)cox.net Guest
Posted: Thu Jan 05, 2006 3:41 pm Post subject: Locks for the doors of the RV-10. |
We haven't gotten to that problem yet but I plan to use the same locks as
used for the baggage door. If a hardpoint is created forward of the inside
latch so that the lock arm could prevent/allow movement of the lever as
desired. The keyed side would extend through the door to the outside.
NYTerminat(at)aol.com Guest
Posted: Thu Jan 05, 2006 10:55 pm Post subject: Locks for the doors of the RV-10. |
Is it TSA apporved?
In a message dated 1/5/2006 6:25:42 PM Eastern Standard Time, Tim(at)MyRV10.com writes:
| Quote: | > A code padlock, to be exact, so you don't have to carry around another key.
| Quote: | It isn't very high-tech, but it works. Nobody has stolen the plane yet.
Posted: Fri Jan 06, 2006 8:07 am Post subject: Locks for the doors of the RV-10. |
Probably somewhere, but I am about 1,500 miles from the plane for the next
several months. Somebody from Osh might have one that they took, but I
don't think I have one with me.
Actually, John Nuys, I believe, put locks on his doors similar to those on
the baggage door, if not the exact same. I didn't get pictures of that
either, though.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
Posted: Fri Jan 06, 2006 8:12 am Post subject: Locks for the doors of the RV-10. |
The beauty of this plane is that you get to avoid the stinking…uh, I mean the, make-me-feel-so-safe-when-they-frisk-my-grandmother, TSA guys. I mean this will all due respect, and you can determine for yourselves how much respect is due. Honestly, though, has anybody else gotten the idea that both the people the hire and the machines they buy must have had “must have a very bad attitude” on the job description or on the PO.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
I am in Ecuador until May, 2006. If you have questions regarding I-TEC, please call the office at 352-465-4545. If you would like to talk to me, please call me at 352-505-1899. This number won't always be on, but it has voicemail that will get to me in Ecuador.
