Tailplane Retention
rogerabc
PostPosted: Sun Jun 24, 2007 10:54 pm    Post subject: Tailplane Retention Reply with quote
Dear Forum/PFA/Europa,
This mod has not been approved or tested and the photos are only of
a trial installation so please don't bother with too much negative
feedback - it wasn't even my idea originally!
It does fit the tailplanes securely with no load transferred to the
internal bushes.
I'm not proposing an alternative system, it's just an idea for
consideration by those who are reviewing the design of our
tailplane retention system.
Brgds,
Roger
 Filesize:  27.02 KB
 Viewed:  554 Time(s)
 Filesize:  57.89 KB
 Viewed:  630 Time(s)
 Filesize:  49.24 KB
 Viewed:  585 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Jun 25, 2007 12:09 am    Post subject: Tailplane Retention Reply with quote
Hi! Roger
I think the concept is an excellent one but.......(NOT BEING NEGATIVE)
a) I would prefer not to invade the existing drive plate and I don't
like sharp filed corners in "canware fabrications". I'd think that the
locator plate could be "fashioned" to engage behind the welded pin
without any filing of the drive plates.
b) I would prefer to have two such retainers on each tail plane fore and
aft of the drive plates. Both similarly "fashioned" as a) above.
c) I could imagine a temporary rigging prop tool to drop between the two
(as in (b) above) upstandings on the surface of the tail planes to
assist one man rigging to be removed prior to engaging the pip pins.
IMHO my clamps take care of the inboard problems, your concept as above
takes care of the outboard problems, this then only leaves the central
horn possibility!
But of course we mere mortals aren't yet privy to all that we are
looking to solve. To enable innovative ideas to be contributed it would
be more helpful for us to "see the horse before we start mending the
cart"!
Hopefully you have copied Ian Rickard in on this concept in time prior
to decisions being made about massive tailplane invasion.?
Bob Harrison G-PTAG
g-iani(at)ntlworld.com
PostPosted: Mon Jun 25, 2007 1:51 am    Post subject: Tailplane Retention Reply with quote
Roger
Thanks this is GREAT. What we all want is this sort of thinking,
outside the box. Please do not apologise for any failings others might
spot. This may be the seed of the idea that saves us all a lot of
problems.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
h.siedsma(at)inter.nl.net
PostPosted: Mon Jun 25, 2007 2:16 am    Post subject: Tailplane Retention Reply with quote
Perhaps it is stupid but I think about the following solution. Pre- load
the TP12 pin. Easy to do without taken the tail system in part. Drill a hole
just behind the TP 12 ( Perhaps only 4 mm ) Take a piece of spring metal.
Through the hole and than bench it around under load. I have no idea what
the pre-load have to be to avoid any movement on the pins. The spring can
be heavy due to the fact you can use a long piece and cut after assembly or
make a special tool.
My tail has already 6.5 mm play on the trailing edge and my plane did not
fly one meter. It has no play on the TP9. My holes are drilled at a special
workshop. It all look perfect but ....
Perhaps this is not a solution for the aviation...
Hans
-----Oorspronkelijk bericht-----
Van: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Namens G-IANI
Verzonden: maandag 25 juni 2007 11:52
Aan: europa-list(at)matronics.com
Onderwerp: RE: Tailplane Retention
Roger
problems.
 Filesize:  77.77 KB
 Viewed:  611 Time(s)
ami(at)mcfadyean.freeserv
PostPosted: Mon Jun 25, 2007 10:53 am    Post subject: Tailplane Retention Reply with quote
Nice idea, but fundamentally doesn't provide connection of the TP skin to
the outer pip pin hole (which I understand the PFA are looking for) in the
event that the outer bush becomes disbonded and grossly loose. .
Duncan McF.
bill.sue(at)orcon.net.nz
PostPosted: Mon Jun 25, 2007 7:21 pm    Post subject: Tailplane Retention Reply with quote
I am visiting the UK, staying in London for 4 weeks from 28th this month.
Am planning to attend the PFA Weekend at Popham 7/8th July.
Will there be any Europa builder/flyers there to chat to and which is
the best day to attend.
Sue & Bill
Mono XS
914 / Airmaster
580Hrs
PostPosted: Tue Jun 26, 2007 1:18 am    Post subject: Tailplane Retention Reply with quote
Hi! Bill and Sue
We can't help with things to do in London however should you venture
"North of Watford" give us a call...... we have Kingsley Hurst and
Janice with us for a couple of nights at present but with the weather as
it's been they are sorry to not have brought their cossy's with them.
Bob and Jan Harrison G-PTAG North Lincolnshire.
01472 852498
do not archive.
mau11(at)free.fr
PostPosted: Tue Jun 26, 2007 2:03 am    Post subject: Tailplane Retention Reply with quote
Hi Roger Sheridan,
I like your solution,
do you have a face picture, and/or drawing.
Michel Auvray
Builder 145 > 300 hours flight
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com]De la part de Roger
Sheridan
Envoye : lundi 25 juin 2007 08:53
A : europa-list(at)matronics.com
Objet : Tailplane Retention
internal bushes.
Brgds,
Roger
grahamsingleton(at)btinte
PostPosted: Tue Jun 26, 2007 4:21 am    Post subject: Tailplane Retention Reply with quote
Maybe I should go back to making wetsuits for a living! Are you flooded
over there?
Graham
R.C.Harrison wrote:
Hi! Bill and Sue
01472 852498
willie.harrison(at)tinyon
PostPosted: Tue Jun 26, 2007 8:56 am    Post subject: Tailplane Retention Reply with quote
Hello Bill
Mine (G-BZNY) is un-grounded again having passed its FSB 006 checks
today. I'll see if I can negotiate a Permit to Fly from Higher
Authority (SWMBO) to go to Popham.
Who knows, Summer might even put in an appearance.
Willie
On 26 Jun 2007, at 04:19, Bill and Sue wrote:
<bill.sue(at)orcon.net.nz>
month.
is the best day to attend.
Sue & Bill
Mono XS
914 / Airmaster
580Hrs
PostPosted: Tue Jun 26, 2007 9:09 am    Post subject: Tailplane Retention Reply with quote
Hi! Graham
No we aren't flooded since we are about 300ft above sea level. However
Roger Cullum and family had to stay with us last night and tonight since
his house has 1ft of water in it. Never mind wet suits ....a device to
make water run up hill would be sure to make a bloody fortune !
G'day Mate!
Bob Harrison G-PTAG
Do not archive.
jrgowing(at)bigpond.net.a
PostPosted: Tue Jun 26, 2007 2:22 pm    Post subject: Tailplane Retention Reply with quote
Well Kingslely and Jan sure get around!
Best Wishes to you all from far off and cold Oz.
JR (Bob) Gowing UK Kit 327
PostPosted: Wed Jun 27, 2007 1:11 am    Post subject: Tailplane Retention Reply with quote
there is one, it's called a tree!
Graham
R.C.Harrison wrote:
Hi! Graham
G'day Mate!
Bob Harrison G-PTAG
Do not archive.
Trevpond(at)aol.com
PostPosted: Wed Jun 27, 2007 6:33 am    Post subject: Tailplane Retention Reply with quote
Hi Bob,
My hangar/garage was flooded to 3 feet and my Trailer was completely under water as were 2 Mig Welders, my compressor, most of my power tools and assorted tool boxes and trolleys. My beautiful new Chysler Crossfire was flooded to the dashboard and appears to be a write-off. Thank goodness my aeroplane was in it's hangar at Abbots Bromley. Our kennels has survived, gold medals for swimming were awarded to staff rescuing dogs and cats (I'm not eligible as I'm both management and retired!) The Cattery is now closed and will be rebuilt from scratch as the Insurance company think that will be the cheapest option.
Hey ho, just another day in my life and of course, according to my Wife, it's all my fault!! Can I come and live at your house as well?
mikenjulie.parkin(at)btin
PostPosted: Wed Jun 27, 2007 12:31 pm    Post subject: Tailplane Retention Reply with quote
Hi Bob,
Regards to Roger, Julie and I are in a hotel - our house is flooded also.
'Beam me up Scottie.'
cheers,
Trev,
We must compare natural disaster notes!!!!!
regards,
PostPosted: Wed Jun 27, 2007 2:09 pm    Post subject: Tailplane Retention Reply with quote
Dear Bob
I was on a floodable farm for some years and experienced a few floods, swimming to get the cattle off the flats at one stage.
I don't know which Bob you are writing to but I can understand a little of how you are feeling. I wish you good luck in getting things together again. Hopefully it will not be as bad as it first appears and you can do at least some rescuing.
I hope a surge of energy engulfs you and you can "get stuck into it" as they wold say in Oz.
Best Wishes
JR (Bob) Gowing UK Kit 327 in Oz.
Trevpond(at)aol.com
PostPosted: Thu Jun 28, 2007 1:29 am    Post subject: Tailplane Retention Reply with quote
Hi Mike,
If we both start swimming now, we should meet up near the reservoir at Rotheram - I'll be wearing the Red Fins!!!! Best to Jules.
Trev
PostPosted: Thu Jun 28, 2007 12:47 pm    Post subject: Tailplane Retention Reply with quote
I am afraid that Jules lost a major sense of humour failure about midday on monday as the filthy water rose above her ankles in the middle of her newly decorated dining room.
Oh Gawd!!!!
regards,
